Cal 2-29 port(window) frames
2 messages2006-06-12 04:00 through 2006-06-12 13:03
Neil McBride2006-06-12 04:00
As part of my upgrade and to fix that one leaking window, I'm about remove the existing windows. The frame is metal and I suspect they will break once I try to pry them off. I have seen a couple of Cal 29s with plastic frames, does anyone know if they are still available and if so where I might be able to purchase them? Neil "Optima" Victoria
Re: Cal 2-29 port(window) frames
John Caldwell2006-06-12 13:03
Call Mark Heacox @ Mark Plastics - 951-735-7705 --- In Ca… [at] yahoogroups.com, "Neil McBride" <n-smcbride@...> wrote: > > As part of my upgrade and to fix that one leaking window, I'm about > remove the existing windows. The frame is metal and I suspect they > will break once I try to pry them off. I have seen a couple of Cal 29s > with plastic frames, does anyone know if they are still available and > if so where I might be able to purchase them? > > Neil > "Optima" > Victoria >
