7 messages2006-09-11 14:58 UTCthrough 2006-09-13 13:41 UTC
jib sheeting angle--Cal 20
Chris Campbell2006-09-11 14:58 UTC
Listees:
My Cal 20 and the other one here have fairleads on the deck, inboard of
the shrouds. On my boat. they're fixed, and on the other one, they're
on a fore-and-aft track.
Sailing the other Cal 20 recently, we tried running the jib sheets
through these inboard fairleads instead of the usual jib sheet blocks,
which are outboard. It gives a very tight sheeting angle when close-hauled.
The only problem is that you have to re-reeve the sheets when going from
beating to reaching or running, because the inboard fairleads give a
fair lead only when close-hauled. Farther off the wind, the sheet would
run into the shrouds.
So, here are my two questions:
*First*, is this what the fairleads are for?
*And second*, is there an easy way to switch from the inboard sheeting
position to the outboard one? Use two sets of sheets? Reeve the lazy
sheet through the next-to-be-used fairlead or block just before tacking
or changing course?
Still figuring out the rigging on Cal 20 #1220
RE: [Cal_Boats] jib sheeting angle--Cal 20
Scott Sauvageot2006-09-11 15:32 UTC
Could they have been for a storm jib or #3 genoa that only came back to the
shrouds? THe position you describe sounds like my #3 (105%) genoa track
placement on my Cal 25, though I'm not certain how far aft the fairleads you
describe are located.
Cheeres,
Scott
>From: Chris Campbell <cl… [at] charterinternet.com>
>Subject: [Cal_Boats] jib sheeting angle--Cal 20
>Date: Mon, 11 Sep 2006 10:58:18 -0400
>Listees:
>My Cal 20 and the other one here have fairleads on the deck, inboard of the
>shrouds. On my boat. they're fixed, and on the other one, they're on a
>fore-and-aft track.
>Sailing the other Cal 20 recently, we tried running the jib sheets through
>these inboard fairleads instead of the usual jib sheet blocks, which are
>beating to reaching or running, because the inboard fairleads give a fair
>lead only when close-hauled. Farther off the wind, the sheet would run
>into the shrouds.
>sheet through the next-to-be-used fairlead or block just before tacking or
>changing course?
>Chris Campbell
Re: [Cal_Boats] jib sheeting angle--Cal 20
Chris Campbell2006-09-11 15:36 UTC
> to the
> fairleads you
The fairleads worked very well on the standard working jib we were
flying. The jib was sheeted inside of all shrouds very nicely. On my
boat, it might be a bit messier, since the forward lower shrouds had
been moved inboard.
Bruce Stirling2006-09-11 16:12 UTC
Chris,
Does this photo of the old Cal 20 for $200 show what you are decribing? I
see a small inside track.
See: http://www.stirlinglaw.com/cal28/oldcal28s/cal%2020%20d.jpg
Bruce
-----Original Message-----
Of Scott Sauvageot
Sent: Monday, September 11, 2006 8:32 AM
Subject: RE: [Cal_Boats] jib sheeting angle--Cal 20
Cheeres,
Scott
>Listees:
>fore-and-aft track.
>into the shrouds.
>changing course?
>Chris Campbell
Chris Campbell2006-09-11 20:12 UTC
Bruce Stirling wrote:
> Chris,
> decribing? I see a small inside track.
> <http://www.stirlinglaw.com/cal28/oldcal28s/cal%2020%20d.jpg>
Bruce--
That's (or "those are") it. That boat has two on each
side--athwartships ones, and fore-and-aft ones, both located inside the
shrouds. You'd have lots of choices on that boat, by moving the little
white fairlead on its car from one track to another, and moving along
each track.
By the way, if that boat is still for sale, post a notice on the list
with location details. Then we can encourage Cal sailors in that
vicinity to encourage local folks to pick up a cheap route into
sailing. I don't think I've raved wildly about the wonders of the Cal
20 yet this week, so here goes. They are just such cool little boats,
such well-mannered vessels, and such a delight to sail. And they fit
with my theory that small boats get sailed more.
jo… [at] peco-energy.com2006-09-12 13:08 UTC
Chris:
I can't help you with the fairlead question, but if you have a mid-ships cleat, here's a helpful tip I got from the Sabre list: take the pressure of the sail with the lazy sheet on the mid-ships cleat and then move your originally-loaded sheet wherever you like it. Once rerouted, return the lazy sheet to its former status and "Bob's your Uncle!"
Jon Myers
Occasional ballast and crew, Cal 3-29 Bay Breeze
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com]On Behalf Of Chris Campbell
Sent: Monday, September 11, 2006 10:58 AM
Listees:
My Cal 20 and the other one here have fairleads on the deck, inboard of the shrouds. On my boat. they're fixed, and on the other one, they're on a fore-and-aft track.
Sailing the other Cal 20 recently, we tried running the jib sheets through these inboard fairleads instead of the usual jib sheet blocks, which are outboard. It gives a very tight sheeting angle when close-hauled.
The only problem is that you have to re-reeve the sheets when going from beating to reaching or running, because the inboard fairleads give a fair lead only when close-hauled. Farther off the wind, the sheet would run into the shrouds.
First, is this what the fairleads are for?
And second, is there an easy way to switch from the inboard sheeting position to the outboard one? Use two sets of sheets? Reeve the lazy sheet through the next-to-be-used fairlead or block just before tacking or changing course?
This e-mail and any of its attachments may contain Exelon
Corporation proprietary information, which is privileged,
confidential, or subject to copyright belonging to the Exelon
Corporation family of Companies.
This e-mail is intended solely for the use of the individual or
entity to which it is addressed. If you are not the intended
recipient of this e-mail, you are hereby notified that any
dissemination, distribution, copying, or action taken in relation
to the contents of and attachments to this e-mail is strictly
prohibited and may be unlawful. If you have received this e-mail
in error, please notify the sender immediately and permanently
delete the original and any copy of this e-mail and any printout.
Thank You.
Chris Campbell2006-09-13 13:41 UTC
jo… [at] peco-energy.com wrote:
Chris:
"Bob's your Uncle!"
Jon: That was what I was thinking, described in another way.
Basically, move the lazy sheet to the lee side, let it become the
working sheet, unload the old working/now lazy sheet, and move that to
the other side. In my method, the sheets end up changing sides in the
process.
Works a lot easier with a crew!
