1981 CAL 31 FOR SALE-HIGHLY CUSTOMIZED
thudbranch
Evania Bow On in Canada
aaEvania Bow & Dink dressed for Cruising Crop.jpg (610.81 KiB) Viewed 2339 times
Evania in Desolation Sound
zEVANIA at Teakerne Arm -Falls 800x600.jpg (46.94 KiB) Viewed 2339 times
Tri-metric Gennaker on close reach
Tri-metric Gennaker on close reach 20160531_124336.jpg (317.16 KiB) Viewed 2339 times
Head
Head
Head 8x6.jpg (37.91 KiB) Viewed 2339 times
Refrig & galley work area
dzRefrig & Nav area only.jpg (137.75 KiB) Viewed 2339 times
V berth looking Forward
hV Berth looking forward 800x600.jpg (41.16 KiB) Viewed 2339 times
Main Cabin Looking Aft
dMain Cabin looking Aft-Note liquer Cab &CabDoors.jpg (306.82 KiB) Viewed 2339 times
Bow-Sprit Extended
Bow-Sprit Extended
aCal31-Bow -Strbd-SpritExtd.jpg (159.03 KiB) Viewed 2339 times
Bpw-Sprit Retracted
Bpw-Sprit Retracted
bCal31-Bow -Strbd-SpritRetracted.jpg (114.29 KiB) Viewed 2339 times
Port Side View
Port Side View
A highly customized Cal 31 sloop, Evania is rigged for single-handing or a cruising couple. Just add food, top-up the tanks, and go cruising. Most systems installed by myself, an engineer with over 20000 cruising miles under my belt. I have sailed Evania many happy miles and days unassisted, alternating between the furling gennaker and furling genoa while single-handed. She is a light air boat perfectly suited for Puget Sound. Lots of beautiful original teak in cabin. She sleeps 5; 2 in the V berth, and 2 in the main cabin dbl berth +1 main cabin single berth. She is 32LOA, 10’ beam, dry weight 9200lb, draft 5.0’, SA/Displ 17.95. Her hull is solid fiberglass with foam cored deck.
Health forces sale. Lots of extra gear included such as binoculars, handheld VHF radio, navigation tools, spare hardware, cruising spares, spare autopilot, spare chart plotter, lbs. of spare stainless fasteners, engine spares, etc. Evania needs bottom paint, hull polishing and waxing, and possibly cabin cushions. FYI “Evania” is Irish for “serene” and Old English for “swift.” If you want to cruise Puget Sound alone or with one friend, this is Cal 31 is for you. Email for more info and pictures. $28500.
CRUISING FEATURES and GEAR SUMMARY
1. Custom 700 sq ft gennaker on furler with all gennaker controls lead aft.
2. Custom retractable bow sprit to allow use of gennaker furler above.
3. Folding 3blade prop- Kiwi model new 2014
4. Dodger (new 2012) and Bimini (new 2016).
5. Custom cockpit seating allows for 4 people to sit easily (original cockpit design maxed at three.
6. Custom Grab handle and Chart Plotter mount added over binnacle
7. Cruising Electronics; Raymarine Autopilot, Standard Horizon Chart plotter, wind Point and speed, Depth and speed + optional readout.
8. Custom propane locker and cockpit storage cubby’s
9. Lazarette features custom SS storage trays Port and Starboard sides.
10. Large Refrigerator with ice trays & external digital temperature gage.
11. Solar panel feeds dual golf-cart battery banks (Trojan T105’s – 250amp hours per bank)
12. Custom companionway hatch screen & custom hatch
13. SAILS; Ullman laminate 130 genoa and laminate main sails. + Spare 105 Dacron jib
14. Gennaker (new 2016) on a “top-down” roller furler (new 2013).
15. Propane Force 10 -3 burner stove/oven
16. Propane system new 2013 with sealed locker, fiberglass 20lb tank and safety gas “sniffer.”
17. “Bus” (engine hot water) cabin heater new 2018
18. Lots of special shelves and storage added
19. Bimini includes extra bracing for integral OB motor hoist (up to 75# weight)
20. OB motor mount on stern rail
21. Propane Force 10 BBQ on stern rail
22. Life Sling MOB retrieval system in custom rail mount canvas box.
23. Universal 16 hp engine well cared for- under 1500 hours. Always starts in a few seconds. Universal diesels are based on a Kubota Tractor engine and most Kubota parts fit perfectly.
24. Custom foam air cleaner installed at about 600hrs – factory original air filter was only a screen
25. Custom fuel polishing system built into fuel system- polish your fuel with no fuss.
CABIN & COMFORT/SAFETY FEATURES;
1. Port Settee sets up for double bunk (custom folding legs added)
2. Fold down Table reinforced with custom Vertical grab post
3. Custom shelves added in both closets and in V berth.
4. Refrigeration includes temperature gage and ice making capacity.
5. Custom cabinet doors (mesh front) added in main cabin
6. Head with 3 way valve and plastic 16 gal holding tank (All new 2007)
7. Portable diaphragm hand pump & 1.5” hoses for emptying holding tank in the wilds
8. Permanently mounted manual Bilge pump operates from cockpit
9. Air vents added to both closets
10. ALL CABIN LIGHTING IS HIGHLY EFFICIENT LED (SOME NEW Fixtures added and other fixtures converted.)
11. 2018 Stereo with Bluetooth & 100watt amp
12. Custom fabricated hatch screen and clear window installed
Under Gennaker- Queen Charlotte Straight
Pryce Channel under Spinnaker 20160608_115901 - Copy.jpg (714.99 KiB) Viewed 2339 times
Dining Table Half open
gDinning Table Half folded.jpg (389.73 KiB) Viewed 2339 times
Dining Table open
Dining Table open
fdinning table -4 places.jpg (215.61 KiB) Viewed 2339 times
Engine
Engine
eEngine Compartment.jpg (360.75 KiB) Viewed 2339 times
Custom cockpit features
cCustom Cockpit Features.jpg (479.35 KiB) Viewed 2339 times
