pox
Chris Campbell2006-10-02 19:52 UTC
Here's another question. Old Cal 20 #1220 is developing the pox along
the waterline and about 4" up. It seems to get a bit worse each year.
It started under my ownership about 8 years ago (that long already???).
These are not "blisters" but are more like "pimples," little bumps of
about 1/8" diameter. It's every teen's nightmare, but my boat turns 40
next year.
I'm assuming this is the usual osmotic blistering phenomenon, in a less
drastic form.
The questions that come to mind are: (1) can I arrest this by removing
bottom paint and applying a barrier coating?
And (2) does my bottom paint accelerate this? It was not present when I
bought the boat, and she was already old as boats go. I changed bottom
paints when I bought her and wonder if there's some effect of the copper
in this formulation that would exacerbate the problem. The boat is not
only in fresh water, which apparently is worse for blistering, but in
pristine fresh water.
RE: [Cal_Boats] pox
Ben Koche2006-10-02 20:59 UTC
I had the same problem on my 74 C25. Make sure its not blistering from the
inside out. Just to be sure I would drain and paint the bildge with interlux
bildgecoat. Next I would sand/sodablast the bottom to remove all the paint,
open all the blisters and flush with freshwater to remove the glycol residue
that resides in the blisters. let the hull dry out for a couple weeks and
when dry, fill the blisters with west system epoxy thickened with 410
microlite. Cover the bottom with 4-6 coats of interlux interprotect 2000,
then you will be ready for bottom paint again.It sounds like a long and hard
process and Id be lieing if I said It wasnt. If you follow this process, the
boat will outlast you.
Ben Koche
Of Chris Campbell
Sent: Monday, October 02, 2006 3:53 PM
To: cal; Ca… [at] yahoogroups.com
Subject: [Cal_Boats] pox
next year.
drastic form.
