Bent Spar
Bent Spar
2 messages2006-01-08 05:51 through 2006-01-08 20:13 UTC
Bent Spar
Mark2006-01-08 05:51
The mast on my 64 cal 30 shows a slight kink of about 2 degrees. I posted a photo. The spar has patches under both spreaders and the bend starts right there. The mast has little corrosion and is stout. Is this something that needs to be corrected, replaced or is tuning it out with the shrouds good enough? Thanks for any input.
RE: [Cal_Boats] Bent Spar
Robert G. Thomas2006-01-08 20:13 UTC
Check with Steve Seal at Seal's Spars, www.seals <http://www.sealsspars.com/> spars.com/ _____ From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Mark Sent: Saturday, January 07, 2006 9:51 PM To: Ca… [at] yahoogroups.com Subject: [Cal_Boats] Bent Spar The mast on my 64 cal 30 shows a slight kink of about 2 degrees. I posted a photo. The spar has patches under both spreaders and the bend starts right there. The mast has little corrosion and is stout. Is this something that needs to be corrected, replaced or is tuning it out with the shrouds good enough? Thanks for any input. SPONSORED LINKS Boating <http://groups.yahoo.com/gads?t=ms&k=Boating+sailing&w1=Boating+sailing&w2=S ailing+boat&w3=Sailing&w4=Boating&c=4&s=65&.sig=KgsPLsahA8AB__qRyAt_XQ> sailing Sailing <http://groups.yahoo.com/gads?t=ms&k=Sailing+boat&w1=Boating+sailing&w2=Sail ing+boat&w3=Sailing&w4=Boating&c=4&s=65&.sig=oZUJLnrR0FEbvZ5o13Ffaw> boat Sailing <http://groups.yahoo.com/gads?t=ms&k=Sailing&w1=Boating+sailing&w2=Sailing+b oat&w3=Sailing&w4=Boating&c=4&s=65&.sig=eGOXnwatS3x0LYN3XxVdNA> Boating <http://groups.yahoo.com/gads?t=ms&k=Boating&w1=Boating+sailing&w2=Sailing+b oat&w3=Sailing&w4=Boating&c=4&s=65&.sig=yMCAyUrqzhoqLD5Ydiy-Rg> _____ YAHOO! GROUPS LINKS * Visit your group "Cal_Boats <http://groups.yahoo.com/group/Cal_Boats> " on the web. * To unsubscribe from this group, send an email to: Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com?subject=Unsubscribe> * Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service. _____
