4 messages2006-06-19 23:14 UTCthrough 2006-06-20 14:33 UTC
Refrigeration on a C29
Terrence Spencer2006-06-19 23:14 UTC
I am thinking about installing a refrigeration conversion unit on my Cal 29.
I am tired of having to hunt for ice every 2-3 days while cruising in the
summer as well as having the icebox drainage in the bilge. I am wondering
about the experiences some of the others on this list have had with this
type of project. Specifically:
What are the best brands of conversion kits; compressors and evaporators?
Where have other C29 owners located the compressor to assure ventilation?
Were there any other pitfalls / things to watch out for?
Thanks for any advice,
Terry Spencer
Cal 2-29
Capriccio
Tacoma, WA
Re: Refrigeration on a C29
mtkennedy12006-06-20 00:13
I had an engine driven Technautics system in my Choate 40 25 years ago and it worked
like a charm. I will put one in the Cal 40 when I get around to it and will contact the same
company. It does not have the 12 vDC capability so, if you plan on spending a lot of time
in the slip and want it there, the 12v DC is probably better and it is cheaper.
The Technautics system had an electric clutch so, when we were running the engine to
charge batteries, we would flip the clutch on. You had to watch it because after 40 minutes
it would freeze everything. I had a temp gauge on the front of the fridge and would shut
off the clutch when it hit 40 degress.
In the Transpac, we used it as a freezer and took the frozen evening meal out each
morning and put it in an ice chest with the soft drinks for the day. It acted like an ice cube
as it cooled and defrosted. We had great food the whole race while lots of guys ate freeze
dried stuff that all tastes like apple sauce. Of course, now water makers make freeze dried
stuff more practical.
That I can't help with. Our unit was under the port quarterberth.
One of the crew took a junior college course on refrigeration so he could fix it if it broke.
We took some spares.
MIke Kennedy
Conquest cal 40 # 96
> Terry Spencer
> Cal 2-29
> Capriccio
> Tacoma, WA
Re: [Cal_Boats] Refrigeration on a C29 & Cal Cruising 46
Tom Vandiver2006-06-20 10:05 UTC
I have had a very good experience with the Norcold, 12
volt DC/ 120 volt AC conversion on out Cal 46. I
installed the first one in 1983. It performed
perfectly for 21 years, yes 21 years. When it finally
died I replaced it with the same unit. Anything on a
boat that lasts 21 years has to be good.
Downside- When operating on 12 volts it pulls a fair
amount of juice from the batteries. No problem if
motoring, as your alternator takes care of it. At
anchor or while sailing, you need to watch your
charge, particularly on a hot day when cold beverages
are being consumed. We have never had a problem, but
our Cal 46 has six large 6 volt golf cart batteries.
Also, I built our fridge from scratch, maxed out the
space available, considered the amount of insulation,
built a male mold of the interior,(rounded corners,
easier to clean, etc.), sprayed up gel coat, then
mat,cloth,mat. I then used the best insulation
available in 1983. It is still working fine. The space
is limited, but not a problem as we have a
12 cubic foot freezer under a dinnete seat. It has a
standard hermitic unit, like each convenience store
has dozens of, (cheap, but 120 volts AC only), great
at the dock or when genset is running. The coils for
this unit are around the stainless steel liner. It
also has a Dole holding plate from an ice cream truck
driven by a 2 cylinder Tecumseh compressor belt driven
off my Yanmar genset. At anchor or sailing in the
tropics, about 20 minutes run time morning and evening
keeps the ice cream hard. On our non-stop sail from
the Panama Canal to Mobile, Alabama, we had a bowl of
ice cream each day.
Life is good aboard SATORI. :-)
Tom and Bobbie Vandiver
> for?
> Terry Spencer
> Cal 2-29
> Capriccio
> Tacoma, WA
Chris Campbell2006-06-20 14:33 UTC
> Cal 29.
I fall into the "refrigeration is expensive and a pain" category, so
I'll inquire about whether you've tried improving the insulation in your
icebox (most are very minimally insulated by the boatbuilder). You can
use standard foam panels, or the spray urethane foam. Using a
reflective surface (like a "space blanket") on top of the contents also
helps. Sometimes you can add foam panels inside the icebox if you have
no way of gaining access to the outside.
To improve efficiency, the drain should have a trap, like the trap under
a sink, to keep cold air from "draining" out via convection (cold air
falls, right down the drain). You can put a bend into the drain hose or
run the hose into a jug or other container. There is a trap in effect
as soon as the water in the container is at the hose end. The container
can also keep the drain juice out of your bilge. You could even put a
small automatic bilge pump into the container and use much less
electricity than the compressor, fan, etc are going to use with
mechanical refrigeration.
