20 messages2006-03-09 22:45 through 2006-03-16 00:05 UTC
Stainless handrails for Cal34
camaflge2006-03-09 22:45
I want to replace my teak handrails on my Cal 34 with stainless.
Anyone know a place in Southern Cal that makes stainless handrails?
Re: [Cal_Boats] Stainless handrails for Cal34
Fin Beven2006-03-09 23:02 UTC
Riley Marine (Wilmington/Long Beach area) does nice work: (562) 435-5233
Fin Beven
Cal-40 #24
Radiant
San Pedro, CA
Sent: Thursday, March 09, 2006 2:45 PM
Subject: [Cal_Boats] Stainless handrails for Cal34
Yahoo! Groups Links
Michael Kennedy2006-03-09 23:12 UTC
Railmakers in Costa Mesa. They made my stanchions and I plan to have
steel grab rails made for the 40. They are on 18th (I think). I can
find it but not give directions. They are hard to find as there is
only a driveway to the street and the plant is away from the street.
Mike Kennedy
Conquest Cal 40 # 96
> SPONSORED LINKS
> Boating sailing Sailing boat Sailing
> Boating
> YAHOO! GROUPS LINKS
> Visit your group "Cal_Boats" on the web.
> To unsubscribe from this group, send an email to:
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
glen fromm2006-03-09 23:16 UTC
We replaced the teak with stainless our selves, it was very easy. We used Sea dog fittings (high profile ones, not the low ones) and two lengths of 1" s/s tubing we ordered from Boat US. The high tech bending method we used was growing right next to the boat, two trees that were growing close to each other! We put the tubing between them and gave a little push and checked it against the deck until we had it right. After over drilling from the inside and filling the holes with epoxy, we through bolted the mounts in place with fender washers on the inside. Check out the photo that is named " New hardware" in the album below.
http://pg.photos.yahoo.com/ph/cal34moonshadow/album?.dir=/a90f&.view=t<about:blank>
Sent: Thursday, March 09, 2006 5:45 PM
Yahoo! Groups Links
Ellwood Jones2006-03-10 13:19 UTC
San Diego Marine Exchange sells them in different lengths.
Woody Jones
Re: Cal 34 Mast Step
Dean Prophet2006-03-10 15:39 UTC
Hi Group,
I have a Cal 34, Hull #9. The base of my mast appears to be moving a bit. Is the base just sitting on that plate and staying in place with tension from the shrouds and stays, or does the plate have some kind of shoulder to it that the perimeter of the mast base sits on?
Any info would help.
Dean
Ventura
YAHOO! GROUPS LINKS
Re: [Cal_Boats] Re: Cal 34 Mast Step
Fred Haas2006-03-10 16:19 UTC
Dean,
I can't speak directly to your 34, but I have recently had the mast off
Nemesis. Its deck plate does have a shoulder about an inch tall, with a
strengthening grid a couple of inches higher. That is through bolted
through the deck and the top flange on the compression post. Any
significant movement would destroy the deck and pull the post out of
line. I cant imagine what it would take to cause that.
Fred Haas
3-30 Nemesis
Tacoma
On Mar 10, 2006, at 7:39 AM, Dean Prophet wrote:
>> Hi Group,
>> Thanks,
>> Dean
>> Ventura
> SPONSORED LINKS
> Boating sailing
> Sailing boat
> Sailing
> Boating
> YAHOO! GROUPS LINKS
> ▪ Visit your group "Cal_Boats" on the web.
> ▪ To unsubscribe from this group, send an email to:
> ▪ Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service.
Skipper2006-03-10 16:51 UTC
Dean,
The base should have a series of vertical plates that make a shoulder to center the mast and hold it from moving laterally. It shouldn't be able to move enough to notice.
Do you mean that the mast base is moving as well, or is the base staying put and the mast moving?
If the base is solid and the mast is moving, is there any deformation on the base of the mast itself? This is a common place for corrosion to eat completely through the base of the mast. This could be very serious.
You can pull the stick and have a welder attach a partial or full collar to rebuild the bottom of the mast. I've heard of guys cutting a couple of inches off, but then you need new standing rigging and give up a bit of sail area.
David Wilkie Owen
Cal 2-29 "Mariposa"
Santa Barbara, CA
http://www.mariposasailing.com
Sent: Friday, March 10, 2006 7:39 AM
Subject: [Cal_Boats] Re: Cal 34 Mast Step
Hi Group,
Dean
Ventura
SPONSORED LINKS Boating sailing Sailing boat Sailing
Boating
YAHOO! GROUPS LINKS
a.. Visit your group "Cal_Boats" on the web.
b.. To unsubscribe from this group, send an email to:
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Fin Beven2006-03-10 17:58 UTC
Sent: Friday, March 10, 2006 8:19 AM
Subject: Re: [Cal_Boats] Re: Cal 34 Mast Step
Dean,
I can't speak directly to your 34, but I have recently had the mast off Nemesis. Its deck plate does have a shoulder about an inch tall, with a strengthening grid a couple of inches higher. That is through bolted through the deck and the top flange on the compression post. Any significant movement would destroy the deck and pull the post out of line. I cant imagine what it would take to cause that.
Fred Haas
3-30 Nemesis
Tacoma
Hi Group,
Dean
Ventura
SPONSORED LINKS
Boating sailing
Sailing boat
Sailing
Boating
YAHOO! GROUPS LINKS
? Visit your group "Cal_Boats" on the web.
? To unsubscribe from this group, send an email to:
? Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Swedish2006-03-11 00:35 UTC
Does not sound good for the base of the mast to move at all.
My deck plate has a 1" + collar with a crossing grid. However, when I inspected the peice a few years back when I got the boat one of the sections had a 2+" crack at the base of the plate. I had it welded back together, but I could see that if it went on for a while, the grid system might fail.
My boat is pulled and I check this each year...no problems to date.
Greg
1977 Cal 34 III
#52 (For Sale)
Sent: Friday, March 10, 2006 12:58 PM
Dean,
Fred Haas
3-30 Nemesis
Tacoma
Hi Group,
Dean
Ventura
SPONSORED LINKS
Boating sailing
Sailing boat
Sailing
Boating
YAHOO! GROUPS LINKS
Boating
YAHOO! GROUPS LINKS
Blister Repair Live Web Q&A?
Rog Jones2006-03-14 02:31 UTC
Hi gang -
Is anyone interested in a blister repair?
If you are, I would host a chat room seminar on blister repair, complete
with various downloads (such as materials, equipment, list of suppliers,
etc.) and photos.
We could first go with diagnosis, then with repair.
Then you can ask questions and we can all discuss.
We may as well use the features that Yahoo gives us for this kind of thing.
If it works out, I am going to ask people who have done engine replacements,
wiring replacements, etc., to do the same for us Cal folks.
Let me know and I'll get everything together and give it away to you so that
you can become your own expert. And as you gain more knowledge, you can come
back and share it with the group.
Take care.
\Rog
Cal 29+ #1
Swiss Navy
Cal 2-30 #77
St. Lori's Comet
Of Skipper
Sent: Friday, March 10, 2006 8:51 AM
Dean,
area.
David Wilkie Owen
Cal 2-29 "Mariposa"
Santa Barbara, CA
Hi Group,
Dean
Ventura
SPONSORED LINKS
Boating
<http://groups.yahoo.com/gads?t=ms&k=Boating+sailing&w1=Boating+sailing&w2=S
ailing+boat&w3=Sailing&w4=Boating&c=4&s=65&.sig=KgsPLsahA8AB__qRyAt_XQ>
sailing
Sailing
<http://groups.yahoo.com/gads?t=ms&k=Sailing+boat&w1=Boating+sailing&w2=Sail
ing+boat&w3=Sailing&w4=Boating&c=4&s=65&.sig=oZUJLnrR0FEbvZ5o13Ffaw> boat
Sailing
<http://groups.yahoo.com/gads?t=ms&k=Sailing&w1=Boating+sailing&w2=Sailing+b
oat&w3=Sailing&w4=Boating&c=4&s=65&.sig=eGOXnwatS3x0LYN3XxVdNA>
Boating
<http://groups.yahoo.com/gads?t=ms&k=Boating&w1=Boating+sailing&w2=Sailing+b
oat&w3=Sailing&w4=Boating&c=4&s=65&.sig=yMCAyUrqzhoqLD5Ydiy-Rg>
YAHOO! GROUPS LINKS
* Visit your group "Cal_Boats
* Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/> Terms of Service.
Re: [Cal_Boats] Blister Repair Live Web Q&A? (Rog)
Eric Jackson2006-03-14 05:14 UTC
that would be great.. I would really like to learn that whole
process. I am going to have to pull my boat in the next year or so,
and I would love to have the information, to be able to do this on my
own. thanks rog, sign me up.
Eric Jackson
BAREFOOT
1971 CAL 29 #316
Channel Islands CA
On Mar 13, 2006, at 6:31 PM, Rog Jones wrote:
> Hi gang –
> complete with various downloads (such as materials, equipment, list
> of suppliers, etc.) and photos.
> of thing. If it works out, I am going to ask people who have done
> engine replacements, wiring replacements, etc., to do the same for
> us Cal folks.
> Let me know and I’ll get everything together and give it away to
> you so that you can become your own expert. And as you gain more
> knowledge, you can come back and share it with the group.
> Take care.
> \Rog
> Cal 29+ #1
> Swiss Navy
> Cal 2-30 #77
> St. Lori's Comet
RE: [Cal_Boats] Blister Repair Live Web Q&A? (Rog)
Fred Haas2006-03-14 17:18 UTC
I'd sure be interested. I stick my head in the sand whenever blisters are
mentioned, but I'd love to know more!
Fred Haas
3-30 Nemesis
Tacoma
Of Eric Jackson
Sent: Monday, March 13, 2006 9:14 PM
Subject: Re: [Cal_Boats] Blister Repair Live Web Q&A? (Rog)
that would be great.. I would really like to learn that whole process. I am
going to have to pull my boat in the next year or so, and I would love to
have the information, to be able to do this on my own. thanks rog, sign me
up.
Eric Jackson
BAREFOOT
1971 CAL 29 #316
Channel Islands CA
Hi gang -
etc.) and photos.
Take care.
\Rog
Cal 29+ #1
Swiss Navy
Cal 2-30 #77
St. Lori's Comet
YAHOO! GROUPS LINKS
Tom Tilley2006-03-14 22:01 UTC
Rog -
Even though I don't have blisters on my Cal 9.2 (knock wood) I'm definitely interested in learning about the effective repair of same.
Count me in.
TomT
1982 Cal 9.2 "Lenochka"
San Mateo, CA
Rog Jones <ro… [at] nvsailing.org> wrote:
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Hi gang
If you are, I would host a chat room seminar on blister repair, complete with various downloads (such as materials, equipment, list of suppliers, etc.) and photos.
We may as well use the features that Yahoo gives us for this kind of thing. If it works out, I am going to ask people who have done engine replacements, wiring replacements, etc., to do the same for us Cal folks.
Let me know and Ill get everything together and give it away to you so that you can become your own expert. And as you gain more knowledge, you can come back and share it with the group.
Take care.
\Rog
Cal 29+ #1
Swiss Navy
Cal 2-30 #77
St. Lori's Comet
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Skipper
Dean,
David Wilkie Owen
Cal 2-29 "Mariposa"
Santa Barbara, CA
Hi Group,
Dean
Ventura
SPONSORED LINKS
Boating sailing Sailing boat Sailing Boating
YAHOO! GROUPS LINKS
Tom Tilley
1982 Cal 9.2 "Lenochka" Hull #53
San Mateo, CA
Relax. Yahoo! Mail virus scanning helps detect nasty viruses!
Terrence Spencer2006-03-15 03:50 UTC
I am interested right now! Of course I am smack in the middle of the whole
process. But every boat project is a new learning experience for me.
When I hauled in late October, I counted 75 blisters, none bigger than a
quarter. After reading, consulting, and searching the web, I concluded that
everybody has an opinion on what to do. Being somewhat conservative (with a
small c) in nature, I decided to do a complete peel and am glad I did. My
wife gave me a bad time when I paid a guy $900 for a half a day¹s work to
peel my bottom, but it was worth it. There is no way I could have ground
out and filled that many blisters and ended up with a fair bottom.
So after drying for 3+ months, this weekend is the rolling and tipping
party. If any of you with expertise (or even with a strong, steady arm) are
near the Tacoma area and want to experience the joy of putting on epoxy and
barrier coats, I will be at Hylebos boatyard Friday, Saturday, and Sunday to
welcome you.
Kidding aside, I have some trepidation about getting these coatings on
without sags and runs. I was advised by the fellow who peeled my bottom, to
do several coats (4-5 mils) of West Systems and then follow it with about
the same thickness of Interlux Barrier Coat. I f anyone on the list has
done this before, I would appreciate advice on how to get these coats on
thick enough to thoroughly wet it out and thin enough to avoid runs and sag
when the epoxy kicks.
Thanks in advance for any good suggestions.
Terry Spencer
Tacoma, WA
Cal 2-29
Formerly ³Kailoa III² soon to be ³Capriccio² (following John Vigors naming
ceremony and the consumption of large quantities of bubbly)
Organization: Sierra Nevada Community Sailing
Reply-To: Ca… [at] yahoogroups.com
Date: Mon, 13 Mar 2006 18:31:29 -0800
Subject: [Cal_Boats] Blister Repair Live Web Q&A?
Hi gang
etc.) and photos.
Let me know and I¹ll get everything together and give it away to you so that
Take care.
\Rog
Cal 29+ #1
Swiss Navy
Cal 2-30 #77
St. Lori's Comet
Of Skipper
Dean,
area.
David Wilkie Owen
Cal 2-29 "Mariposa"
Santa Barbara, CA
> From: Dean Prophet <mailto:sa… [at] sbcglobal.net>
>> Hi Group,
>> Thanks,
>> Dean
>> Ventura
> SPONSORED LINKS
> Boating sailing
> <http://groups.yahoo.com/gads?t=ms&k=Boating+sailing&w1=Boating+sailing&w2=Sai
> Sailing boat
> <http://groups.yahoo.com/gads?t=ms&k=Sailing+boat&w1=Boating+sailing&w2=Sailin
> g+boat&w3=Sailing&w4=Boating&c=4&s=65&.sig=oZUJLnrR0FEbvZ5o13Ffaw> Sailing
> <http://groups.yahoo.com/gads?t=ms&k=Sailing&w1=Boating+sailing&w2=Sailing+boa
> Boating
> <http://groups.yahoo.com/gads?t=ms&k=Boating&w1=Boating+sailing&w2=Sailing+boa
> YAHOO! GROUPS LINKS
> * Visit your group "Cal_Boats <http://groups.yahoo.com/group/Cal_Boats> " on
> the web.
> * Ca… [at] yahoogroups.com
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
> <http://docs.yahoo.com/info/terms/> .
Re: Blister Repair Live Web Q&A?
michaelkennedy052006-03-15 18:33
I'd be very interested in some blister repair expertise given my
interest in not one but 2 old fiberglass boats.
Mike Kennedy Jr.
Cal 40 #96
Santana 22 # 146
--- In Ca… [at] yahoogroups.com, "Rog Jones" <rog@...> wrote:
> Hi gang -
complete
suppliers,
> etc.) and photos.
of thing.
replacements,
you so that
can come
> Take care.
> \Rog
> Cal 29+ #1
> Swiss Navy
> Cal 2-30 #77
> St. Lori's Comet
> _____
On Behalf
> Of Skipper
> Dean,
shoulder to
able to
staying put
deformation on the
eat
serious.
collar to
couple of
bit of sail
> area.
> David Wilkie Owen
> _________________
> Cal 2-29 "Mariposa"
> Santa Barbara, CA
> From: Dean <mailto:sailingdean@...> Prophet
> Hi Group,
a bit.
tension
shoulder to
> Thanks,
> Dean
> Ventura
> SPONSORED LINKS
> Boating
> sailing
> Sailing
boat
> Sailing
> Boating
> _____
> YAHOO! GROUPS LINKS
> _____
Re: [Cal_Boats] Re: Blister Repair Live Web Q&A?
Chris Collins2006-03-15 18:38 UTC
Me too!
Chris
Chris Collins
'63 Cal 20 #323
"don't know yet"
Nashville, TN
> Mike Kennedy Jr.
> Cal 40 #96
> Santana 22 # 146
>> Hi gang -
> complete
> suppliers,
>> etc.) and photos.
> of thing.
> replacements,
> you so that
> can come
>> Take care.
>> \Rog
>> Cal 29+ #1
>> Swiss Navy
>> Cal 2-30 #77
>> St. Lori's Comet
>> _____
> On Behalf
>> Of Skipper
>> Dean,
> shoulder to
> able to
> staying put
> deformation on the
> eat
> serious.
> collar to
> couple of
> bit of sail
>> area.
>> David Wilkie Owen
>> _________________
>> Cal 2-29 "Mariposa"
>> Santa Barbara, CA
>> Hi Group,
> a bit.
> tension
> shoulder to
>> Thanks,
>> Dean
>> Ventura
>> SPONSORED LINKS
>> Boating
>> sailing
>> Sailing
> boat
>> Sailing
>> Boating
>> _____
>> YAHOO! GROUPS LINKS
>> _____
> Yahoo! Groups Links
Fred Haas2006-03-15 20:55 UTC
Terry,
If I can get my act together, I'll stop by the Hylebos Marina on Saturday
to inspect your project. I've seen Kailoa III on Commencement Bay a couple
of times in the last year or so. When did you buy her? I have no experience
with that type of repair, but am always willing to watch other people work.
Fred Haas
3-30 Nemesis
Tacoma
Of Terrence Spencer
Sent: Tuesday, March 14, 2006 7:50 PM
wife gave me a bad time when I paid a guy $900 for a half a day's work to
welcome you.
Terry Spencer
Tacoma, WA
Cal 2-29
Formerly "Kailoa III" soon to be "Capriccio" (following John Vigors naming
Hi gang -
etc.) and photos.
Take care.
\Rog
Cal 29+ #1
Swiss Navy
Cal 2-30 #77
St. Lori's Comet
<mailto:Ca… [at] yahoogroups.com%5d> On Behalf Of Skipper
Dean,
area.
David Wilkie Owen
Cal 2-29 "Mariposa"
Santa Barbara, CA
Hi Group,
Dean
Ventura
SPONSORED LINKS
Boating sailing
Sailing boat
Sailing
Boating
YAHOO! GROUPS LINKS
Service <http://docs.yahoo.com/info/terms/>
SPONSORED LINKS
Boating
sailing
Sailing
Sailing
Boating
YAHOO! GROUPS LINKS
Ellwood Jones2006-03-15 23:46 UTC
Me three!!
Woody Jones
Cal-34 #36
San Diego
> Me too!
> Chris
> Chris Collins
> '63 Cal 20 #323
> "don't know yet"
> Nashville, TN
>> Mike Kennedy Jr.
>> Cal 40 #96
>> Santana 22 # 146
>>> Hi gang -
>> complete
>> suppliers,
>>> etc.) and photos.
>> of thing.
>> replacements,
>> you so that
>> can come
>>> Take care.
>>> \Rog
>>> Cal 29+ #1
>>> Swiss Navy
>>> Cal 2-30 #77
>>> St. Lori's Comet
>>> _____
>> On Behalf
>>> Of Skipper
>>> Dean,
>> shoulder to
>> able to
>> staying put
>> deformation on the
>> eat
>> serious.
>> collar to
>> couple of
>> bit of sail
>>> area.
>>> David Wilkie Owen
>>> _________________
>>> Cal 2-29 "Mariposa"
>>> Santa Barbara, CA
>>> Hi Group,
>> a bit.
>> tension
>> shoulder to
>>> Thanks,
>>> Dean
>>> Ventura
>>> SPONSORED LINKS
>>> Boating
>>> sailing
>>> Sailing
>> boat
>>> Sailing
>>> Boating
>>> _____
>>> YAHOO! GROUPS LINKS
>>> _____
>> Yahoo! Groups Links
> Yahoo! Groups Links
RE: [Cal_Boats] Re: Blister Repair Live Web Q&A? (all members)
Rog Jones2006-03-16 00:05 UTC
Okay, I'll start getting the resources together and up on one of my .ftp
sites so you can download.
Let's begin thinking about the end of April. I am kind of up to my navel
with work right now. Will try to do two chat room sessions (because of time
differences) so that you right coast folks don't have to be tired the next
day.
We'll cover prevention, diagnosis, repair alternatives (theory and actual
practice), drying, removal of damaged material, peeling, laminate
replacement, filling and fillers, fairing, a little bit of chemistry - you
need to know this if you are going to avoid doing it again sometime - resin,
reinforcement and barrier coat selection, paint and bottom paint and
application methods.
Later.
\Rog
Cal 29+ #1
Swiss Navy
Cal 2-30 #77
St. Lori's Comet
