4 messages2006-01-29 01:04 UTCthrough 2006-01-29 16:47 UTC
Prop Change Out
ng… [at] comcast.net2006-01-29 01:04 UTC
Hi,
I have located a used folding Martec prop for my boat (Cal 9.2)
Yea ! ! ! I don't have to now spend $650 only $200
Wondering what to watch out for in installing from a fixed prop. Does the end of the shaft have to be changed in anyway? Any holes to be drilled? Appears that a folding prop hangs lower because it extends out of the end of the shaft, where a fixed is a few inches inside from the end of the shaft. Probably does not matter, except the blade diament can be larger.
Also, most important, what is the difference in the pitch number. When I asked Martec which would be best for my boat they said 13 x 10 x 1. The one I am considering is a 9 not 10 pitch. What performance will be compromised ?
Any help from the cal list is welcome as always.
Late, Nick "Jade" Cal 9.2
Re: [Cal_Boats] Prop Change Out
scott2006-01-29 01:50 UTC
Nick
I just changed my prop on a Cal 2-29 from a 3 blade 12-12 pitch this was good only
if I had more power the new Martec 15-10pitch works great.The first ideal choice should 14-13pitch.
Martec is very helpful about the size pitch stuff.
The Martec will fit your 1" shaft with standard keyway
Also check the free play in the blades Martec sells a shim to correct for play
this what I have been told.
Go to martec web site they have full directions and they are very helpful.
Your size and pitch numbers could to far from the ideal match but try it guess
and the beauty about these you can get new blades for the hub.
My 10 cents
Scott 1975 2-29
ng… [at] comcast.net wrote:
Hi,
YAHOO! GROUPS LINKS
Visit your group "Cal_Boats" on the web.
To unsubscribe from this group, send an email to:
Ca… [at] yahoogroups.com
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Yahoo! Autos. Looking for a sweet ride? Get pricing, reviews, & more on new and used cars.
Michael Kennedy2006-01-29 04:38 UTC
On Jan 28, 2006, at 5:04 PM, ng… [at] comcast.net wrote:
> Hi,
Make sure it is a genuine Martec. There are imitations, like Michigan
wheel.
The nut is in the hub of the Martec.
Slower under power.
Mike Kennedy
Conquest Cal 40 # 96
> YAHOO! GROUPS LINKS
RE: [Cal_Boats] Prop Change Out
Frank and Wendy2006-01-29 16:47 UTC
Hi Nick,
I am in the same situation. I am switching from a 14-10 2 bladed fixed prop
to a 16-9 martec. (got it on e-bay for $50--baby! not too many people
bidding on a left turning prop for a volvo diesel).
Any how I spoke to both Martec and the local prop shop. Going from a 10
pitch to a 9 pitch should be no big deal, but you may have to rev the engine
faster for the same speed on the water. This is oK as long as you are not
over-reving. You should have an optimal RPM target for your particular
engine. Also every inch of diameter is roughly equivalent to 1 degree in
pitch. In my case the motor may run slower for the same speed as it will
develop more thrust per rpm (up 2 in diameter and down 1 in pitch)
When I spoke to Martec they recommended several combinations of pitch and
diameter for my cal31 with a 13hp volvo. If I recall they suggested a 14-12
or a 15-10.
You should have at least 15% of the diameter of the prop in clearance
between prop and hull.
Hopefully you won't have to shorten the shaft to account for the extra
length of the folded prop. If this were the case the shaft would need
machining. Probably you would shorten the engine end of it.
Probably it would be wise to change your cutless bearing while you are at
it.
Hope this helps
Frank
-----Original Message-----
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com]On
Behalf Of ng… [at] comcast.net
Sent: Saturday, January 28, 2006 8:05 PM
To: Cal List
Subject: [Cal_Boats] Prop Change Out
Hi,
YAHOO! GROUPS LINKS
a.. Visit your group "Cal_Boats" on the web.
b.. To unsubscribe from this group, send an email to:
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
