Re: [Cal_Boats] mineral spirits stove
4 messages2006-06-27 17:44 UTCthrough 2006-07-06 17:54 UTC
Hall, Edward C (GE Indust, Plastics)2006-06-27 17:44 UTC
My stove uses denatured alcohol. Slightlyu dangerous to light because you have to fill a cup with alcohol and let it heat the burner before it can be used. I'd rather have propane if it were my choice. I would guess mineral spirits would require a similar system as alcohol if I were to bet. Ed Hall Amentes Cal 2-29 -------------------------- From: Ca… [at] yahoogroups.com To: ca… [at] list.sailnet.net; Ca… [at] yahoogroups.com; Ca… [at] groups.msn.com; ca… [at] hotmail.com Sent: Tue Jun 27 13:27:05 2006 Subject: [Cal_Boats] mineral spirits stove Anyone have any experience with stoves which use mineral spirits as a fuel alternative? Reggie
r good2006-06-29 18:00 UTC
I've heard of using an alcohol "paste" to pre heat the burner. It comes in a tube like tooth paste. You squeeze out about 1/2 inch of it and light it. I believe it is used as a fire starter. Anyone have experience with this? Sure sounds less messy and safer. Reggie >From: "Hall, Edward C (GE Indust, Plastics)" <ed… [at] ge.com> >Reply-To: Ca… [at] yahoogroups.com >To: <Ca… [at] yahoogroups.com> >Subject: Re: [Cal_Boats] mineral spirits stove >Date: Tue, 27 Jun 2006 13:44:43 -0400 > >My stove uses denatured alcohol. Slightlyu dangerous to light because you >have to fill a cup with alcohol and let it heat the burner before it can be >used. I'd rather have propane if it were my choice. > >I would guess mineral spirits would require a similar system as alcohol if >I were to bet. > >Ed Hall >Amentes >Cal 2-29 >-------------------------- >Sent from my BlackBerry Wireless Handheld > > >-----Original Message----- >From: Ca… [at] yahoogroups.com >To: ca… [at] list.sailnet.net; Ca… [at] yahoogroups.com; >Ca… [at] groups.msn.com; ca… [at] hotmail.com >Sent: Tue Jun 27 13:27:05 2006 >Subject: [Cal_Boats] mineral spirits stove > >Anyone have any experience with stoves which use mineral spirits as a fuel >alternative? >Reggie > > > > >
RE: [Cal_Boats] mineral spirits stove
Husar Charlie2006-07-06 15:57 UTC
How about a some sterno for the purpose? A little dab'll do ya. CAL 25s came through with a 2 burner alcohol stove as standard equipment. We all got rid of them pretty quickly. It's the invisible fire that is scary. Cheers Charlie From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of r good Sent: Thursday, June 29, 2006 2:01 PM To: Ca… [at] yahoogroups.com Subject: Re: [Cal_Boats] mineral spirits stove Importance: Low I've heard of using an alcohol "paste" to pre heat the burner. It comes in a tube like tooth paste. You squeeze out about 1/2 inch of it and light it. I believe it is used as a fire starter. Anyone have experience with this? Sure sounds less messy and safer. Reggie >From: "Hall, Edward C (GE Indust, Plastics)" <ed… [at] ge.com> >Reply-To: Ca… [at] yahoogroups.com >To: <Ca… [at] yahoogroups.com> >Subject: Re: [Cal_Boats] mineral spirits stove >Date: Tue, 27 Jun 2006 13:44:43 -0400 > >My stove uses denatured alcohol. Slightlyu dangerous to light because you >have to fill a cup with alcohol and let it heat the burner before it can be >used. I'd rather have propane if it were my choice. > >I would guess mineral spirits would require a similar system as alcohol if >I were to bet. > >Ed Hall >Amentes >Cal 2-29 >-------------------------- >Sent from my BlackBerry Wireless Handheld > > >-----Original Message----- >From: Ca… [at] yahoogroups.com >To: ca… [at] list.sailnet.net; Ca… [at] yahoogroups.com; >Ca… [at] groups.msn.com; ca… [at] hotmail.com >Sent: Tue Jun 27 13:27:05 2006 >Subject: [Cal_Boats] mineral spirits stove > >Anyone have any experience with stoves which use mineral spirits as a fuel >alternative? >Reggie > > > > > Yahoo! Groups Links
Apologies
Rog Jones2006-07-06 17:54 UTC
Just found out yesterday that one of my email addresses hadn't been popped by my Outlook since last December. Aarrgghh. There were several thousand messages on the server - far too many to read and respond to. I'd like to apologize to anyone who sent me an email on that address (sw… [at] sbcglobal.net - now working, but not my primary). If it was important, please resend it to my primary email address, which is ro… [at] nvsailing.org and (assuming it clears all the spam filters and it isn't pornographic) I should get it and will respond. Again, apologies to those who probably think, "What a jerk, he didn't even reply!" Thanks. \Rog Cal 29+ #1 Swiss Navy Cal 2-30 #77 St. Lori's Comet
