Rudder Lubrication on Cal2-25
Hi all,
I have a Cal2-25. The rudder was not moving smoothly and easily. I
noticed a grease fitting on the tube housing the rudder post, and
greased the fitting. Later, I was told that I should have used
lithium grease--I used standard grease. Apparently the regular grease
will emulsify with water--causing problems. Have I screwed up? The
greasing did not seem to help the rudder turn more freely.
Travis
