Re: [Cal_Boats] West System
As long as the pumps are fairly new, it is not possible to mix them up,
WEST SYSTEM uses a smaller cap on the 207 and 209 hardener cans and the
pump for those hardeners will not fit the 205 and 206 cans. If you have
older pumps I'm not sure if that is the case.
Rod Johnson
"NODROG"
1970 CAL 21 #285
On Fri, 3 Feb 2006 17:15:23 -0500 "Lost Sailor"
<lo… [at] digitalsail.com> writes:
> Hi Scott and the rest of the groupsters,
> > Check your pumps. Make sure they are clear of obstructions inside,
> make
> sure they don't lose prime, and make sure they are returning to the
> top
> completely after each pump, and then check with measuring cups. And
> of
> course, don't mix up the two hardener pumps. 205 and 206 are 5:1
> while 207
> and 209 are 3:1.
> Peaceski
> Mattski
> "Shakedown"
> '65 Cal25 #104
