Need to know 2-29 window gasket, seal, rubber
Mac_39_74!
I need to know what gasket material to use on my 2 opening portholes in my head area on my Cal 2-29 can you still get them..?
I do not know if they are still available, but you can check with: Mark's Plastics -760 064 6680, sealspars.com, D&R Marine -508 644 3001. All three are very knowledgeable and if they do not have it they may know a resource to get it. For mine I was able to bring the seals back with a few small applications of silicone grease. Also I added a secondary seal in the groove just beyond the seal. I used round insulation foam from home depot. If I remember correctly 5/8".
port seal.JPG (18.23 KiB) Viewed 150000 times
You can rescue pretty bad seals by cleaning and turning upside down …
viewtopic.php?t=360
pbnelson
This may be a bit late, but on my Cal-34 Perko portlights I was able to use an OEM gasket from Perko, #0461. Width 1/4" - 7/16", Height 3/8". They worked perfectly for me.
https://www.perko.com/catalog/ventilato ... stripping/
There are numerous resellers. For example, WestMarine, here: https://www.westmarine.com/perko-weathe ... 68344.html
Last bumped by Anonymous on Mon Jun 24, 2024 3:18 am.
