4 messages2005-12-10 12:52 UTCthrough 2005-12-11 02:58 UTC
RE: Through Hull Adventure!
Alfred Poor2005-12-10 12:52 UTC
Scott wrote:
>Here is an Idea you can mount the hull sounder in a water box
>with distilled water the lo freq energy will transmit thru the
>hull via the water.
We chose to use mineral oil instead of water. No critter growth or bad
smells. And presumably will be easier to change out the transducer than if
we had mounted it to the hull with a gob of caulk, as some have done.
Alfred Poor
1969 Cal 29 #132, "Pentaquod"
Re: [Cal_Boats] RE: Through Hull Adventure!
Michael Kennedy2005-12-10 16:42 UTC
> >hull via the water.
> than if
I had a depth sounder transducer in mineral oil in the Cal 34. It
worked fine although it was not a sophisticated "fish finer" type. It
was in a box glassed to the hull in the head, as I recall.
MIke Kennedy
COnquest Cal 40 ## 96
> Alfred Poor
> SPONSORED LINKS
> Boating sailing Sailing boat Sailing
> Boating
> YAHOO! GROUPS LINKS
> Visit your group "Cal_Boats" on the web.
> To unsubscribe from this group, send an email to:
> Ca… [at] yahoogroups.com
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Skipper2005-12-10 22:43 UTC
Never shirking away from having to use a grinder to undo anything, I applied
my depth transducer puck with a gently mixed bubble-free layer of epoxy. I
built a damn to contain it, wet out the puck and sat it gently in place. It
reads depths to 400-500' depending on a variety of factors that I haven't
noted and don't care about.
I've never much noticed depths below 90 to 100', which is what I would call
being "in soundings" for local conditions. I tacked inside the Red buoy
coming into the harbor under sail a couple of weeks ago.... The jump from
20' to 8' in half a boats length was a bit of a lesson in prudence. Amazing
how quickly you can tack a boat with your pride at stake.
David "DeWalt-Boy" Owen
Cal 2-29 "Mariposa"
Santa Barbara, CA
http://www.mariposasailing.com
Sent: Saturday, December 10, 2005 4:52 AM
Subject: [Cal_Boats] RE: Through Hull Adventure!
> >hull via the water.
> Alfred Poor
> Yahoo! Groups Links
scott2005-12-11 02:58 UTC
My water box had 2 tablespoons of bleach and was used for 2years no problem
till the boat was hauled and done right. So whatever you chooose silcone, mineral oil, ect it could fill in till haul out time.
Do any of you Cal owners have the Faryman A30 would to ask about prop size.
And injector pump governor rebuild or diagnose.
Thanks
Scott
>hull via the water.
I had a depth sounder transducer in mineral oil in the Cal 34. It worked fine although it was not a sophisticated "fish finer" type. It was in a box glassed to the hull in the head, as I recall.
MIke Kennedy
Alfred Poor
SPONSORED LINKS
Boating sailing Sailing boat Sailing Boating
YAHOO! GROUPS LINKS
SPONSORED LINKS
YAHOO! GROUPS LINKS
Yahoo! Shopping
Find Great Deals on Holiday Gifts at Yahoo! Shopping
