RE: [Cal_Boats] Re: Cal 2-29 Flex Coupler
5 messages2006-06-26 13:19 UTCthrough 2006-07-10 20:42
Hall, Edward C (GE Indust, Plastics)2006-06-26 13:19 UTC
Thanks John and Tom. I'll follow up on this help! From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com]On Behalf Of John Caldwell Sent: Saturday, June 24, 2006 12:25 PM To: Ca… [at] yahoogroups.com Subject: [Cal_Boats] Re: Cal 2-29 Flex Coupler By 3" flex coupler you mean the one between the prop shaft and the transmission, they're about $300 from PRP. If you're running the Farymann, be sure to check the bushings on the transmission and replace those if needed (abt $51 @ PRP), or youi'll just be replacing the coupling again. You'll also want to make sure that the flanges on the tranny and prop shaft are clean and free of rust, or you'll just be replacing the coupler again about three years later.... --- In Cal_Boats@yahoogrou <mailto:Cal_Boats%40yahoogroups.com> ps.com, "Hall, Edward C \(GE Indust, Plastics\)" <edward1.hall@...> wrote: > > Sorry if this becomes a double post. I think I didn't send the original. > > I need to replace the Flex Coupler on my 1974 Cal 2-29. Its a 3" coupler but I can't find one like the one that's on the boat. > > Anyone know where to find one? > > Ed Hall > Cal 2-29 > Amantes > -------------------------- > Sent from my BlackBerry Wireless Handheld >
r good2006-06-27 15:36 UTC
mine was about $110 from Hansen Marine. Guess it depends upon what you need. Reggie >From: "Hall, Edward C (GE Indust, Plastics)" <ed… [at] ge.com> >Reply-To: Ca… [at] yahoogroups.com >To: <Ca… [at] yahoogroups.com> >Subject: RE: [Cal_Boats] Re: Cal 2-29 Flex Coupler >Date: Mon, 26 Jun 2006 09:19:39 -0400 > >Thanks John and Tom. I'll follow up on this help! > >-----Original Message----- >From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com]On Behalf >Of John Caldwell >Sent: Saturday, June 24, 2006 12:25 PM >To: Ca… [at] yahoogroups.com >Subject: [Cal_Boats] Re: Cal 2-29 Flex Coupler > > > >By 3" flex coupler you mean the one between the prop shaft and the >transmission, they're about $300 from PRP. > >If you're running the Farymann, be sure to check the bushings on the >transmission and replace those if needed (abt $51 @ PRP), or youi'll >just be replacing the coupling again. You'll also want to make sure >that the flanges on the tranny and prop shaft are clean and free of >rust, or you'll just be replacing the coupler again about three >years later.... > >--- In Cal_Boats@yahoogrou <mailto:Cal_Boats%40yahoogroups.com> ps.com, >"Hall, Edward C \(GE Indust, >Plastics\)" <edward1.hall@...> wrote: > > > > Sorry if this becomes a double post. I think I didn't send the >original. > > > > I need to replace the Flex Coupler on my 1974 Cal 2-29. Its a 3" >coupler but I can't find one like the one that's on the boat. > > > > Anyone know where to find one? > > > > Ed Hall > > Cal 2-29 > > Amantes > > -------------------------- > > Sent from my BlackBerry Wireless Handheld > > > > > > >
Re: [Cal_Boats] Re: Cal 2-29 Flex Coupler
Hall, Edward C (GE Indust, Plastics)2006-07-08 18:05 UTC
John, I got the 3" Flex Coupler from PRP. Thanks for the lead. Unfortunately, when I left my boat last weekend I forgot to grab one of the screws to attach it to the prop. I want to use new screws, but can't check them because they're about 5 hrs away. Does anyone know what size screws should used to attach the 3" Flex Coupler on a Faryman 12 to the transmission and to the prop shaft? Thanks, Ed Hall -------------------------- From: Ca… [at] yahoogroups.com To: Ca… [at] yahoogroups.com Sent: Sat Jun 24 12:24:46 2006 Subject: [Cal_Boats] Re: Cal 2-29 Flex Coupler By 3" flex coupler you mean the one between the prop shaft and the transmission, they're about $300 from PRP. If you're running the Farymann, be sure to check the bushings on the transmission and replace those if needed (abt $51 @ PRP), or youi'll just be replacing the coupling again. You'll also want to make sure that the flanges on the tranny and prop shaft are clean and free of rust, or you'll just be replacing the coupler again about three years later.... --- In Cal_Boats@yahoogrou <mailto:Cal_Boats%40yahoogroups.com> ps.com, "Hall, Edward C \(GE Indust, Plastics\)" <edward1.hall@...> wrote: > > Sorry if this becomes a double post. I think I didn't send the original. > > I need to replace the Flex Coupler on my 1974 Cal 2-29. Its a 3" coupler but I can't find one like the one that's on the boat. > > Anyone know where to find one? > > Ed Hall > Cal 2-29 > Amantes > -------------------------- > Sent from my BlackBerry Wireless Handheld >
John Caldwell2006-07-10 05:01
Glad I could help, Ed. I'm pretty sure that the bolts are 10mm x 1". You might want to try giving Ralph at PRP a call. I'm sure that he'd be a quick response. :) John > > John, > > I got the 3" Flex Coupler from PRP. Thanks for the lead. Unfortunately, when I left my boat last weekend I forgot to grab one of the screws to attach it to the prop. I want to use new screws, but can't check them because they're about 5 hrs away. > > Does anyone know what size screws should used to attach the 3" Flex Coupler on a Faryman 12 to the transmission and to the prop shaft? > > Thanks, > > Ed Hall > -------------------------- > Sent from my BlackBerry Wireless Handheld > > > -----Original Message----- > From: Ca… [at] yahoogroups.com > To: Ca… [at] yahoogroups.com > Sent: Sat Jun 24 12:24:46 2006 > Subject: [Cal_Boats] Re: Cal 2-29 Flex Coupler > > By 3" flex coupler you mean the one between the prop shaft and the > transmission, they're about $300 from PRP. > > If you're running the Farymann, be sure to check the bushings on the > transmission and replace those if needed (abt $51 @ PRP), or youi'll > just be replacing the coupling again. You'll also want to make sure > that the flanges on the tranny and prop shaft are clean and free of > rust, or you'll just be replacing the coupler again about three > years later.... > > --- In Cal_Boats@yahoogrou <mailto:Cal_Boats%40yahoogroups.com> ps.com, "Hall, Edward C \(GE Indust, > Plastics\)" <edward1.hall@> wrote: > > > > Sorry if this becomes a double post. I think I didn't send the > original. > > > > I need to replace the Flex Coupler on my 1974 Cal 2-29. Its a 3" > coupler but I can't find one like the one that's on the boat. > > > > Anyone know where to find one? > > > > Ed Hall > > Cal 2-29 > > Amantes > > -------------------------- > > Sent from my BlackBerry Wireless Handheld > > >
John Caldwell2006-07-10 20:42
Happy to help, Ed. Give Ralph at PRP a call back. He should be able to give you the exact, but I believe that the bolts are 10mm x 1". > John, > > I got the 3" Flex Coupler from PRP. Thanks for the lead. Unfortunately, when I left my boat last weekend I forgot to grab one of the screws to attach it to the prop. I want to use new screws, but can't check them because they're about 5 hrs away. > > Does anyone know what size screws should used to attach the 3" Flex Coupler on a Faryman 12 to the transmission and to the prop shaft? > > Thanks, > > Ed Hall > -------------------------- > Sent from my BlackBerry Wireless Handheld > > > -----Original Message----- > From: Ca… [at] yahoogroups.com > To: Ca… [at] yahoogroups.com > Sent: Sat Jun 24 12:24:46 2006 > Subject: [Cal_Boats] Re: Cal 2-29 Flex Coupler > > By 3" flex coupler you mean the one between the prop shaft and the > transmission, they're about $300 from PRP. > > If you're running the Farymann, be sure to check the bushings on the > transmission and replace those if needed (abt $51 @ PRP), or youi'll > just be replacing the coupling again. You'll also want to make sure > that the flanges on the tranny and prop shaft are clean and free of > rust, or you'll just be replacing the coupler again about three > years later.... > > --- In Cal_Boats@yahoogrou <mailto:Cal_Boats%40yahoogroups.com> ps.com, "Hall, Edward C \(GE Indust, > Plastics\)" <edward1.hall@> wrote: > > > > Sorry if this becomes a double post. I think I didn't send the > original. > > > > I need to replace the Flex Coupler on my 1974 Cal 2-29. Its a 3" > coupler but I can't find one like the one that's on the boat. > > > > Anyone know where to find one? > > > > Ed Hall > > Cal 2-29 > > Amantes > > -------------------------- > > Sent from my BlackBerry Wireless Handheld > > >
