- Old bulkhead with rot
- 56782335-DE61-45C5-A462-06B7C5993075_1_105_c.jpeg (281.62 KiB) Viewed 1314 times
- Fresh Hydro Tek
- 853EFCC2-852B-4B23-9428-4291BD0487AE_1_105_c.jpeg (263.65 KiB) Viewed 1314 times
- Dry fit bulkhead
- B0151B00-C0D2-4782-9318-184058FA940F_1_105_c.jpeg (242.65 KiB) Viewed 1314 times
- From inside head.. new compression post, new bulkhead piece, freshly glued and screwed.
- 60F0F227-E106-4440-B178-415447EA422B_1_105_c.jpeg (224 KiB) Viewed 1314 times
- Table re-attached. Ideas for covering the mis-matched surfaces?
- 98113571-45DD-4B35-A4C2-7406CB3856BE_1_105_c.jpeg (200.63 KiB) Viewed 1314 times
- Table dry-fit with new holes drilled. Chainplate bolts removed to saturate bulkhead with penetrating epoxy. Will install mast wire cover later after saturating that corner with penetrating epoxy and creating a safe place for water leaks to go.
- 2DE6D5E9-3B05-4299-B18E-A5BBE2525583_1_105_c.jpeg (236.11 KiB) Viewed 1314 times
