8 messages2006-06-05 03:39 UTCthrough 2006-06-07 20:06 UTC
West System & PVC
Scott Sauvageot2006-06-05 03:39 UTC
A friend of mine has a PVC canoe (coleman) and wanted to fill some nasty gouges and gashes that have formed from years of whitewater canoeing. Would West System be ok, or will it attack PVC?
Also, what would be good for repainting the canoe? Is there an epoxy paint that would do the trick?
Cheers,
Scott S.
Cal 25 #1651 Indefatigable
Re: [Cal_Boats] West System & PVC
Chris Campbell2006-06-05 16:28 UTC
Scott:
The problem is not that epoxy will "attack" the PVC--it is that nothing
much will stick to the PVC. But the Gougeon Brothers have had some
success using a propane torch just prior to applying the epoxy. I think
it has to do with oxidizing the plasticizers. Contact their customer
service reps, or maybe you can get their "Epoxyworks" publication
on-line. It had an article a couple years back about doing this.
I have an old Porta-Potti with cracked corners in the holding tank that
I fixed long ago by roughing the plastic with sandpaper and then using
epoxy & cloth. I did it before reading about the torch method and so
far it hasn't leaked. But it's relatively well protected from flexing.
On a canoe that gets a lot of abuse, I'd be more careful.
PVC structural repair (Was RE: [Cal_Boats] West System & PVC)
Rog Jones2006-06-05 16:54 UTC
With the proper equipment and materials, PVC can be thermally welded. There
is also a product made by Oatey called Adhesive X15 for bonding of PVC. In
most cases this will do as well as or better than welding.
If you need complete information, there is a $100 book, Plastics and
Composites Welding Handbook, available on Amazon.com and some technical
school libraries also have copies.
\Rog
Cal 29+ #1
Swiss Navy
Cal 2-30 #77
St. Lori's Comet
Of Chris Campbell
Sent: Monday, June 05, 2006 9:29 AM
Subject: Re: [Cal_Boats] West System & PVC
Scott:
The problem is not that epoxy will "attack" the PVC--it is that nothing much
will stick to the PVC. But the Gougeon Brothers have had some success using
a propane torch just prior to applying the epoxy. I think it has to do with
oxidizing the plasticizers. Contact their customer service reps, or maybe
you can get their "Epoxyworks" publication on-line. It had an article a
I have an old Porta-Potti with cracked corners in the holding tank that I
fixed long ago by roughing the plastic with sandpaper and then using epoxy &
cloth. I did it before reading about the torch method and so far it hasn't
leaked. But it's relatively well protected from flexing. On a canoe that
SPONSORED LINKS
Boating
<http://groups.yahoo.com/gads?t=ms&k=Boating+sailing&w1=Boating+sailing&w2=S
ailing+boat&w3=Sailing&w4=Boating&c=4&s=65&.sig=KgsPLsahA8AB__qRyAt_XQ>
sailing
Sailing
<http://groups.yahoo.com/gads?t=ms&k=Sailing+boat&w1=Boating+sailing&w2=Sail
ing+boat&w3=Sailing&w4=Boating&c=4&s=65&.sig=oZUJLnrR0FEbvZ5o13Ffaw> boat
Sailing
<http://groups.yahoo.com/gads?t=ms&k=Sailing&w1=Boating+sailing&w2=Sailing+b
oat&w3=Sailing&w4=Boating&c=4&s=65&.sig=eGOXnwatS3x0LYN3XxVdNA>
Boating
<http://groups.yahoo.com/gads?t=ms&k=Boating&w1=Boating+sailing&w2=Sailing+b
oat&w3=Sailing&w4=Boating&c=4&s=65&.sig=yMCAyUrqzhoqLD5Ydiy-Rg>
YAHOO! GROUPS LINKS
* Visit your group "Cal_Boats
* Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/> Terms of Service.
Scott Sauvageot2006-06-05 17:06 UTC
Thanks! I'll look into these references. The gouges aren't all the way
through, but we wanted to fill them and fair the bottom of the canoe. Is
there a material that can be used as a filler for the pvc? I'm not trying
to structurally repair an open hole or split, just fill gouges.
Cheers,
Scott
>From: Chris Campbell <cl… [at] charterinternet.com>
>Date: Mon, 05 Jun 2006 12:28:30 -0400
>Scott:
>much will stick to the PVC. But the Gougeon Brothers have had some success
>using a propane torch just prior to applying the epoxy. I think it has to
>do with oxidizing the plasticizers. Contact their customer service reps,
>or maybe you can get their "Epoxyworks" publication on-line. It had an
>& cloth. I did it before reading about the torch method and so far it
>hasn't leaked. But it's relatively well protected from flexing. On a
>Chris Campbell
Chris Campbell2006-06-05 19:40 UTC
> trying
In the old days at least, snow ski bottoms were PVC, and they made stome
stuff that was melted into big scratches, as I recall. My brothers were
the big skiers so my connection with that was tangential. Call a ski
shop, if you live in snow country, or go the the internet.
> Cheers,
> Scott
> nasty
> >Scott:
> success
> has to
> reps,
> that I
> epoxy
> >Chris Campbell
> SPONSORED LINKS
> Boating sailing
> <http://groups.yahoo.com/gads?t=ms&k=Boating+sailing&w1=Boating+sailing&w2=Sailing+boat&w3=Sailing&w4=Boating&c=4&s=65&.sig=KgsPLsahA8AB__qRyAt_XQ>
> Sailing boat
> <http://groups.yahoo.com/gads?t=ms&k=Sailing+boat&w1=Boating+sailing&w2=Sailing+boat&w3=Sailing&w4=Boating&c=4&s=65&.sig=oZUJLnrR0FEbvZ5o13Ffaw>
> Sailing
> <http://groups.yahoo.com/gads?t=ms&k=Sailing&w1=Boating+sailing&w2=Sailing+boat&w3=Sailing&w4=Boating&c=4&s=65&.sig=eGOXnwatS3x0LYN3XxVdNA>
> Boating
> <http://groups.yahoo.com/gads?t=ms&k=Boating&w1=Boating+sailing&w2=Sailing+boat&w3=Sailing&w4=Boating&c=4&s=65&.sig=yMCAyUrqzhoqLD5Ydiy-Rg>
> YAHOO! GROUPS LINKS
> <http://groups.yahoo.com/group/Cal_Boats>" on the web.
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service <http://docs.yahoo.com/info/terms/>.
>No virus found in this incoming message.
>Checked by AVG Free Edition.
>Version: 7.1.394 / Virus Database: 268.8.1/355 - Release Date: 6/2/2006
Bob Ellison2006-06-05 23:43 UTC
Scott,
Are you sure it's PVC. Many canoes and kayaks (flatwater and ww) are
polyethylene. Some of them are repairable, some are not. I don't think
filling gouges has any real benefit. I've got some good size gouges in my
ww kayaks. Its just a fact of life, rocks are harder and sharper than
plastic. I've got a description of how to repair a plastic boat that I can
send off list. The disclaimer is that I have not tried to and don't know if
it works. Some kayak manufacturers sell repair sticks that can be melted
in. The reference to the ski base repair method mentioned earlier is a
p-tex candle.
Bob
Sent: Monday, June 05, 2006 1:06 PM
> Cheers,
> Scott
David Lyons2006-06-06 00:22 UTC
Check out marine tex website. They have sone things
specifically for PVC but it sounds like you still need
to touch the PVC. - David
--- Chris Campbell <cl… [at] charterinternet.com>
> the pvc? I'm not
> > trying
> fill gouges.
> and they made stome
> internet.
> Chris Campbell
> > Cheers,
> > Scott
> wanted to fill some
> > nasty
> > >Scott:
> > success
> epoxy. I think it
> > has to
> > reps,
> the holding tank
> > that I
> > epoxy
> careful.
> > >Chris Campbell
> > SPONSORED LINKS
> > Boating sailing
> > Sailing boat
> > Sailing
> > Boating
> > YAHOO! GROUPS LINKS
> on the web.
> email to:
> Yahoo! Terms of
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
r good2006-06-07 20:06 UTC
why wouldn't the "P-tex" type stuff used to repair teh bottoms of a ski
work?
>Scott:
>Chris Campbell
