RE: [Cal_Boats] Cal Database (Mark)
Husar Charlie2006-01-09 17:00 UTC
Hi, Mark. Are you getting the numbers from the imprint on the stern of
the boat (started in 1973 or 74).
A few possibilities here:
For a number of years (1968 to ??), CALs were built in both CA and NJ.
If the CAL 25s are an example, the first digit or two digits in the hull
number tell you where it was built. 7nn, 9nn, 11nn, 13nn... built in
CA. 8nn, 10nn, 12nn... built in NJ. Thus, the numbers need not be in
date sync.
Somebody made up a number. It is quite common on older boats.
CAL 29s changed models in between, and started renumbering.
Behalf Of masconsult
Sent: Monday, January 09, 2006 11:20 AM
Subject: Re: [Cal_Boats] Cal Database
Looking at the data base, which is a great start! The hull numbers and
years of the Cal 2-29 don't compute unless mfg from different locations
maybe? The one in Long Beach CA is from 1977 hull number 277, where the
pelican is 1976 hull #918.
Mark
From: Chris Campbell <mailto:cl… [at] traverse.com>
Sent: Monday, January 09, 2006 7:46 AM
Neil McBride wrote:
>In the Database portion of this web site, I've created a table
for
>members to enter the basic information about their boat. Will
give
>others in the group an idea who to direct questions, that's not
to say
>I wouldn't what the rest of you to answer.
>Hopefully I've created the table correctly so you should be
able to
>enter your own data. Let me know if it doesn't work.
Cal 20 #1220 is added.
YAHOO! GROUPS LINKS
* Visit your group "Cal_Boats
* Your use of Yahoo! Groups is subject to the Yahoo!
Terms of Service <http://docs.yahoo.com/info/terms/> .
Re: Cal Database (Mark)
Neil McBride2006-01-09 21:33
To complicate matters a little more, Cals were also build in Canada
by Calgan Marine in Vancouver. Al Nairne, a good friend of Jack
Jensen, was down in California in 1962 and discovered the Cal 20.
He fell in love with the little boat and arranged with Jack to build
it up North in Vancouver, British Columbia. Al's company was called
Calgan Marine Ltd., and they began manufacturing Cal 20s later that
year. In all Calgan Marine build about 180 Cal 20 models under
licence, They also build the Cal 25, Cal 28, and Cal 29 boats. In
addition to the Cal line, they developed their own line of
sailboats, the Crown 18, 28 and 34. Calgan Marine is no longer in
business. (info taken from Sept 2003 Cal 20 Newsletter)
Neil
Optima Cal 2-29
Victoria
- In Ca… [at] yahoogroups.com, "Husar Charlie" <husar_charlie@b...>
stern of
NJ.
the hull
in
be in
> date sync.
> Cheers
> Charlie
On
and
locations
where the
> Mark
> From: Chris Campbell <mailto:clcampbl@t...>
table
> for
Will
> give
not
> to say
> able to
> Chris Campbell
> YAHOO! GROUPS LINKS
