7 messages2006-01-22 09:42 UTCthrough 2006-01-28 02:36 UTC
RE: [Cal_Boats] Rudder Lubrication on Cal2-25 (Travis)
Husar Charlie2006-01-22 09:42 UTC
Hi, Travis. Yes, it should be lithium grease. Have you ever removed
the rudder? It builds up crap inside just like winches do. Is the boat
in the water? Is this a long standing problem, or has it gotten worse
over time? There can be several reasons for a sticky rudder. Also a
few tricks for cleaning it out.
Annapolis, MD
Many CALs
Behalf Of Travis
Sent: Saturday, January 21, 2006 11:47 PM
Subject: [Cal_Boats] Rudder Lubrication on Cal2-25
Hi all,
I have a Cal2-25. The rudder was not moving smoothly and easily. I
noticed a grease fitting on the tube housing the rudder post, and
greased the fitting. Later, I was told that I should have used lithium
grease--I used standard grease. Apparently the regular grease will
emulsify with water--causing problems. Have I screwed up? The greasing
did not seem to help the rudder turn more freely.
Travis
Yahoo! Groups Links
Re: [Cal_Boats] Rudder Lubrication on Cal2-25 (Travis)
tr… [at] sbcglobal.net2006-01-23 00:30 UTC
I bought the boat 2 1/2 years ago. The prior owner did a lot of work on the boat, but I don't know if he removed the rudder. The boat is in the water and I have not removed the rudder. I plan to pull the boat this spring for bottom paint. The problem has existed since I bought the boat and seems to be getting somewhat worse. It is stiff enough that, in light air, I don't need a "tiller tamer." I don't know anything about how rudders, shafts, bearings, etc are assembled, so I would appreciate any help.
Travis
Little Rock, Arkansas
Sent: Sunday, January 22, 2006 3:42 AM
Subject: RE: [Cal_Boats] Rudder Lubrication on Cal2-25 (Travis)
Annapolis, MD
Many CALs
-----Original Message-----
Behalf Of Travis
Hi all,
Travis
Yahoo! Groups Links
SPONSORED LINKS Boating sailing Sailing boat Sailing
Boating
YAHOO! GROUPS LINKS
a.. Visit your group "Cal_Boats" on the web.
b.. To unsubscribe from this group, send an email to:
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Who needs antifreeze when we have cheap vodka?
NYBoilermaker2006-01-25 14:26 UTC
Good Morning All,
I'm the proud new owner of a Cal 33-2 and while I was making my do
list yesterday, I noticed that the fresh water tank and icebox hoses
were winterized with antifreeze. Instead of using antifreeze, does
anyone have experience using vodka instead. How does it effect the
seals/hoses/etc.
Thank you,
JD
Cambridge, MD
Re: [Cal_Boats] Who needs antifreeze when we have cheap vodka?
Chris Campbell2006-01-25 22:07 UTC
NYBoilermaker wrote:
> Good Morning All,
> seals/hoses/etc.
JD:
If you can find out what they used, do so. I'm guessing that they used
an antifreeze made for potable water systems--it's used widely in RVs
and such. I would prefer that to vodka, which has the deficiency of
losing its alcohol via evaporation. In the early days of automobiles,
alcohol was used as an antifreeze, but the unpressurized colling systems
and warm engine operating temps made the stuff evaporate. It was a
constant chore, checking the antifreeze.
I use vodka as a compass fluid, in older compassses using alcohol and
water.
RE: [Cal_Boats] Who needs antifreeze when we have cheap vodka?
John Raxter ~~~~~_/)~~~~2006-01-25 23:47 UTC
JD, Welcome to the group..
There are a few of us here with the 33-2 (Raymond Hunt Design). I have
collected a few owners from this and other list, promising to keep everyone
in touch when problems and questions arise.
We have an 87 Cal 33, and there is another in our marina. What we have
found is that we seem to be replacing items about the same time. Jeff (the
other owner) replaced his water pump, mine quite working the following
weekend. We replaced the thru hulls on the last haul out, and was able to
show him what to look for this winter. Etc.Etc Etc.
We have not used any antifreeze since our first winter with the boat (we are
into our 6th year). Of course the winters here in NC are milder than on the
Chesapeake. After the first winter it took us about all season to flush the
odor from the tanks. Now we drain completely, water heater included, and
hope for the best. The water lines are the same material that went thru the
class action suit for home owners in the '80s. It is similar to what they
now call "pex". I honestly believe it will sustain a slight amount of
flexing in the freeze/thaw of winter.
I would recommend finding a low spot (hoses run thru the bilge to the head)
separate the lines and clear out with compressed air. Get the antifreeze
out of the tanks before it turns rank.
If you have any other questions, please feel free to contact me on or off
list. We can use our knowledge base to solve almost anything. Certainly we
will have enough input to over-engineer any problem (G).
John Raxter
S/V Erin Brook
Cal 33
Oriental NC
Of NYBoilermaker
Sent: Wednesday, January 25, 2006 9:26 AM
Subject: [Cal_Boats] Who needs antifreeze when we have cheap vodka?
Good Morning All,
I'm the proud new owner of a Cal 33-2 and while I was making my do list
yesterday, I noticed that the fresh water tank and icebox hoses were
winterized with antifreeze. Instead of using antifreeze, does anyone have
experience using vodka instead. How does it effect the seals/hoses/etc.
Thank you,
JD
Cambridge, MD
SPONSORED LINKS
Boating
<http://groups.yahoo.com/gads?t=ms&k=Boating+sailing&w1=Boating+sailing&w2=S
ailing+boat&w3=Sailing&w4=Boating&c=4&s=65&.sig=KgsPLsahA8AB__qRyAt_XQ>
sailing
Sailing
<http://groups.yahoo.com/gads?t=ms&k=Sailing+boat&w1=Boating+sailing&w2=Sail
ing+boat&w3=Sailing&w4=Boating&c=4&s=65&.sig=oZUJLnrR0FEbvZ5o13Ffaw> boat
Sailing
<http://groups.yahoo.com/gads?t=ms&k=Sailing&w1=Boating+sailing&w2=Sailing+b
oat&w3=Sailing&w4=Boating&c=4&s=65&.sig=eGOXnwatS3x0LYN3XxVdNA>
Boating
<http://groups.yahoo.com/gads?t=ms&k=Boating&w1=Boating+sailing&w2=Sailing+b
oat&w3=Sailing&w4=Boating&c=4&s=65&.sig=yMCAyUrqzhoqLD5Ydiy-Rg>
YAHOO! GROUPS LINKS
* Visit your group "Cal_Boats
* Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/> Terms of Service.
Darr LaFon2006-01-27 01:04 UTC
JD,
I agree with what John said, except that it does get colder on the Chesapeake. I keep my Cal 33-2 (1986) in Annapolis and one winter was working on replacing the fuel lines and noticed that the water in the oil catch pan under the engine had frozen.
The pink stuff is not too bad. What I do is pour some in the water tanks and then pump them dry at the start of the winter season. I have seen some folks have all sorts of challenges on the Chesapeake when their water systems "popped" during the winter and they found out about it the next spring. Vodka is an interesting idea, as long as it does not eat through the hoses.
I live in Cincinnati until 2008 and we plan to move back to the Bay area. One place may be Cambridge. Right now the boat is on the hard at Annapolis naval station. Last week they had some high winds that knocked over a few of the Navy 44s and some private boats that were in dry storage. Must have been some big gusts there.
I love the Cal 33s and have pretty much taken apart everything over the years and replaced a lot of original stuff as it wears out. There are a few idiosyncrasies, but the boat is wonderful and you should have years of fun. Where was your vessel before Cambridge?
Blue Skies,
Darr LaFon
Sent: Wednesday, January 25, 2006 6:47 PM
Subject: RE: [Cal_Boats] Who needs antifreeze when we have cheap vodka?
There are a few of us here with the 33-2 (Raymond Hunt Design). I have collected a few owners from this and other list, promising to keep everyone in touch when problems and questions arise.
We have an 87 Cal 33, and there is another in our marina. What we have found is that we seem to be replacing items about the same time. Jeff (the other owner) replaced his water pump, mine quite working the following weekend. We replaced the thru hulls on the last haul out, and was able to show him what to look for this winter. Etc.Etc Etc.
We have not used any antifreeze since our first winter with the boat (we are into our 6th year). Of course the winters here in NC are milder than on the Chesapeake. After the first winter it took us about all season to flush the odor from the tanks. Now we drain completely, water heater included, and hope for the best. The water lines are the same material that went thru the class action suit for home owners in the '80s. It is similar to what they now call "pex". I honestly believe it will sustain a slight amount of flexing in the freeze/thaw of winter.
I would recommend finding a low spot (hoses run thru the bilge to the head) separate the lines and clear out with compressed air. Get the antifreeze out of the tanks before it turns rank.
If you have any other questions, please feel free to contact me on or off list. We can use our knowledge base to solve almost anything. Certainly we will have enough input to over-engineer any problem (G).
John Raxter
S/V Erin Brook
Cal 33
Oriental NC
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of NYBoilermaker
Good Morning All,
I'm the proud new owner of a Cal 33-2 and while I was making my do list yesterday, I noticed that the fresh water tank and icebox hoses were winterized with antifreeze. Instead of using antifreeze, does anyone have experience using vodka instead. How does it effect the seals/hoses/etc.
Thank you,
JD
Cambridge, MD
Boating
YAHOO! GROUPS LINKS
NYBoilermaker2006-01-28 02:36 UTC
Hiya Darr,
Great to hear from you.
Yes, for the last couple days, it's been blowin'
like stink. Today was nice; sunny, light winds and about 45 degrees.
The boat's been here in Cambridge for two years
and before that was in TX. A couple I know bought
the boat, cruised Maine last summer and loved the
lifestyle so much that on the way home they
bought a Caliber 38 and are moving aboard full
time this summer. The CAL didn't have the storage or range which they needed.
Those were new 44s weren't they? Ouch.
Jonathan Deus "JD"
AIM:jdeus
yahoo:jonathandeus
msn:nyboilermaker
At 20:04 1/26/2006, you wrote:
>JD,
>Blue Skies,
>Darr LaFon
>From: <mailto:jr… [at] triad.rr.com>John Raxter ~~~~~_/)~~~~
>To: <mailto:Ca… [at] yahoogroups.com>Ca… [at] yahoogroups.com
>owners in the 80s. It is similar to what they
>now call pex. I honestly believe it will
>John Raxter
>S/V Erin Brook
>Cal 33
>Oriental NC
>Good Morning All,
>Thank you,
>JD
>Cambridge, MD
>SPONSORED LINKS
><http://groups.yahoo.com/gads?t=ms&k=Boating+sailing&w1=Boating+sailing&w2=Sailing+boat&w3=Sailing&w4=Boating&c=4&s=65&.sig=KgsPLsahA8AB__qRyAt_XQ>Boating
>sailing
><http://groups.yahoo.com/gads?t=ms&k=Sailing+boat&w1=Boating+sailing&w2=Sailing+boat&w3=Sailing&w4=Boating&c=4&s=65&.sig=oZUJLnrR0FEbvZ5o13Ffaw>Sailing
>boat
><http://groups.yahoo.com/gads?t=ms&k=Sailing&w1=Boating+sailing&w2=Sailing+boat&w3=Sailing&w4=Boating&c=4&s=65&.sig=eGOXnwatS3x0LYN3XxVdNA>Sailing
><http://groups.yahoo.com/gads?t=ms&k=Boating&w1=Boating+sailing&w2=Sailing+boat&w3=Sailing&w4=Boating&c=4&s=65&.sig=yMCAyUrqzhoqLD5Ydiy-Rg>Boating
>YAHOO! GROUPS LINKS
> * Visit your group
> "<http://groups.yahoo.com/group/Cal_Boats>Cal_Boats" on the web.
> <mailto:Ca… [at] yahoogroups.com?subject=Unsubscribe>Ca… [at] yahoogroups.com
> the <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service.
