12 messages2006-10-02 19:37 UTCthrough 2006-10-05 13:30 UTC
use of traveller
Chris Campbell2006-10-02 19:37 UTC
Listees:
I'll inquire on this list, which has more racers than the list for my
other boat. My Cal 20 does not have a traveler (but should). The other
boat does.
The question is about proper use of the traveler. The other boat has an
old one (early '60s) that I'm thinking about replacing this winter
because it's very hard to use--lots of friction.
I've assumed that you use the traveler primarily to control the amount
of mainsail twist. If you sheet the main in and then use the traveler
to control the boom position, you can keep an untwisted main that draws
evenly (more or less) from top to bottom. When you need to let the main
out some, for a puff or for general trim, you just let the traveler down
to leeward.
If you want a main with some twist so it luffs toward the head and
depowers the sail, you can move the traveler amidships or to windward
and let the sheet out more so the mainsheet is at an angle from the
vertical, pulling down less.
Have I got this right? If I'm right, you'd use the traveler to leeward
mostly in moderate winds, when you want the perfect foil-shaped
mainsail, and you'd pull it back to center or even to windward when you
wanted a fuller sail shape in light air or when you really wanted the
head to fall off and luff as a means of depowering in high winds.
Advice?
RE: [Cal_Boats] use of traveller
ti… [at] ch2m.com2006-10-02 20:57 UTC
Essentially Correct, Windward for Twist, and making a slot for larger
genoas.
Recall also that the wind itself, "twists" as it get farther from the
surface, the friction with water "bends the air" @ 15% or so,,, that's
why waves are a bit harder to sail through in starboard.. generally, so
you put more twist on your starboard trim to power up the boat. See
Coriolis effect (Wind Shear).
Wind Sheer
When there is wind-speed, there is wind shear!
What is wind shear?
The main reason for wind shear is due to the Coriolis force. The wind
will rotate counter clockwise on the North Hemisphere around the centre
of the low pressure.
Then, there is a friction between the sea surface and the free air
above. This friction will slow down the airspeed at sea level and
gradually up into the free air above. This friction will also decrease
the effect of the Coriolis force, so the wind will shear (to the right)
from sea level up to the mast top (and above). The wind transducer will
only measure at one altitude, so you need to understand and consider
this sheared angle to adjust the sail accordingly down to deck level.
Note! Several meteorological effects will have impact on the size of the
sheared wind. When cold and warm air is mixed with faster winds from
higher levels, gradients and sheared winds may locally change very fast.
Generally, by applying sail trim according to the size of wind shear,
you can get more power out of the wind on starboard by adding more twist
to match the shear (on starboard only). This will reduce the top force
from the wind, move the pressure centre downwards and allow for a more
forward pointing and efficient wind force.
The wind instrument will "show you" that you are sailing lower than port
side, but it is only a relative illusion since the reference is from
your average attack angle and sail trim including wind shear.
On port side, the sheared wind is "negative", and it requires more flat
sail trim. The instruments will tell you that you are sailing high and
fast on port tack, but this is also a relative illusion, but opposite
from starboard tack. You have less wind force in the top of the sail, so
the efficient wind pressure centre is moved downwards. Then, for a given
heel angle, you will have a wider wind angle, which mean that you are
actually not sailing as high as the instrument says!
At open sea, where wind direction is stabilized, the waves will follow
the wind direction that occurs at the surface. Since this wind-speed is
reduced by the friction, it will therefore point towards the low
pressure. This means that you will hit the waves slightly harder on
starboard then port side (on the North hemisphere). This is also a
reason for adding more twist and power on starboard tack!
Behalf Of Chris Campbell
Sent: Monday, October 02, 2006 12:38 PM
To: cal; Ca… [at] yahoogroups.com
Subject: [Cal_Boats] use of traveller
Listees:
boat does.
to leeward.
Advice?
Bruce Stirling2006-10-03 02:48 UTC
Rog recently sent me an email about the Cal 28 liking a bit of twist in her
sails. While I'd stumbled across references to "twist" before in sailing
materials, I wasn't really sure how to accomplish the manuever. After
spending some time online and Google, I realized, finally, what the traveler
was really used for. I spent this weekend determined to get a twist in both
the main and genoa. In the light air of San Diego's bay and Point Loma, I
opted to keep the traveler to windward side. See position in attached photo
of Debbie at the helm. Note, too, the work of the power thruster, as we
motored towards the blue water, where we cut the engine to chase the
schooner shown.
Thanks for these finer points on proper use of the traveler. Just the sort
of thing I was hoping to pickup as a member of this fine group. Thanks for
asking about it, Chris. I talked to the marina and the Cal 20 is still
available. I told them I might buy it just to practice my painting,
fiberlglass, and carpentry skills.
Bruce Stirling
Gangfurd
Cal 28 - Hull 82
http://www.stirlinglaw.com/cal28
Of ti… [at] ch2m.com
Sent: Monday, October 02, 2006 1:57 PM
Subject: RE: [Cal_Boats] use of traveller
genoas.
surface, the friction with water "bends the air" @ 15% or so,,, that's why
waves are a bit harder to sail through in starboard.. generally, so you put
more twist on your starboard trim to power up the boat. See Coriolis effect
(Wind Shear).
Wind Sheer
What is wind shear?
The main reason for wind shear is due to the Coriolis force. The wind will
rotate counter clockwise on the North Hemisphere around the centre of the
low pressure.
Then, there is a friction between the sea surface and the free air above.
This friction will slow down the airspeed at sea level and gradually up into
the free air above. This friction will also decrease the effect of the
Coriolis force, so the wind will shear (to the right) from sea level up to
the mast top (and above). The wind transducer will only measure at one
altitude, so you need to understand and consider this sheared angle to
sheared wind. When cold and warm air is mixed with faster winds from higher
Generally, by applying sail trim according to the size of wind shear, you
can get more power out of the wind on starboard by adding more twist to
match the shear (on starboard only). This will reduce the top force from the
wind, move the pressure centre downwards and allow for a more forward
side, but it is only a relative illusion since the reference is from your
On port side, the sheared wind is "negative", and it requires more flat sail
trim. The instruments will tell you that you are sailing high and fast on
port tack, but this is also a relative illusion, but opposite from starboard
tack. You have less wind force in the top of the sail, so the efficient wind
pressure centre is moved downwards. Then, for a given heel angle, you will
have a wider wind angle, which mean that you are actually not sailing as
At open sea, where wind direction is stabilized, the waves will follow the
wind direction that occurs at the surface. Since this wind-speed is reduced
by the friction, it will therefore point towards the low pressure. This
means that you will hit the waves slightly harder on starboard then port
side (on the North hemisphere). This is also a reason for adding more twist
Of Chris Campbell
Listees:
boat does.
to leeward.
Advice?
Re: [Cal_Boats] use of traveller
Fin Beven2006-10-03 03:21 UTC
Timm...
I'm a little unclear on this one.
Between 20' above the water and 35' above the water, how many degrees of wind direction difference would you expect to find ???
Fin.
Essentially Correct, Windward for Twist, and making a slot for larger genoas.
Recall also that the wind itself, "twists" as it get farther from the surface, the friction with water "bends the air" @ 15% or so,,, that's why waves are a bit harder to sail through in starboard.. generally, so you put more twist on your starboard trim to power up the boat. See Coriolis effect (Wind Shear).
Wind Sheer
What is wind shear?
The main reason for wind shear is due to the Coriolis force. The wind will rotate counter clockwise on the North Hemisphere around the centre of the low pressure.
Then, there is a friction between the sea surface and the free air above. This friction will slow down the airspeed at sea level and gradually up into the free air above. This friction will also decrease the effect of the Coriolis force, so the wind will shear (to the right) from sea level up to the mast top (and above). The wind transducer will only measure at one altitude, so you need to understand and consider this sheared angle to adjust the sail accordingly down to deck level.
Note! Several meteorological effects will have impact on the size of the sheared wind. When cold and warm air is mixed with faster winds from higher levels, gradients and sheared winds may locally change very fast.
Generally, by applying sail trim according to the size of wind shear, you can get more power out of the wind on starboard by adding more twist to match the shear (on starboard only). This will reduce the top force from the wind, move the pressure centre downwards and allow for a more forward pointing and efficient wind force.
The wind instrument will "show you" that you are sailing lower than port side, but it is only a relative illusion since the reference is from your average attack angle and sail trim including wind shear.
On port side, the sheared wind is "negative", and it requires more flat sail trim. The instruments will tell you that you are sailing high and fast on port tack, but this is also a relative illusion, but opposite from starboard tack. You have less wind force in the top of the sail, so the efficient wind pressure centre is moved downwards. Then, for a given heel angle, you will have a wider wind angle, which mean that you are actually not sailing as high as the instrument says!
At open sea, where wind direction is stabilized, the waves will follow the wind direction that occurs at the surface. Since this wind-speed is reduced by the friction, it will therefore point towards the low pressure. This means that you will hit the waves slightly harder on starboard then port side (on the North hemisphere). This is also a reason for adding more twist and power on starboard tack!
Listees:
boat does.
to leeward.
Advice?
RE: [Cal_Boats] use of traveller - Fin
ti… [at] ch2m.com2006-10-04 18:17 UTC
Fin -
We use the Nexus T.R.U.E. feature to tune the boat before every race.
The Wind Shear changes
with conditions, wave height, wind weight, air temperature, leeway etc.
The T.R.U.E. feature can even
be used during the race to recalibrate a changing condition.
To use the feature, you'll need the new FDX Server, FDX Software (free),
1 meter Twin Fin wind
transducer, and the "non-amplifier" depth transducer.
A starting point is @ 7.5 degrees.. sometimes more, sometimes less....
More info on the software and use can be found at
Summary
http://tinyurl.com/gtywy <http://tinyurl.com/gtywy>
More Detail
http://www.silva.se/marine/fdx/nx2soft_manual.pdf
<http://www.silva.se/marine/fdx/nx2soft_manual.pdf>
dEmO
Behalf Of Fin Beven
Sent: Monday, October 02, 2006 8:21 PM
Subject: Re: [Cal_Boats] use of traveller
Timm...
Fin.
<mailto:ti… [at] ch2m.com>
larger genoas.
Wind Sheer
What is wind shear?
very fast.
Listees:
for my
other
boat does.
has an
winter
amount
traveler
that draws
the main
traveler down
to leeward.
and
windward
the
leeward
when you
wanted the
winds.
Advice?
Re: [Cal_Boats] use of traveller - Fin
Chris Campbell2006-10-04 19:34 UTC
ti… [at] ch2m.com wrote:
> Fin -
> etc. The T.R.U.E. feature can even
> (free), 1 meter Twin Fin wind
And I thought I had caught up with the modern world when I got a Windex.
Wind Sensors - Chris
ti… [at] ch2m.com2006-10-04 20:23 UTC
Actually Chris, the Windex is an invaluable tool for shorter
races, as it is generally more responsive/ sensitive than a
transducer. The transducer benefit, is to help keep our eyes
"in the war zone" verses looking up at the sky.
I use the Windex, and tell tales on the shrouds, primarily when
we are doing buoy popper races on the Columbia.. Popper races
is my term for very short legs, popping sails up and down every mile or
so.
My favorite (low tech) wind reading tools:
Backside of head, after a new haircut,
Shroud Tell tails - a furry string fiber
Windex
Water Ripples
Cigar Smoke
Land Smoke/ Flags
Puffy Clouds with flat bottoms.
Clouds along a shoreline
The very Nice Nexus Instruments/ software is useful, once you get the
boat
established on a beat/ run, to maximize Sailing angles, Target Boat
Speeds, and waypoint closure. Also the better transducers provide
good information for us to use in our weather routing software and
tactics.
dEmO
Sent: Wednesday, October 04, 2006 12:35 PM
Subject: Re: [Cal_Boats] use of traveller - Fin
ti… [at] ch2m.com <mailto:ti… [at] ch2m.com> wrote:
Fin -
race. The Wind Shear changes
leeway etc. The T.R.U.E. feature can even
less....
Re: Wind Sensors - Chris
slickbutfoxbuger2006-10-04 23:48
<ears pop up>
did i hear someone mention my old stomping ground;
The Columbia River?
as the wind kinda changes with the local topography around the
small islands and such, i would watch the pointing of the boats up-a-
head. the wind was coming from about 1/2 way between the ones on a
hard port tack and the ones on a hard starboard tack. or along the
shore (which is where i was, to stay out of the current), i looked
for the wind-shadow behind the pilling.
are there still a lot of Cal boats down there?
fiver
Oh Boy do i wish i had *had* a Cal-28 Flush-Deck in the 60's....
mile or
> so.
> Windex
> Water Ripples
> Cigar Smoke
> Land Smoke/ Flags
the
> boat
> tactics.
> dEmO
On
> timmothy.lessley@... <mailto:timmothy.lessley@...> wrote:
> Fin -
every
Software
> less....
Windex.
> Chris Campbell
Columbia Cals - Fiver
ti… [at] ch2m.com2006-10-05 00:02 UTC
Fiver,
I'm proud to say that there are a large number of Cals on the River.
I have a Cal 20 (Culo Bagnato) and Cal 9.2 (Freewind) on the river.
Our Cal 20 Fleet is possibly the strongest in the USA, with 43...
12-20 are lined up on race days.
There are many that are cruisers, from 25-36' and at least two Cal 46's.
We moved
our Cal 40 "Victoria!" to Richmond California in 2002. She is now my
parents boat,
and named "California Girl"
My favorite Cal on the River is a Cal 43... WOW, is she a beautiful and
well thought
out craft.
Pictures are at: http://www.sailingtexas.com/scal43a.html when she was
for sale
last year.
dEmO
Behalf Of slickbutfoxbuger
Sent: Wednesday, October 04, 2006 4:48 PM
Subject: [Cal_Boats] Re: Wind Sensors - Chris
<ears pop up>
The Columbia River?
fiver
mile or
> so.
> Windex
> Water Ripples
> Cigar Smoke
> Land Smoke/ Flags
the
> boat
> tactics.
> dEmO
> From: Ca… [at] yahoogroups.com <mailto:Cal_Boats%40yahoogroups.com>
[mailto:Ca… [at] yahoogroups.com <mailto:Cal_Boats%40yahoogroups.com> ]
On
> To: Ca… [at] yahoogroups.com <mailto:Cal_Boats%40yahoogroups.com>
> Fin -
every
Software
> less....
Windex.
> Chris Campbell
Re: Columbia Cals - Fiver
slickbutfoxbuger2006-10-05 00:33
it's always been a hot-spot for Cal-20's and 25's right there
just below *Saltys* by the airport on the oregon side of the
Columbia.
Cal-20's For Ever!
(and in every color)
fiver
PS. that is a nice looking 43......
> Fiver,
46's.
> We moved
> parents boat,
and
> well thought
> out craft.
was
> for sale
> last year.
> Cheers
> dEmO
On
> <ears pop up>
> The Columbia River?
a-
> fiver
> mile or
> > so.
> > Windex
> > Water Ripples
> > Cigar Smoke
> > Land Smoke/ Flags
> the
> > boat
Boat
> > tactics.
> > dEmO
40yahoogroups.com>
> On
40yahoogroups.com>
> > timmothy.lessley@ <mailto:timmothy.lessley@> wrote:
> > Fin -
> every
> Software
> > less....
> Windex.
> > Chris Campbell
Re: [Cal_Boats] Columbia Cals - Fiver
Michael Kennedy2006-10-05 01:40 UTC
Mike Jr and I flew up there in 2004 to buy that Cal 43. The guy had
convinced himself that the chain plates needed replacing. He might
well have been right but he placed them on the outside of the hull,
like a Westsail 32. It ruined the boat. It has been around the world
but had lots of cruising gear that was old and we didn't need. It had
a couple of potential problems but is beautiful, as you pointed out.
His price was too high (It has come way down since) and we would have
had to have repaired the holes in the topsides and probably have had
to paint the hull. We decided to look for a Cal 40. For cruising, it
is great. It has two heads and an aft cabin with a double and a
single berth. The other great advantage for California is that it
will fit in a 40 foot slip. I looked at a Cal 48 about 8 years ago
that was also beautiful but I would have had to leave it in Mexico
for years to get a 50 foot slip.
Had he lowered his price to what it is now (He may have sold it
since) I would have bought it and saved about $50,000 restoring the
Cal 40. No Transpac, though. The 43 weighed 22,000 pounds before all
the gear.
Mike Kennedy
Conquest Cal 40 # 96
On Oct 4, 2006, at 5:02 PM, <ti… [at] ch2m.com> wrote:
> Fiver,
> 46's. We moved
> my parents boat,
> and well thought
> out craft.
> was for sale
> last year.
> Cheers
> dEmO
> On Behalf Of slickbutfoxbuger
> <ears pop up>
> The Columbia River?
> fiver
> mile or
> > so.
> > Windex
> > Water Ripples
> > Cigar Smoke
> > Land Smoke/ Flags
> the
> > boat
> > tactics.
> > dEmO
> On
> > Fin -
> every
> Software
> > less....
> Windex.
> > Chris Campbell
Re: [Cal_Boats] Wind Sensors - Chris
Chris Campbell2006-10-05 13:30 UTC
Those of us who are follicle-impaired will have trouble with the "new
haircut" option. I had a haircut on somebody's back steps just before
working in a southern state back at the end of 1969 and another one
given by my dad in the kitchen before interviewing for my current job in
1994. I guess the next one's due in 2019.
So a few years back I went out and bought a whole ball of acrylic
knitting yarn in a bright red-orange color. It makes great tell-tales,
both on sails and on rigging. It'll probably be in use long after I've
expired, at the current rate of consumption. And it saves me the
indignity of a haircut.
