In the Pink! (VERY long)
4 messages2006-05-22 13:56 UTCthrough 2006-05-25 20:25 UTC
Alfred Poor2006-05-22 13:56 UTC
We went for a sail Saturday, the first non-sea trial outing of the season for Pentaquod. At least one boat was heading in as we headed out, saying it was a bit challenging out there. There were whitecaps on the Bohemia River, which doesn't have that long a fetch, so it had to be blowing pretty good. We expected the winds to hold westerly, so we figured we'd be in for a roaring reach down the Elk River to the head of the Chesapeake and back again. There's what you figure, and what actually happens. We stopped at the gas dock to top off the tank; the 18 gallon tank was down to 3 so we figured it was time to top off with 13 gallons of fresh fuel, and we dumped in the Marvel Mystery Oil as our engine's mate (and partner in Pentaquod) had instructed (based on Don Moyer's directions for proper Atomic 4 maintenance.) My brother-in-law (the third Pentaquod partner) was concerned about the new ethanol additives to the gas in this area, and had clippings of articles that described instant catastrophe for sludge release by the ethanol that would clog gas filters and cause major problems. The table was now set. We motored the mile or two where the Bohemia joins the Elk. Into the wind, the wind guage was reading about 14 knots, and minus the boat speed, put the true wind under 10 knots. It felt like more, but I figured it was because it was a cool day. I later revised that opinion. As we headed dead into the wind to hoist the main, I throttled back. And the engine died. And wouldn't start again. No problem; this is a sail boat. Put up the sails and then sort it out. I was not as far upwind as I wanted, so in spite of pinching, we had to tack to clear the mouth of the river; more work than I wanted, and since I was expecting to be on a reach momentarily, I had not tucked in the reef on the main. As we worked our way upwind across the Elk, I decided not to troubleshoot the engine now. We'd enjoy our sail, and we could try to start it as we neared the marina on our return. If it fired up, fine. If not, we could either drop anchor and troubleshoot, or the winds were favorable, and I could make the two right-angle turns under sail to make it to our slip. We turned to head down the Elk, and the rail was in the water because the wind was more on the nose than I had expected. So we paused and put a reef in the main and cranked in about half of the genny. We stood a little straighter, but it still was not enough. The wind meter was still showing only about 16 knots, but the boat was behaving like it was over 20. We sailed on, with the wind continuing to swing around to head us further. Soon we were close-hauled and weren't going to fetch the mouth of the Elk. And who knew what awaited outside Turkey Point at the head of the Bay. This was becoming too much like work, so we spun around and blasted back, making 8+ knots according to the GPS. According to plan, we tried the engine again as we neard the marina. At full choke, it ran roughly. At about half choke, it ran smoothly at higher RPMs but wouldn't idle. And it would die if the choke were pushed all the way in. Hmmm. And we were producing prodigious amounts of white smoke. Black exhaust is soot, and a bad mixture. Doesn't white smoke mean oil or water or both? Hmmm. My brother-in-law was convinced that we'd made ethanol-induced sludge. Maybe it had clogged the gas filter and the engine is starved for fuel; no, because it ran fine at high speed and not at low, which is the reverse of what you'd get with reduced fuel flow. Well, we could get back to the slip, and so we headed for the marina. Just before the first turn, I throttled back, and the engine died. I made a dead-stick landing in the slip without too much excitement. After the lines were secured, we tried the engine again to work on diagnosing the problem. And the dock master came roaring up in his pickup truck. "Please turn your engine off right now," he asked firmly. I figured he didn't like us smoking up the joint, so I complied. He then told us that the new kid on the gas dock had fueled us from the diesel half of the pump. I had known that the pump was half and half. I was busy with the pump-out at the bow, but I did go back to call out the gallons briefly when the dock hand was called away for a moment. And I was looking square at the diesel side when I did. My brother-in-law saw that the fuel was pink, but didn't say anything thinking maybe the ethanol was dyed that color or something. And he later recalled not smelling any gasoline fumes during the fueling; again thinking maybe the ethanol made it smell different or something. The dock master was understandably a bit anxious about our reaction, and promised that they'd have a mechanic working on it first thing today to pump out the diesel and clean up the fuel lines and fill it with gasoline. He was relieved when my reaction was to laugh at the whole situation. I'm reasonably sure that no permanent damage was done (unlike what would have happened had it been a diesel fueled with gasoline), and I learned once more about just how durable the little Atomic 4 is, that it can even run on diesel. (Not well, but it ran.) Now I know that if we ever run out of fuel in an emergency, I can just dump the salad oil in the tank at get another mile or two out of it! But this was just one of many lessons learned, including triple-check what tank the fuel hose is coming from before you put the nozzle in the fill hole. Also, it's easier to shake out an unneeded reef that put one in, so reef before you are sure you need it. Oh, and I have put a new wind unit on the wish list; the direction module stopped working last year, so now that the speed unit has also gone unreliable, it's time to replace them all. Alfred Poor 1969 Cal 29 #132, "Pentaquod"
RE: [Cal_Boats] Wind Speed Indicator - Was: In the Pink!
Harleigh Ewell2006-05-22 14:36 UTC
Good story, Alfred. At least it sounds like the sail back up the river was a blast. Your problems with the wind indicator reminded me of an issue I wanted to run by the list. This year, my wind speed indicator is not working. The speed sensor is spinning, the wind direction indicator is working, but the speed reading is "00" (so I assume it's getting power). Any fixes short of a new unit? It is a Standard 45, I believe, installed new winter 2000/2001. Harleigh Ewell Cal 31 Magothy River, Chesapeake Bay
Re: In the Pink! (VERY long)
mtkennedy12006-05-22 15:34
--- In Ca… [at] yahoogroups.com, "Alfred Poor" <apoor@...> wrote: > > We went for a sail Saturday, the first non-sea trial outing of the season > for Pentaquod. At least one boat was heading in as we headed out, saying it > was a bit challenging out there. There were whitecaps on the Bohemia River, > which doesn't have that long a fetch, so it had to be blowing pretty good. > We expected the winds to hold westerly, so we figured we'd be in for a > roaring reach down the Elk River to the head of the Chesapeake and back > again. There's what you figure, and what actually happens. > > > > We stopped at the gas dock to top off the tank; the 18 gallon tank was down > to 3 so we figured it was time to top off with 13 gallons of fresh fuel, snipped >After the lines > were secured, we tried the engine again to work on diagnosing the problem. > And the dock master came roaring up in his pickup truck. "Please turn your > engine off right now," he asked firmly. I figured he didn't like us smoking > up the joint, so I complied. He then told us that the new kid on the gas > dock had fueled us from the diesel half of the pump. > This happened in reverse to my wife about 20 years ago. Her Mercedes diesel wagon got its tank filled with gasoline by a new kid at the gas station. She couldn't figure out what was the matter as the lines were still full of diesel as she drove to the beach. Then she was ready to come home and it wouldn't start. I took it to the mechanic who figured out what had happened. It would run, after a fashion, but was really acting strangely. The station owner wasn't very happy but paid for repairs which consisted of replacing all the hoses. The engine wasn't badly damaged. Mike Kennedy Conquest Cal 40 # 96
Re: [Cal_Boats] In the Pink! (VERY long)
Chris Campbell2006-05-25 20:25 UTC
Alfred Poor wrote: > We went for a sail Saturday, the first non-sea trial outing of the > season for Pentaquod. > > > But this was just one of many lessons learned, including triple-check > what tank the fuel hose is coming from before you put the nozzle in > the fill hole. Also, it's easier to shake out an unneeded reef that > put one in, so reef before you are sure you need it. > > Nice tale, Al. The example you have set is to be prepared for the unexpected, which is what sailing is all about, really. For me, one of the appealing things about sailing is the degree of self-reliance required. Whenever you have the VHF on, you'll hear the occasional call from the powerboater who has run out of gas or whose engine has mysteriously died. You hear few sailors making such calls, perhaps because we are better prepared to deal with events as they make themselves known. And we all need to hear "reef early" just one more time, because it never seems to sink in until we should have reefed half an hour ago. "Martha C," the Cal 20, slid off the trailer yesterday morning, and in the evening her mast went up and the boom and mainsail went on. Too late for sailing by that time, and I may be shut out by thunderstorms tonight. We'll see. She looks lovely on her mooring. Chris Campbell
