5 messages2006-01-05 02:42 UTCthrough 2006-01-06 14:54 UTC
RE: [Cal_Boats] Speed unit - Try GPS (Nick)
Husar Charlie2006-01-05 02:42 UTC
Nick, from my view the GPS does not give you the fine points of how one
"attacks" waves or modifies trim. I prefer the old Kenyons (no fancy
interfaces and a 9V battery - again, I'm a Luddite) with 2 digits after
the decimal and a very nice adjustable damping function that does not
dance the numbers around. Improvement/changes in speed are immediately
noted. Only place left to get them is a place called Miller Marine in
Florida (as far as I know). I keep buying parts there to keep the old
Kenyon alive.
Behalf Of ng… [at] comcast.net
Sent: Wednesday, January 04, 2006 7:56 PM
Subject: Re: [Cal_Boats] Speed unit - Try GPS
Hi, I hate it when I go on the other tack and it feels good, but the
knotmeter says I am going slower. Insight into this would be to suggest
you check the speed on GPS. It is speed over ground, which is more
accurate anyway, with current, waves, etc. When motoring up the St Clair
River into the mouth of Lake Huron the current down is about 6 knots,
the meter says I am going 6 and the GPS says I am going 3. Just another
reason to use GPS.
Later, Nick 'Jade' Cal 9.2
-------------- Original message --------------
Last year when "Lenochka" was hauled I replace the speed unit,
including the paddle-wheel sending unit, with new Standard
Horizon
units. (Okay, next time I'll pick a company who it NOT getting
out
of the instrumentation business.)
Now the speed unit works "intermittently" - usually not as I am
leaving the dock or for about the first 3-4 miles, then it start
working - most of the time. When I "troubleshoot" it - ie, the
sending unit out and in my hand - blowing on the paddlewheel,
the
unit works with no problem. And I keep the boat pretty clean as
well. Also - when first "splashed" after the boat job, the unit
worked without problems.
So - when I installed the new thru-hull housing, after I read
the
directions several times I kept co! ming to the part that said
"if the
housing is not being installed on the centerline of the boat,
angle
the housing slightly towards the bow of the boat to account for
the
flow of water over the hull."
I am beginning the think that I may have pointed the unit a
little
too much towards the bow and that water flow is pushing the
paddle
wheel into too much side contact/friction and that is the reason
is
does not work consistently.
Can anyone give me some validation or contradiction or other
insight?
Thanks in advance.
TomT
1982 Cal 9.2 "Lenochka" Hull #52
San Mateo, CA
SPONSORED LINKS
Boating sailing
<http://groups.yahoo.com/gads?t=ms&k=Boating+sailing&w1=Boating+sailing&
w2=Sailing+boat&w3=Sailing&w4=Boating&c=4&s=65&.sig=KgsPLsahA8AB__qRyAt_
XQ> Sailing boat
<http://groups.yahoo.com/gads?t=ms&k=Sailing+boat&w1=Boating+sailing&w2=
Sailing+boat&w3=Sailing&w4=Boating&c=4&s=65&.sig=oZUJLnrR0FEbvZ5o13Ffaw>
Sailing
<http://groups.yahoo.com/gads?t=ms&k=Sailing&w1=Boating+sailing&w2=Saili
ng+boat&w3=Sailing&w4=Boating&c=4&s=65&.sig=eGOXnwatS3x0LYN3XxVdNA>
Boating
<http://groups.yahoo.com/gads?t=ms&k=Boating&w1=Boating+sailing&w2=Saili
ng+boat&w3=Sailing&w4=Boating&c=4&s=65&.sig=yMCAyUrqzhoqLD5Ydiy-Rg>
YAHOO! GROUPS LINKS
* Visit your group "Cal_Boats
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
Re: [Cal_Boats] Speed unit - Try GPS (Nick)
Michael Kennedy2006-01-05 15:13 UTC
I bought a new SignetMarine knotmeter and haven't had much
opportunity to test it but it works so far. One point about leaving
the impeller in is that, if you have a diver who cleans the bottom,
the impeller may be getting dinged. Same holds true for haulout. In
my Cal 34, the impeller location was sideways in the keel. That
worked very well.
Mike Kennedy
Conquest Cal 40 # 96
> one "attacks" waves or modifies trim. I prefer the old Kenyons (no
> fancy interfaces and a 9V battery - again, I'm a Luddite) with 2
> digits after the decimal and a very nice adjustable damping
> function that does not dance the numbers around. Improvement/
> changes in speed are immediately noted. Only place left to get
> them is a place called Miller Marine in Florida (as far as I
> know). I keep buying parts there to keep the old Kenyon alive.
> Cheers
> Charlie
> On Behalf Of ng… [at] comcast.net
> the knotmeter says I am going slower. Insight into this would be to
> suggest you check the speed on GPS. It is speed over ground, which
> is more accurate anyway, with current, waves, etc. When motoring up
> the St Clair River into the mouth of Lake Huron the current down is
> about 6 knots, the meter says I am going 6 and the GPS says I am
> going 3. Just another reason to use GPS.
> From: "tilleytom" <ti… [at] yahoo.com>
> including the paddle-wheel sending unit, with new Standard Horizon
> units. (Okay, next time I'll pick a company who it NOT getting out
> sending unit out and in my hand - blowing on the paddlewheel, the
> So - when I installed the new thru-hull housing, after I read the
> directions several times I kept co! ming to the part that said "if the
> housing is not being installed on the centerline of the boat, angle
> the housing slightly towards the bow of the boat to account for the
> I am beginning the think that I may have pointed the unit a little
> too much towards the bow and that water flow is pushing the paddle
> wheel into too much side contact/friction and that is the reason is
> Can anyone give me some validation or contradiction or other insight?
> Thanks in advance.
> TomT
> San Mateo, CA
> SPONSORED LINKS
> Boating sailing Sailing boat Sailing
> Boating
> YAHOO! GROUPS LINKS
> Visit your group "Cal_Boats" on the web.
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Chris Campbell2006-01-05 17:01 UTC
Michael Kennedy wrote:
> In my Cal 34, the impeller location was sideways in the keel. That
> worked very well.
My other boat has an old mechanical Sumlog. The boat, a Seafarer
Polaris by Tripp, Sr., is a keel/centerboarder with very shoal draft,
and a quite flat bottom with hard bilges to give form stability.
Basically, there is no place _except_ the keel sides to mount the
impeller and have it in the water all the time, regardless of angle of
heel. So I put it in the keel side.
That keeps it in the water on a starboard tack, when the bottom of the
boat on the stbd. side is mostly out of the water, but... ah, the
"but." But the nature of keels on sailboats is that the water flow is
not uniform on both tacks--angle of attack, lift, all those little
things going on underwater. So my knotmeter/log gives a faster reading
on one tach than on the other. It's really right-on on one tack, and
too slow on the other, according to my GPS. If you want absolute
accuracy, you're probably better off moving the impeller as far from the
keel as possible (if it will stay underwater there).
On the other hand, I use the device mostly for relative-speed checks, or
to pat myself on the back for having such a speedy boat and for sailing
her so well, so a little inaccuracy ain't so bad. If necessary for
T/S/D calculations, I can add a bit to the slow-tacks speeds or
distances to compensate.
Husar Charlie2006-01-06 12:11 UTC
Same location on my CAL 25. Side of keel.
Behalf Of Michael Kennedy
Sent: Thursday, January 05, 2006 10:13 AM
Subject: Re: [Cal_Boats] Speed unit - Try GPS (Nick)
I bought a new SignetMarine knotmeter and haven't had much opportunity
to test it but it works so far. One point about leaving the impeller in
is that, if you have a diver who cleans the bottom, the impeller may be
getting dinged. Same holds true for haulout. In my Cal 34, the impeller
location was sideways in the keel. That worked very well.
Mike Kennedy
how one "attacks" waves or modifies trim. I prefer the old Kenyons (no
fancy interfaces and a 9V battery - again, I'm a Luddite) with 2 digits
after the decimal and a very nice adjustable damping function that does
not dance the numbers around. Improvement/changes in speed are
immediately noted. Only place left to get them is a place called Miller
Marine in Florida (as far as I know). I keep buying parts there to keep
[mailto:Ca… [at] yahoogroups.com] On Behalf Of ng… [at] comcast.net
suggest you check the speed on GPS. It is speed over ground, which is
more accurate anyway, with current, waves, etc. When motoring up the St
Clair River into the mouth of Lake Huron the current down is about 6
knots, the meter says I am going 6 and the GPS says I am going 3. Just
unit,
Standard Horizon
getting out
as I am
it start
ie, the
paddlewheel, the
clean as
the unit
read the
that said "if the
boat, angle
account for the
unit a little
the paddle
the reason is
other insight?
Thanks in advance.
TomT
San Mateo, CA
SPONSORED LINKS
Boating sailing
XQ> Sailing boat
Sailing
Boating
YAHOO! GROUPS LINKS
Terms of Service <http://docs.yahoo.com/info/terms/> .
YAHOO! GROUPS LINKS
Michael Kennedy2006-01-06 14:54 UTC
I wasn't racing the Cal 34 and the small variation caused by flow
phenomena was not an issue. For racing, the midline position ahead of
the keel is no doubt better. In the Choate 40, that was the location.
The Cal 40 could put one there although it's a bit awkward. Since
racing around the buoys is not in my future (such as it is) I'll
leave it where it is. That is on the port side in the head. The boat
had the old Signet switch for two impeller locations but they don't
make them anymore. It had two impellers, one for each tack. I'm
converting the stbd one to a thru-hull for the holding tank.
My suggestion for those noticing a difference on opposite tacks would
be to calibrate it with GPS. Sail one tack for a mile or two,
checking the speed and then calculate the distance/ speed on time and
GPS. Do the same on the other tack. You could do the same with other
points of sail to check for flow differences.
Fin commented that they spent a lot of time on stbd in last summer's
Transpac so the port location is not as good as midline. Still, I
think most fast sailing in Transpac will probably be on stbd so port
is a little better for the impeller. If I stiffen the hull with
carbon before going, maybe I'll get ambitious and move the impeller.
That would be the time to do it. Rog's suggestion is to grind off a
quarter inch of glass above and below the hull-keel junction and lay
up some carbon fiber to stiffen the hull. That would come close to
the impeller location. I noticed that someone had ground off a couple
of the ribs that stiffen the junction to make the water tank fit in
the bilge. That's another reason to think about reenforcing it when I
do the bottom in 2007.
Mike Kennedy
Conquest cal 40 96
> Cheers
> Charlie
> On Behalf Of Michael Kennedy
> worked very well.
> Mike Kennedy
>> Kenyons (no fancy interfaces and a 9V battery - again, I'm a
>> Luddite) with 2 digits after the decimal and a very nice
>> adjustable damping function that does not dance the numbers
>> around. Improvement/changes in speed are immediately noted. Only
>> place left to get them is a place called Miller Marine in Florida
>> Kenyon alive.
>> Cheers
>> Charlie
>> to suggest you check the speed on GPS. It is speed over ground,
>> which is more accurate anyway, with current, waves, etc. When
>> motoring up the St Clair River into the mouth of Lake Huron the
>> current down is about 6 knots, the meter says I am going 6 and the
>> GPS says I am going 3. Just another reason to use GPS.
>> the
>> Thanks in advance.
>> TomT
>> San Mateo, CA
>> SPONSORED LINKS
>> Boating
>> YAHOO! GROUPS LINKS
> YAHOO! GROUPS LINKS
