6 messages2006-04-26 19:28 through 2006-05-01 14:07 UTC
mast wiring
mtkennedy12006-04-26 19:28
There is a discussion going on in Sailnet about mast wiring and how to connect the wire
harness at the step. I can't post to Sailnet from work so I thought I would add something
here. When I rewired the Cal 40, I ran negative commons and hot wires to common
terminals. The terminal screws can be connected by bridges or can be separated for each
circuit. I have such a set of connectors in the head under the deck. The mast harness
comes out of an opening below deck but the same principle could be used with a deck
stepped mast, taking care that the water in the mast was drained and not allowed to
infiltrate the sandwich structure of the deck. The harness goes into the head compartment
and the circuits are attached there. I have a lengthy set of connectors since the wiring for
the bow port-side lights is also there.
The mast lights are connected by wires to the block of connectors. The negative side goes
to a gang block connected to a single heavy gauge negative going back to the panel. The
light circuits are all separate and, when it is time to pull the mast again, the wires are
detached on the mast side. All the wiring from the panel and breakers stays as is. I know
this is basic but maybe it will help someone with the project.
I also have the "brain" of the electronic instruments there, as well. It will all be covered
with a thin bit of mahogany plywood when I am finally finished.
Latest project is finishing the pressure water and the holding tank. The cruising dodger is
close to being finished. Next step, Catalina! That will probably be July, though.
Mike Kennedy
Conquest Cal 40 # 96
Re: [Cal_Boats] (Mike Kennedy) pressure water (was mast wiring)
Duane Knize2006-04-27 00:05 UTC
Mike,
Here's a suggestion on pressure water....It has merit if you have a
water heater and limited tankage.
I ran the hot water as a loop with replacing the couplers at each
faucet with tee's.
The circuit runs in half inch tubing from the heater outlet to the
galley, then to the head sink, and to the shower, then back aft and
through a small sureflo 1g/min pump (aft run uses 3/8 inch tubing to
match the pump barbs) and to a tee in the water heater inlet. The
pump is wired to a toggle at the electrical panel.
We use the pump to circulate the water on demand to eliminate waste
waiting for the hot water to reach the faucets. There is about 1
gallon in the tube between the heater and the galley -- run the pump
1 minute --; there is about two more gallons in the run to the head
-- run the pump 3 minutes.
I inserted a check valve inlet of the heater inlet so the water won't
move backwards around the loop when the faucets are turned on. There
is also a gate valve at the heater inlet to bleed the air from the system.
The cold water circuits are unaltered.
This really works.
Regards,
Duane
Duane & Lynn Knize
Marlyn, 1978 Cal 2-39, #18
Berthed: Emeryville, CA
>to connect the wire
>wires to common
>separated for each
>The mast harness
>used with a deck
>not allowed to
>July, though.
>Mike Kennedy
>YAHOO! GROUPS LINKS
> * Visit your group
> "<http://groups.yahoo.com/group/Cal_Boats>Cal_Boats" on the web.
> * To unsubscribe from this group, send an email to:
> <mailto:Ca… [at] yahoogroups.com?subject=Unsubscribe>Ca… [at] yahoogroups.com
> * Your use of Yahoo! Groups is subject to the
> <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service.
Duane & Lynn Knize
Michael Kennedy2006-04-27 11:51 UTC
Good suggestions. I'll save the message. My son will have a fit if he
reads that I'm thinking of a water heater and shower so we'll keep
this just between us and the group.
Mike Kennedy
On Apr 26, 2006, at 5:05 PM, Duane Knize wrote:
> Mike,
> faucet with tee's.
> to match the pump barbs) and to a tee in the water heater inlet.
> The pump is wired to a toggle at the electrical panel.
> pump 1 minute --; there is about two more gallons in the run to the
> head -- run the pump 3 minutes.
> won't move backwards around the loop when the faucets are turned
> on. There is also a gate valve at the heater inlet to bleed the
> This really works.
> Regards,
> Duane
> Duane & Lynn Knize
>> wires to common
>> used with a deck
>> and not allowed to
>> be July, though.
>> Mike Kennedy
>> YAHOO! GROUPS LINKS
>> Visit your group "Cal_Boats " on the web.
>> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
> Duane & Lynn Knize
> SPONSORED LINKS
> Boating sailing Sailing boat Sailing
> Boating
> YAHOO! GROUPS LINKS
> Visit your group "Cal_Boats" on the web.
Re: (Mike Kennedy) pressure water (was mast wiring)
michaelkennedy052006-04-28 21:35
It all sounds awfully heavy. I used to think I'd like to enter that
boat in a race one day.
--- In Ca… [at] yahoogroups.com, Michael Kennedy <mtkennedy1@...>
he
keep
> Mike Kennedy
> > Mike,
have a
each
> > faucet with tee's.
the
and
tubing
inlet.
waste
the
turned
the
> > This really works.
> > Regards,
> > Duane
> > Duane & Lynn Knize
and
hot
> >> wires to common
can
be
> >> used with a deck
drained
> >> and not allowed to
goes
connectors.
going
the
as
probably
> >> be July, though.
> >> Mike Kennedy
> >> YAHOO! GROUPS LINKS
Service.
> > Duane & Lynn Knize
> > SPONSORED LINKS
> > Boating
> > YAHOO! GROUPS LINKS
Service.
mtkennedy12006-04-28 22:03
--- In Ca… [at] yahoogroups.com, "michaelkennedy05" <michaelkennedy05@...> wrote:
Oh Oh. I'm busted.
My son reads this list too.
Mike Kennedy
Conquest Cal 40 ## 96
> --- In Ca… [at] yahoogroups.com, Michael Kennedy <mtkennedy1@>
> he
> keep
> > Mike Kennedy
> > > Mike,
> have a
> each
> > > faucet with tee's.
> the
> and
> tubing
> inlet.
> waste
> 1
> the
> turned
> the
> > > This really works.
> > > Regards,
> > > Duane
> > > Duane & Lynn Knize
> and
> hot
> > >> wires to common
> can
> be
> > >> used with a deck
> drained
> > >> and not allowed to
> goes
> connectors.
> going
> the
> as
> probably
> > >> be July, though.
> > >> Mike Kennedy
> > >> YAHOO! GROUPS LINKS
> Service.
> > > Duane & Lynn Knize
> > > SPONSORED LINKS
> > > Boating
> > > YAHOO! GROUPS LINKS
> Service.
Re: [Cal_Boats] Re: (Mike Kennedy) pressure water (was mast wiring)
Chris Campbell2006-05-01 14:07 UTC
> > he
> > keep
I'm laughing to myself because the boat next to mine in the boat barn is
a really pretty 42 foot Sabre from 1989. The owner bought her from the
original owners last year. They kept the boat in top-notch condition
and the new owner is doing the same. But he was amused at the novelty
of having three heads and two showers below, plus a deck shower with hot
& cold water. We in the Great Lakes are not accustomed to such luxuries.
