14 messages2006-06-30 20:36 UTCthrough 2006-07-04 19:41 UTC
Diesel Fuel/water Filters
John Boyce2006-06-30 20:36 UTC
Since my engine is now 25+ years old and has never had a water separator in
the fuel line I've concluded that I'm pushing my luck and should do
something proactive before I really regret it. So, what are the
recommendations from the group? What type of separator should I have? Should
I have the tank drained and cleaned?
My thinking was prompted by a problem a friend had with water in the fuel
caused by a broken o-ring on the fill pipe. $6.00 for the o-ring at West
Marine seems very expensive, but $500+ to have the tank pumped out and
cleaned by a marina seems a lot worse.
Re: [Cal_Boats] Diesel Fuel/water Filters
Sail Away2006-06-30 21:49 UTC
Racor 500 series....
Sent: Friday, June 30, 2006 4:36 PM
Subject: [Cal_Boats] Diesel Fuel/water Filters
Since my engine is now 25+ years old and has never had a water separator in the fuel line I've concluded that I'm pushing my luck and should do something proactive before I really regret it. So, what are the recommendations from the group? What type of separator should I have? Should I have the tank drained and cleaned?
My thinking was prompted by a problem a friend had with water in the fuel caused by a broken o-ring on the fill pipe. $6.00 for the o-ring at West Marine seems very expensive, but $500+ to have the tank pumped out and cleaned by a marina seems a lot worse.
masconsult2006-07-02 04:20 UTC
This morning I was out on a friends sailboat and noticed that the rudder post was moving some from side to side from each swell. Does this sound like a bearing or bushing. Additionally, I have noticed that his wheel steering seems to be getting harder to rotate. Is there any correlation between the two?
I would appreciate any feed back.
Mark
Cal 2-29 Pelican
San Pedro, CA
PS 4th of July we will be anchoring inside Cabrillo beach for the fireworks display, bands, etc. The bands on the beach near launching ramp begin at 4:30. It would be fun to meet other local Cal boat owners their.
Sent: Friday, June 30, 2006 2:49 PM
Subject: Re: [Cal_Boats] Diesel Fuel/water Filters
biggs dave2006-07-03 14:49 UTC
I don't see a reason to have you tank drained and cleaned if you haven't have a problem without a separator.
I like the Racor 200 series with the primer pump and I installed a 215R2 two years ago. I also intalled a filter vacuum gauge which give you an early indication that the filter is clogged. I was told to use locktite on the connections. I think I used the blue locktite
http://www.parker.com/parkersql/default.asp?type=2&id=27
Dave
80 Cal 35 Runnin Late
Coyote Pt, SF Bay
John Boyce <je… [at] adelphia.net> wrote:
Since my engine is now 25+ years old and has never had a water separator in the fuel line Ive concluded that Im pushing my luck and should do something proactive before I really regret it. So, what are the recommendations from the group? What type of separator should I have? Should I have the tank drained and cleaned?
Do you Yahoo!?
Next-gen email? Have it all with the all-new Yahoo! Mail Beta.
tiller vs wheel
Frank and Wendy2006-07-04 01:59 UTC
I recently removed the propane locker/helm seat from my Cal 31 to free up
some space in the cockpit behind the wheel. I will make a few modifications
so it is easy to put back on for cruising.
I am also thinking of changing over to tiller steering. Seems a wheel was
optional on the 31 and I wonder if the tiller would be better with the
crowded cockpit. We do about 50% racing plus daysailing and cruising. This
is a new boat for me so I thought I would put it out there for those with
more experience with the boat.
[Frank & Wendy]
'79 Cal 31
CIYC on Lake Erie
RE: [Cal_Boats] tiller vs wheel
Harleigh Ewell2006-07-04 03:12 UTC
A tiller would give you more room at anchor, but not necessarily while you
are sailing, because of the arc the tiller would need to move when steering.
Of course, if you change to tiller steering, you will need to remove the
pedestal, patch the resulting hole, and relocate the compass and the
throttle and transmission controls.
Harleigh Ewell
Cal 31
Of Frank and Wendy
Sent: Monday, July 03, 2006 9:59 PM
Subject: [Cal_Boats] tiller vs wheel
[Frank & Wendy]
'79 Cal 31
CIYC on Lake Erie
Rog Jones2006-07-04 03:20 UTC
Hang in there with the wheel on that boat. The cockpit is deliberately small
to keep it from getting pooped in a heavy sea and dragging the boat down.
\Rog
Cal 29+ #1
Swiss Navy
Cal 2-30 #77
St. Lori's Comet
Of Frank and Wendy
Sent: Monday, July 03, 2006 6:59 PM
[Frank & Wendy]
'79 Cal 31
CIYC on Lake Erie
qgold.772006-07-04 04:36 UTC
Best thing wd be a little joystick, with a thumb button for dropping the
anchor.
Nick
Of Harleigh Ewell
Sent: July 3, 2006 8:12 PM
Subject: RE: [Cal_Boats] tiller vs wheel
Harleigh Ewell
Cal 31
Of Frank and Wendy
[Frank & Wendy]
'79 Cal 31
CIYC on Lake Erie
Frank and Wendy2006-07-04 13:35 UTC
Yup, I know it will be a big job. I do like the feel and increased rudder
travel you get with a tiller though. I am planing on dropping the rudder to
take a mold and layup a new one over the winter anyway. that would be the
time to make the change if I do.
The rudder has stress/freeze cracks in it that make me nervous.
Frank Foote
Cal 31
[Frank & Wendy]
Of Harleigh Ewell
Sent: Monday, July 03, 2006 11:12 PM
Harleigh Ewell
Cal 31
-----Original Message-----
Behalf Of Frank and Wendy
[Frank & Wendy]
'79 Cal 31
CIYC on Lake Erie
Re: [Cal_Boats] tiller vs wheel
walter2006-07-04 15:26 UTC
I have a Cal34 with tiller and plan to convert to wheel. I have already
purchased a new pedestal but have not gotten around to installing it et
because there are other things ahead of it on the list.
The tiller takes up the whole cockpit. You have to keep it clear.
Perhaps that is less of a problem if one goes in a long straight line
for considerable time.
Edson suggests putting the pedestal (on my cal34) 12" ahead of the
tiller but then there interference from the traveler and boom. I have
seen a photo somewhere of a Cal with the pedestal quite near the
companionway. Is anyone familiar with this arrangement?
Walter
Cal34 #301
> up some space in the cockpit behind the wheel. I will make a few
> modifications so it is easy to put back on for cruising.
> was optional on the 31 and I wonder if the tiller would be better with
> the crowded cockpit. We do about 50% racing plus daysailing and
> cruising. This is a new boat for me so I thought I would put it out
> there for those with more experience with the boat.
> [Frank & Wendy]
> '79 Cal 31
> CIYC on Lake Erie
Skipper2006-07-04 16:17 UTC
Another option, if properly done, is to move your traveler to the cabin top.
It has a number of disadvantages for sure, but many love them there.
Wilkie
Sent: Tuesday, July 04, 2006 8:26 AM
Subject: Re: [Cal_Boats] tiller vs wheel
> Walter
> Cal34 #301
>> [Frank & Wendy]
>> '79 Cal 31
>> CIYC on Lake Erie
> Yahoo! Groups Links
walter2006-07-04 17:42 UTC
I have thought of that. I have the 14' boom, generally considered too
weak for a traveler mid-boom. Then I would have to strengthen the boom
while maintaining aesthetics.
It is a vicious circle.
Walter
> cabin top.
> Wilkie
Scott Sauvageot2006-07-04 19:32 UTC
The advantage of it near the companionway is that you can keep the rudder post through the deck, and hook up the tiller again as an emergency should the wheel steering fail.
Cheers and happy 4th
Scott
Walter
Cal34 #301
> [Frank & Wendy]
> '79 Cal 31
> CIYC on Lake Erie
walter2006-07-04 19:41 UTC
That was my thought but I have no personal experience with the wheel
being closer to the companionway. It would also be closer to the dodger
(another project for the future).
There would also be more "open space" aft of the wheel, as opposed to
being in the middle and splitting up the cockpit.
Walter
> Scott
