3 messages2006-09-18 18:22 UTCthrough 2006-09-19 12:42 UTC
spreader clamps
Chris Campbell2006-09-18 18:22 UTC
Rog Jones was singing the praises of little clamps that secure to the
shrouds to hold up the spreader tips, or rather, to keep them from
drooping. These were supposedly available from West Marine. I spent
some time with a clerk there who is a sailor and he did not find them in
the catalog, nor on the shelf.
Better ideas for locating these items?
RE: [Cal_Boats] spreader clamps (Chris)
Rog Jones2006-09-18 20:48 UTC
Hi Chris -
These are also very easy to make at home. Get a small chunk of 3/8"
polypropylene. Cut out two 1-1/2-inch diameter circles. Drill the center of
the circle to a diameter slightly smaller than your shroud. Sand a slight
radius on each sharp edge so that there is nothing to cut or wear your sail.
Draw a line through the center and cut the disk in half to make a
semicircle. Parallel to and 5/8" from the flat side of the semicircle draw a
pencil line along the face of the semicircle. From each side of that line
measure inward 3/8" and draw a vertical line perpendicular to it. Use a band
saw or hacksaw to cut out that little notch. Set each semicircle upright on
a drill press with the flat surface facing downward. Drill a hole down
through the center of the notch to take whatever size machine screw you want
to use to hold the two halves together. Put your screws and nuts through and
attach the little round disks to the shrouds. Slide them up the shrouds to
where you want the spreader tips and tighten them up. Making these is about
a twenty minute process if you have the right tools.
\Rog
Cal 29+ #1
Swiss Navy
Cal 2-30 #77
St. Lori's Comet
Of Chris Campbell
Sent: Monday, September 18, 2006 11:23 AM
Subject: [Cal_Boats] spreader clamps
Re: [Cal_Boats] spreader clamps (Chris)
Chris Campbell2006-09-19 12:42 UTC
Rog Jones wrote:
> Hi Chris --
> center of the circle to a diameter slightly smaller than your shroud.
Thanks, Rog!
Now I need to scrounge for polypro. I suppose I could melt down some
old long underwear....
