3 messages2005-12-02 00:26 through 2005-12-02 14:57
it's snowing here; winterizing tips for live-aboards please
jeribelle20002005-12-02 00:26
Hi all,
Well, the snow has hit here in Anacortes. I have turned off the water
to the hose that leads into the sailboat we're living on right now,
and the hose is opened up to allow any water left to trickle into the
bilge, which I can pump out. This morning I picked up a plunger to
work on my sink drains, as both are plugged tight, leaving me without
running water. I got one unplugged, and will work on the one in the
head in a bit. It is just too cold for the 2 heaters to keep up, with
the water being around 50 degrees, and the air temperature expected
to go into the 20s tonight. So I closed off the forward v-berth cabin
to conserve heat, and am running both heaters for the main cabin and
head, where I'll be for the next few days. I got all items out of the
dock box and into the boat that might be affected by freezing.
The Morgan (future digs) is heated by an electric heater on low, with
the water heater inside, and the incoming water is off, so it should
be ok, I think.
Anybody have any ideas of other things that might need attention,
please help me out. I'm doing this on the fly, as DH is in the air
right now, out of town, and I've never done this before.
girlsaylor
Re: [Cal_Boats] it's snowing here; winterizing tips for live-aboards please
John Mallon2005-12-02 01:03 UTC
Hi,
I'm not sure this will be of help as it the check list developed for laying up our particular boat which we are not living on. It will give you some ideas hopefully of things to check.
John
17. Winterize Lists
Winterize List
Ø Antifreeze required 9 gal
3 Anti corrosion:
2 gal Engine Raw water
1 gal Engine Fresh water
8 Propylene Glycol:
1 gal Watermaker
2 gal Head
1 gal head/shower drain
1 gal Galley drain
2 gal Main bilge
½ gal Anchor bilge
½ gal Engine bilge
Ø General
o Close windows, open vents
Ø Engine
Change lube oil & filter (warm)
Change transmission oil
Change fuel filter & Racor filter
Change fresh cooling antifreeze
Close input thru-hull cock
Run engine while pouring 2 gal antifreeze into filter in e/room
Turn over for 10 seconds with stop button pressed to coat inside engine with new oil
Ø Outboard
Grease spindles
Add gas stabilizer to tank
Ø Watermaker
See KL-Syst.doc Watermaker Pickling sequence
Ø Dock Lines: double all
Ø Cover
Chafe points: boom, windscreen
Tarp = 15 x 25 ft
Tie to lower life line P&S
Ø Water
Drain all tanks (65 gal, bladder, hot water)
Fit air compressor pump (under 40lbs) to input of water pressure pump (to blow water out of pump)
Close all faucets, open drain thru-hulls
With air on open each faucet (drain hot water tank & immediately close), galley x 2, head x 2, shower,) and have all water blown thru.
Fore and aft deck washes
Open all faucets, close thru-hulls
Remove Aquafilter filters
Remove all water filters (inlc. pressure water, watermaker raw water, watermaker mixer, foot pump)
Remove all water strainers (incl. pressure water, head intake & shower drain)
Ø Head
Empty holding tank
Run macerator/pump till dry (2-3 short bursts)
Fill bowl with Propylene Glycol antifreeze and flush through (1 second/foot)
To out of hull
Divert to holding tank, 1 gallon to holding tank
Hand pump antifreeze from holding tank
Close thru-hulls
Fill shower and head drain with antifreeze
Remove all 3 liquid soap dispensers pumps and place in basins
Ø Shower/head drain
o Remove strainer cover
o Bleed antifreeze through from both head and shower.
o Replace strainer cover
o Pump antifreeze through pump to sink drain
Ø Galley drain
Pour in ½ gallon anti-freeze
Ø Bilges
Pour in antifreeze, cycle pump to move through to sea:
Main bilge
Engine bilge
Anchor bilge
Ø Thru-hulls
Close all
Ø Diesel
Top off all tanks (use WaterZorb)
De-Commission/Store
Ø Plumbing
Thru-hulls
Propane bottles
Ø Electrical
Power drains
Solar panels?
Re-commission List
Ø Plumbing
Thru-hulls
Ø Mechanical
Pull back on shaft log seal bellows to lubricate
Set of insect bombs
Ø Engine
Open input thru-hull cock
Turn over for 5 seconds with stop button pressed to coat parts with oil
Ø Water
Re-connect hot water tank drain
Re-connect main water tank line at pump
Re-install Aquafilters
Re-install all water filters
Re-install water strainer fror pressure water
Ø Holding Tank
Fill and empty twice (to remove all anti-freeze, which kills active bacteria in KO) then treat with 4oz of KO.
jeribelle2000 <gi… [at] hotmail.com> wrote:
Hi all,
be ok, I think.
girlsaylor
SPONSORED LINKS
Boating sailing Sailing boat Sailing Boating
YAHOO! GROUPS LINKS
Visit your group "Cal_Boats" on the web.
To unsubscribe from this group, send an email to:
Ca… [at] yahoogroups.com
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Yahoo! Personals
Let fate take it's course directly to your email.
See who's waiting for you Yahoo! Personals
Re: it's snowing here; winterizing tips for live-aboards please
jeribelle20002005-12-02 14:57
John,
Thank you, and yes it helps me try to prevent damage while living
aboard. As the Cal is up for sale and will have to be winterized when
we move onto the Morgan, unless a miracle sale happens quickly, I've
got one live aboard vessel to attend to and one on the hard to tend
to. We're looking at possible job relocation, and I would have to
tend to both boats and follow when done here. If we have to truck the
Morgan again, I'll be winterizing it alone and arranging the
trucking, with Dudley once again. So, it's kinda mind-boggling, being
faced with winterizing the Cal and getting it delivered to the broker
on the other side of the island here.
Anyhow, I'll be readying the Cal to show to a prospective buyer
today, then head over to the Morgan with a load of stuff that doesn't
get sold with the Cal.
girlsaylor
--- In Ca… [at] yahoogroups.com, John Mallon <bmajecllc@y...> wrote:
> Hi,
> John
> 17. Winterize Lists
> Winterize List
> 3 Anti corrosion:
> 8 Propylene Glycol:
> 1 gal Watermaker
> 2 gal Head
> 1 gal Galley drain
> 2 gal Main bilge
> ½ gal Anchor bilge
> ½ gal Engine bilge
> Ø General
> Ø Engine
engine with new oil
> Ø Outboard
> Grease spindles
> Ø Watermaker
> Ø Cover
> Tarp = 15 x 25 ft
> Ø Water
shower drain)
> Ø Head
> Empty holding tank
second/foot)
> To out of hull
> Close thru-hulls
> Ø Shower/head drain
> Ø Galley drain
> Ø Bilges
> Main bilge
> Engine bilge
> Anchor bilge
> Ø Thru-hulls
> Close all
> Ø Diesel
> De-Commission/Store
> Ø Plumbing
> Thru-hulls
> Propane bottles
> Ø Electrical
> Power drains
> Solar panels?
> Re-commission List
> Ø Plumbing
> Thru-hulls
> Ø Mechanical
> Set of insect bombs
> Ø Engine
oil
> Ø Water
> Ø Holding Tank
> jeribelle2000 <girlsaylor@h...> wrote:
> Hi all,
water
the
without
with
cabin
and
the
with
should
> be ok, I think.
> girlsaylor
> SPONSORED LINKS
> YAHOO! GROUPS LINKS
Service.
> Yahoo! Personals
