4 messages2006-04-27 02:42 UTCthrough 2006-04-27 17:46
RE: [Cal_Boats] mast wiring
Husar Charlie2006-04-27 02:42 UTC
Mike, the things you are doing with the boat can only be described as
"amazing". Best of luck.
Behalf Of mtkennedy1
Sent: Wednesday, April 26, 2006 3:29 PM
Subject: [Cal_Boats] mast wiring
There is a discussion going on in Sailnet about mast wiring and how to
connect the wire harness at the step. I can't post to Sailnet from work
so I thought I would add something here. When I rewired the Cal 40, I
ran negative commons and hot wires to common terminals. The terminal
screws can be connected by bridges or can be separated for each circuit.
I have such a set of connectors in the head under the deck. The mast
harness comes out of an opening below deck but the same principle could
be used with a deck stepped mast, taking care that the water in the mast
was drained and not allowed to infiltrate the sandwich structure of the
deck. The harness goes into the head compartment and the circuits are
attached there. I have a lengthy set of connectors since the wiring for
the bow port-side lights is also there.
The mast lights are connected by wires to the block of connectors. The
negative side goes to a gang block connected to a single heavy gauge
negative going back to the panel. The light circuits are all separate
and, when it is time to pull the mast again, the wires are detached on
the mast side. All the wiring from the panel and breakers stays as is. I
know this is basic but maybe it will help someone with the project.
I also have the "brain" of the electronic instruments there, as well. It
will all be covered with a thin bit of mahogany plywood when I am
finally finished.
Latest project is finishing the pressure water and the holding tank. The
cruising dodger is close to being finished. Next step, Catalina! That
will probably be July, though.
Mike Kennedy
Conquest Cal 40 # 96
Yahoo! Groups Links
Re: [Cal_Boats] mast wiring
Michael Kennedy2006-04-27 11:59 UTC
Well, there are a few boats, like Dancing Bear in the last two
month's Cruising World, that are finished. I'm envious because this
is now in the second year. It's been a learning experience. If I ever
buy another Cal 40 in poor condition I'll know exactly how to do it.
That was a small joke.
I copied a lot of Fin's work.
Mike Kennedy
> Cheers
> Charlie
> -----Original Message-----
snipped
Skipper2006-04-27 15:59 UTC
Mike,
You have a photo album somewhere on the net, as I recall. Any updates to
it? I can't find the link. I have enjoyed watching you work on Conquest.
Wilkie
Sent: Thursday, April 27, 2006 4:59 AM
Subject: Re: [Cal_Boats] mast wiring
> Mike Kennedy
>> Cheers
>> Charlie
> snipped
> Yahoo! Groups Links
Re: mast wiring
mtkennedy12006-04-27 17:46
--- In Ca… [at] yahoogroups.com, "Skipper" <skipper@...> wrote:
> Mike,
This may work:
http://pg.photos.yahoo.com/ph/mtkennedy1/album
You can also find it in Yahoo with my user name.
Mike Kennedy
I'll add some Cal 40 pics if they show up in the iPhoto revamp.
> Wilkie
> ----- Original Message -----
> From: "Michael Kennedy" <mtkennedy1@...>
> > Mike Kennedy
