4 messages2006-08-31 16:27 through 2006-08-31 21:30 UTC
Cal 29 Sail Trim
markalan052006-08-31 16:27
I have been racing on a friends Cal 29. I have been having trouble
getting the mainsail properly adjusted. When sailing to weather, in
winds estimated 8-24 knots, the main back winds from the luff back. I
can not trim this 1/3 or more back-winding out of the sail.
I have tried about every thing with the main even over sheeting and
traveling boom up to the center line and still the sail luffs. We
mostley use a 138 or 155.
The owner said that this is just how this loose footed main sail has
worked from day 1...back winded!
When I ease out the main to almost 1/2 back-winded we seem to gain a
knot.
We have reefed the main and still get back-wind.
I have noticed that the Jib's leach cord is a little tight causing the
jib to curl some could this be causing the problem?...Capt says no.
Any suggestions would be helpful.
Mark
Cal 2-29
Pelican (San Pedro)
RE: [Cal_Boats] Cal 29 Sail Trim
Downing, Thomas2006-08-31 18:52 UTC
Trying to correct excessive backwinding by sheeting in the
main is probably counter productive, as your post seems to
say!
Marchaj says that foresail leach curl is a major cause of
backwinding. Problem is, with older sails leach curl can
stay in even with a slack leach line. Other causes are
excessive camber in the genoa, especially near the head,
or camber too far aft.
You might talk to a sailmaker. Correcting leach cutaway
might help.
YMMV, I am not a racer...or a sailmaker.
td
From: Ca… [at] yahoogroups.com on behalf of markalan05
Sent: Thu 8/31/2006 12:27 PM
Subject: [Cal_Boats] Cal 29 Sail Trim
knot.
Mark
Cal 2-29
Pelican (San Pedro)
DISCLAIMER:
Re: Cal 29 Sail Trim
michaelkennedy052006-08-31 20:15
Hi Mark
Wise man say trim the front of the jib and the back of the main. A
little bubble at the front of the main doesn't slow you down, and
sheeting in enough to remove it makes the leech of the main a big
airbrake. The bubble is caused by backwash off of the jib, as well
as turbulence from the mast itself. One thing that can be done (and
should be done for the sake of jib trim, if nothing else) is ease
the jib's leech line until the leech flutters, then pull it back on
just till the fluttering stops. Some of that bubble should also go
away when you pull on the outhaul and cunningham as the breeze comes
on. Other than that, the buble at the front of the main in and of
itself isn't anything to worry about.
For the main, another thing that will help when the breeze comes on
is adding twist-instead of easing the traveler down, ease the
mainsheet instead. This will decrease heel making the sails and the
keel more effective. Keeping all 4 wheels on the ground is fast!
When the breeze eases off and you need more power, pull the
mainsheet back on and move the traveler up and down with an eye on
the knotmeter to find the sweet spot. Which combination of all this
makes the boat happiest is different every time, due to different
wind/water conditions, but that's part of the fun.
Good luck. Hope this helps
Mike Kennedy Jr.
Conquest Cal 40 #96
--- In Ca… [at] yahoogroups.com, "markalan05" <masconsult@...>
in
back. I
and
has
a
> knot.
the
no.
> Mark
> Cal 2-29
> Pelican (San Pedro)
ti… [at] ch2m.com2006-08-31 21:30 UTC
Without seeing anything, either your
main is too full, or
main not twisted enough.. or
maybe the Genoa incorrectly trimmed???
(twisting the Genoa is another valuable art form)
Or maybe everything is just right!!!
8 knot solutions are different than 24 knot solutions,
water conditions (waves) also change the solution.
I believe that your ultimate desire is to sail at your maximum upwind
Target Boat Speed (TBS).. in mild to flatter seas.
(no boom surge caused by wave action) - NOTE TBS
is NOT the highest angle in which you can physically sail, it
is the maximum vector of speed and angle that gets
you to the upwind target the fastest!!!! i.e. win the race to the mark.
Do you know these numbers? (TWA/TWS/SOW) (also known as polars?)
"Fisherman's Reefs" (backwinded main) are not always bad,
see if you can reach your TBS.
The controls for the main are:
The Main Car, - Upwind for twist and weather helm - converse leeward
The Main Sheet, - Controls leech curve & boom angle
The Outhaul - main Leech and "lower draft"
The Vang - main Leech curve & Draft
The Back Stay - Genoa luff - Main flattening
The Cunningham - main luff tensioning / move draft.
The Baby Stay, with backstay amplifies main adjustments
The Running Backs, tunes middle top of main
The Main Halyard
The main Backwinding is adjusted by these controls, and is affected by
the jib-Genoa trim.
First I would start with sailing the boat at the target angle, and get
the power plant, the Jib/Genoa
flying correctly for the wind/wave condition.
Then using the above tools, maybe start off with maximum twisted main.
Main car high, (windward)
Main sheet adjusted "loose" to get twist, and remove "fisherman's reef"
Outhaul, play until draft improves, but not so tight as to curl leech -
streaming tail tells ALWAYS
Vang, - play until top batten parallel with boom... or not... watch
speed
Backstay - tighten to move Genoa draft forward, and flatten main
Cunningham loose, see what effect adjusting it does...
Baby stay, play with backstay
Running Backs... probably not needed unless bouncy seas/ higher winds.
Main Halyard. an initial setting establishes draft location, loose light
air, tighter heavy - neutral Mylar sails
Infinite wind/sea combinations combined with infinite sail trimming
options
AND SAIL MATERIALS make sailing an interesting sport - and separates
the observant (winners) from the less observant (losers).
Key importance is to know the numbers you should be sailing, and then
never be satisfied with the trim until you obtain the proper speeds....
Use a GPS
and watch your Speed to mark (Waypoint Closure
Lastly, since you win races by finishing before the rest of the
sailors..
covering the fleet, is always a primary concern.
Behalf Of markalan05
Sent: Thursday, August 31, 2006 9:28 AM
knot.
Mark
Cal 2-29
Pelican (San Pedro)
