3 messages2006-05-14 21:30 UTCthrough 2006-05-16 14:56 UTC
Re: [Cal_Boats] electricl connections
ya… [at] aol.com2006-05-14 21:30 UTC
Do NOT solder connections...a properly crimped connection, using tinned
stranded wire and tinned copper connectors will in effect be soldered by the
pressure of the crimp. The assumption being here, of course that you use a proper
ratcheting double crimp tool to make the crimps. The problem is that most
people use the inexpensive non-ratcheting tool, and don't get the proper amount
of pressure around the connector. Also, many folks only make one crimp,
instead of the two separate ones required for a proper job.
Soldering turns the very flexible stranded wire into a solid conductor for a
short distance up the wire from the crimp, and a solid wire is forbidden by
the ABYC and USCG. I see soldered connections fail often.
Best-Mark
Mark & Terry Rogers
Mobile Marine Electrical Services, Inc.
"Seirenia" 1966 Cal 36
Re: electricl connections
kvcpls2006-05-16 14:28
This is probably the single most important thing I've heard yet. I
didn't even know there were "good and bad" crimping tools.
Westmarine offers a crimping tool by ancor - about $135.
Considering the several hundred dollars spent on wire alone and the
desire to not need to do this again in 2 or 3 years it sounds like
it is well worth the money. Any other suggestions on a specific
tool?
Thanks for your comments
Keith
Cal-34 - Second Wind
tinned
soldered by the
you use a proper
that most
proper amount
crimp,
conductor for a
forbidden by
> Best-Mark
> Mark & Terry Rogers
Re: [Cal_Boats] Re: electricl connections
Michael Kennedy2006-05-16 14:56 UTC
I got the racheting crimping tool that Ancor makes. It won't open
until you've crimped the connector tightly enough. You can get them
for less money from sources like Hamilton Marine and Jamestown
Distributors.
Mike Kennedy
Conquest Cal 40 # 96
> tool?
> Keith
> tinned
> soldered by the
> you use a proper
> that most
> proper amount
> crimp,
> conductor for a
> forbidden by
> > Best-Mark
> > Mark & Terry Rogers
> YAHOO! GROUPS LINKS
> Visit your group "Cal_Boats" on the web.
> To unsubscribe from this group, send an email to:
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
