Double Stern Rail and Rail Seats
18 messages2006-09-27 14:26 through 2006-10-09 01:20
rua842006-09-27 14:26
My wife admired all the people seated in their stern seats mounted on their stern rails the last time we were out. She said she would like to have them on the Cal 28, which has a single stern rail. Looks like you need a double rail to properly attach the seats. What's the general consensus on these seats? It doesn't look like the ideal place for weight in the cockpit. Anyone make this change on their boat? Would it look funky moving from the single rail to the double? Is there a relatively cheap source for double stern rails out there? How about the seats. They look easy enough to make. Thanks for your thoughts. Bruce Stirling Gangfurd Cal 28 - Hull 82 http://www.stirlinglaw.com/cal28
Re: Double Stern Rail and Rail Seats
egiajack2006-09-27 15:16
What is it about women and those stern seats? My wife has talked about installing them on our boat. We chartered one of them Benes in the BVIs, and it had stern seats. I admit that they are a nice place to rest and be able to see everything. But Benes have a big wide back end. Lapworth was never big on big back ends, so there is quite a bit less room to use them effectively. Hunt's designs are a bit wider, but not by much. I've got double rails on my stern pulpit, so it could be done, but I'm not eager to clutter up my fairly small cockpit and helmsman space. My guess is that you could still do it with a single rail, just depends on where the vertical post is since you'd have to tie into it to stabilize the seat. The other attachments could be stainless straps that hang from the rail and strap to the seat. Good luck with all that. Jack Cal 31
RE: [Cal_Boats] Double Stern Rail and Rail Seats
r good2006-09-27 18:07 UTC
Our friend calls them "Mai Tai" seats. they are adding them to their C27 pop-top Reggie >From: "rua84" <br… [at] stirlinglaw.com> >Reply-To: Ca… [at] yahoogroups.com >To: Ca… [at] yahoogroups.com >Subject: [Cal_Boats] Double Stern Rail and Rail Seats >Date: Wed, 27 Sep 2006 14:26:08 -0000 > >My wife admired all the people seated in their stern seats mounted on >their stern rails the last time we were out. She said she would like >to have them on the Cal 28, which has a single stern rail. Looks like >you need a double rail to properly attach the seats. > >What's the general consensus on these seats? It doesn't look like the >ideal place for weight in the cockpit. Anyone make this change on >their boat? Would it look funky moving from the single rail to the >double? Is there a relatively cheap source for double stern rails out >there? How about the seats. They look easy enough to make. > >Thanks for your thoughts. > >Bruce Stirling >Gangfurd >Cal 28 - Hull 82 >http://www.stirlinglaw.com/cal28 > > > >
r good2006-09-27 18:08 UTC
It doesn't look like the >ideal place for weight in the cockpit. not normally occupied when racing. Reggie
RE: [Cal_Boats] Re: Double Stern Rail and Rail Seats
r good2006-09-27 18:10 UTC
Someone on th elist added tham to a Cal 31. The 31 has a relatively small cockpit so I believe the stern rail was re-designed so that the Mai Tai seats were suspended outside the cockpit. No sense giving up any cockpit space! Reggie >From: "egiajack" <jg… [at] erols.com> >Reply-To: Ca… [at] yahoogroups.com >To: Ca… [at] yahoogroups.com >Subject: [Cal_Boats] Re: Double Stern Rail and Rail Seats >Date: Wed, 27 Sep 2006 15:16:19 -0000 > >What is it about women and those stern seats? My wife has talked >about installing them on our boat. > >We chartered one of them Benes in the BVIs, and it had stern seats. >I admit that they are a nice place to rest and be able to see >everything. But Benes have a big wide back end. Lapworth was never >big on big back ends, so there is quite a bit less room to use them >effectively. Hunt's designs are a bit wider, but not by much. > >I've got double rails on my stern pulpit, so it could be done, but >I'm not eager to clutter up my fairly small cockpit and helmsman >space. > >My guess is that you could still do it with a single rail, just >depends on where the vertical post is since you'd have to tie into it >to stabilize the seat. The other attachments could be stainless >straps that hang from the rail and strap to the seat. > >Good luck with all that. > >Jack >Cal 31 > > >
Jon Conyers2006-09-27 21:30 UTC
I've got'em. Wife loves 'em. Cost about $200. Go to www.zarcor.com or check at a major boat show. They're called 'SternPerch'. ~Jon >From: "rua84" <br… [at] stirlinglaw.com> >Reply-To: Ca… [at] yahoogroups.com >To: Ca… [at] yahoogroups.com >Subject: [Cal_Boats] Double Stern Rail and Rail Seats >Date: Wed, 27 Sep 2006 14:26:08 -0000 > >My wife admired all the people seated in their stern seats mounted on >their stern rails the last time we were out. She said she would like >to have them on the Cal 28, which has a single stern rail. Looks like >you need a double rail to properly attach the seats. > >What's the general consensus on these seats? It doesn't look like the >ideal place for weight in the cockpit. Anyone make this change on >their boat? Would it look funky moving from the single rail to the >double? Is there a relatively cheap source for double stern rails out >there? How about the seats. They look easy enough to make. > >Thanks for your thoughts. > >Bruce Stirling >Gangfurd >Cal 28 - Hull 82 >http://www.stirlinglaw.com/cal28 > > > >
Keith and Susan2006-09-27 22:04
We had them in our last boat. I don't know if it's a woman thing, but it was my favorite place to sit. Susan Cal 40 Kismet --- In Ca… [at] yahoogroups.com, "rua84" <bruce@...> wrote: > > My wife admired all the people seated in their stern seats mounted on > their stern rails the last time we were out. She said she would like > to have them on the Cal 28, which has a single stern rail. Looks like > you need a double rail to properly attach the seats. > > What's the general consensus on these seats? It doesn't look like the > ideal place for weight in the cockpit. Anyone make this change on > their boat? Would it look funky moving from the single rail to the > double? Is there a relatively cheap source for double stern rails out > there? How about the seats. They look easy enough to make. > > Thanks for your thoughts. > > Bruce Stirling > Gangfurd > Cal 28 - Hull 82 > http://www.stirlinglaw.com/cal28 >
Rog Jones2006-09-27 22:16 UTC
They look swell on the Hunters. Hehehe. \Rog Cal 29+ #1 Swiss Navy Cal 2-30 #77 St. Lori's Comet _____ From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of rua84 Sent: Wednesday, September 27, 2006 7:26 AM To: Ca… [at] yahoogroups.com Subject: [Cal_Boats] Double Stern Rail and Rail Seats My wife admired all the people seated in their stern seats mounted on their stern rails the last time we were out. She said she would like to have them on the Cal 28, which has a single stern rail. Looks like you need a double rail to properly attach the seats. What's the general consensus on these seats? It doesn't look like the ideal place for weight in the cockpit. Anyone make this change on their boat? Would it look funky moving from the single rail to the double? Is there a relatively cheap source for double stern rails out there? How about the seats. They look easy enough to make. Thanks for your thoughts. Bruce Stirling Gangfurd Cal 28 - Hull 82 http://www.stirling <http://www.stirlinglaw.com/cal28> law.com/cal28
John Raxter ~~~~~_/)~~~~2006-09-27 22:46 UTC
Bruce, I know this is not a 28, it’s a 33, as someone else stated we had the second rail. It was an easy mod, home made with ¾” starboard, cut to match the rail contours and cockpit coaming. The seats actually get crowed by the lifesling, dingy motor and grill. And the bimini is nice during July and august sunshine. They are a great perch if you don’t like sitting facing backwards. Visibility is great as well See attached photo. (that’s my daughter driving BTW) John Cal 33 Oriental NC . <http://geo.yahoo.com/serv?s=97359714/grpId=16485695/grpspId=1600065792/msgI d=3460/stime=1159367664/nc1=3848610/nc2=2/nc3=3>
mtkennedy12006-09-27 22:55
--- In Ca… [at] yahoogroups.com, "Keith and Susan" <sshroyer@...> wrote: > > We had them in our last boat. I don't know if it's a woman thing, but > it was my favorite place to sit. > > Susan > Cal 40 Kismet My Cal 40 doesn't have a wide enough stern for women to sit in the stern pulpit. Just kidding. The new/old spinnakers will be flying with new center panels (and sail numbers) in a couple of weeks when we test sails. MIke Kennedy Conquest Cal 40 #96
slickbutfoxbuger2006-09-27 23:16
fiver aint putting one of them in her boat unless you can teach her to row, or trim-sail.... ********************* --- In Ca… [at] yahoogroups.com, "Jon Conyers" <leftend86@...> wrote: > > I've got'em. Wife loves 'em. Cost about $200. Go to www.zarcor.com or > check at a major boat show. They're called 'SternPerch'. > > ~Jon
kirkgrier2006-09-29 04:01
Hi, I've been lurking here for a few months. Just uploaded a photo of my 34's stern seat to the misc photo album/gallery. More photos of her at: http://kirkgrier.com/photos/sailing/00-our-new-boat-Mar-2006/index.html Kirk
mtkennedy12006-09-29 14:31
--- In Ca… [at] yahoogroups.com, "kirkgrier" <kgg@...> wrote: > > Hi, > > I've been lurking here for a few months. Just uploaded a photo of my > 34's stern seat to the misc photo album/gallery. > > More photos of her at: > > http://kirkgrier.com/photos/sailing/00-our-new-boat-Mar-2006/index.html > > Kirk > Nice looking boat. Beautiful job on he interior. Mike Kennedy Conquest Cal 40 # 96
rua842006-09-30 00:57
Kirk, Simply beautiful. That's the Cal-Cabo Rico look I've dreamed about. Where was the interior work done? Beautiful. If I left my wife see your photos, I'll be hearing about it for the rest of the year! The photos could take her mind off of the Beneteau she's dreaming about, though. Very nice, indeed! Thanks for sharing the photos. All other lurkers in possession of Cal-Cabo Ricos need to submit their photos. These kind of publicized photos will drive up the price of all Cal Boats! Very nice. Bruce --- In Ca… [at] yahoogroups.com, "mtkennedy1" <mtkennedy1@...> wrote: > > --- In Ca… [at] yahoogroups.com, "kirkgrier" <kgg@> wrote: > > > > Hi, > > > > I've been lurking here for a few months. Just uploaded a photo of my > > 34's stern seat to the misc photo album/gallery. > > > > More photos of her at: > > > > http://kirkgrier.com/photos/sailing/00-our-new-boat-Mar-2006/ index.html > > > > Kirk > > > > Nice looking boat. Beautiful job on he interior. > > Mike Kennedy > Conquest Cal 40 # 96 >
kirkgrier2006-09-30 03:59
Mike and Bruce, Thanks for the kind words. You see Footloose as I purchased her earlier this year. My understanding from the previous owner, is that the owner he bought it from was a cabinet maker, who did the work. Places where one would think to skip - underside of shelves - were done. The time commitment must have been incredible. The owners through the years kept nearly all the paperwork. Manuals and receipts for equipment long gone, berthing slips from where she visited, even the original Permanent Vessel Reg assigning the CF #'s dated Dec 1, 1975. Kinda of a connection back through the years. Until I moved her to Channel Islands Harbor (and Ventura West this weekend) she had been in San Diego. When I get the time I'll scan the owners manual and upload. I have the westerbeke manual and I think the vdrive trans too. They would take longer to scan ;> Kirk --- In Ca… [at] yahoogroups.com, "rua84" <bruce@...> wrote: > > Kirk, > > Simply beautiful. That's the Cal-Cabo Rico look I've dreamed about. > Where was the interior work done? Beautiful. If I left my wife see > your photos, I'll be hearing about it for the rest of the year! The > photos could take her mind off of the Beneteau she's dreaming about, > though. Very nice, indeed! Thanks for sharing the photos. All other > lurkers in possession of Cal-Cabo Ricos need to submit their photos. > These kind of publicized photos will drive up the price of all Cal > Boats! Very nice. > > Bruce > > --- In Ca… [at] yahoogroups.com, "mtkennedy1" <mtkennedy1@> wrote: > > > > --- In Ca… [at] yahoogroups.com, "kirkgrier" <kgg@> wrote: > > > > > > Hi, > > > > > > I've been lurking here for a few months. Just uploaded a photo of > my > > > 34's stern seat to the misc photo album/gallery. > > > > > > More photos of her at: > > > > > > http://kirkgrier.com/photos/sailing/00-our-new-boat-Mar-2006/ > index.html > > > > > > Kirk > > > > > > > Nice looking boat. Beautiful job on he interior. > > > > Mike Kennedy > > Conquest Cal 40 # 96 > > >
Re: Cal-34 *Footloose* (was) Double Stern Rail and Rail Seats
slickbutfoxbuger2006-09-30 04:38
i just had a look at "FootLoose" and that is quite a Boat! i wouldn't imagine that the wood trimmed port-lights are stock on that boat. nor the custom handrails, mid-boom sheeting, or the nice compass binical. i also noted the outfit of electronics the boat had. *Furuno* radar with self-leveling antenna mounting. a nice *NT* Magellan chartplotter. and was that an autohelm trydata on the starboard side in the aft end of the cockpit that i saw? and looking at the mast-head; the standard wind-speed and direction remote sensors. and now, the inside of the cabin simply must be mentioned. Very, very nice....... fiver ************************** --- In Ca… [at] yahoogroups.com, "rua84" <bruce@...> wrote: > > Kirk, > > Simply beautiful. That's the Cal-Cabo Rico look I've dreamed about. > Where was the interior work done? Beautiful. If I left my wife see > your photos, I'll be hearing about it for the rest of the year! The > photos could take her mind off of the Beneteau she's dreaming about, > though. Very nice, indeed! Thanks for sharing the photos. All other > lurkers in possession of Cal-Cabo Ricos need to submit their photos. > These kind of publicized photos will drive up the price of all Cal > Boats! Very nice. > > Bruce > > --- In Ca… [at] yahoogroups.com, "mtkennedy1" <mtkennedy1@> wrote: > > > > --- In Ca… [at] yahoogroups.com, "kirkgrier" <kgg@> wrote: > > > > > > Hi, > > > > > > I've been lurking here for a few months. Just uploaded a photo of > my > > > 34's stern seat to the misc photo album/gallery. > > > > > > More photos of her at: > > > > > > http://kirkgrier.com/photos/sailing/00-our-new-boat-Mar-2006/ > index.html > > > > > > Kirk > > > > > > > Nice looking boat. Beautiful job on he interior. > > > > Mike Kennedy > > Conquest Cal 40 # 96 > > >
kirkgrier2006-10-01 03:39
Hi, Pretty much got it. That is an Raymarine 4000 autopilot. The Furuno is a 16 mile 1623, the chartplotter is a Magellan 6500. Signet depth and boat speed. She doesn't have wind speed and direction though. OTOH she does have a vacuflush head crammed into what was the port side hanging locker, and CNG stove/oven, which makes senior management (my wife) happy. Mostly I am overjoyed to be a boat owner again. Especially a Cal. It's been almost 25 years since my first boat - 1965 Cal 25. And nearly 15 years since my last one, an Ericson 35. Kirk --- In Ca… [at] yahoogroups.com, "slickbutfoxbuger" <SlickButFoxBuger@...> wrote: > > i just had a look at "FootLoose" > and that is quite a Boat! > > i wouldn't imagine that the wood trimmed port-lights are stock on > that boat. nor the custom handrails, mid-boom sheeting, or the nice > compass binical. i also noted the outfit of electronics the boat had. > *Furuno* radar with self-leveling antenna mounting. a nice *NT* > Magellan chartplotter. and was that an autohelm trydata on the > starboard side in the aft end of the cockpit that i saw? and looking > at the mast-head; the standard wind-speed and direction remote > sensors. > and now, the inside of the cabin simply must be mentioned. Very, > very nice....... > > fiver > > > ************************** > --- In Ca… [at] yahoogroups.com, "rua84" <bruce@> wrote: > > > > Kirk, > > > > Simply beautiful. That's the Cal-Cabo Rico look I've dreamed > about. > > Where was the interior work done? Beautiful. If I left my wife > see > > your photos, I'll be hearing about it for the rest of the year! > The > > photos could take her mind off of the Beneteau she's dreaming > about, > > though. Very nice, indeed! Thanks for sharing the photos. All > other > > lurkers in possession of Cal-Cabo Ricos need to submit their > photos. > > These kind of publicized photos will drive up the price of all Cal > > Boats! Very nice. > > > > Bruce > > > > --- In Ca… [at] yahoogroups.com, "mtkennedy1" <mtkennedy1@> wrote: > > > > > > --- In Ca… [at] yahoogroups.com, "kirkgrier" <kgg@> wrote: > > > > > > > > Hi, > > > > > > > > I've been lurking here for a few months. Just uploaded a photo > of > > my > > > > 34's stern seat to the misc photo album/gallery. > > > > > > > > More photos of her at: > > > > > > > > http://kirkgrier.com/photos/sailing/00-our-new-boat-Mar-2006/ > > index.html > > > > > > > > Kirk > > > > > > > > > > Nice looking boat. Beautiful job on he interior. > > > > > > Mike Kennedy > > > Conquest Cal 40 # 96 > > > > > >
jenfreespirit2006-10-09 01:20
--- In Ca… [at] yahoogroups.com, "kirkgrier" <kgg@...> wrote: > > Hi, > > I've been lurking here for a few months. Just uploaded a photo of my > 34's stern seat to the misc photo album/gallery. > > More photos of her at: > > http://kirkgrier.com/photos/sailing/00-our-new-boat-Mar- 2006/index.html > > Kirk > Hello, Kirk.. My name is Jen, my husband is Tim and we JUST purchased a '68 Cal 34...and I happened upon this thread with the link to your pictures and just about peed my pants!..(sorry if that's TMI) ...I couldn't believe how beautiful a boat like ours COULD BE! We got a lot of boat for very little money..($9,000)...but WOW...how cool it COULD be was extremely inspiring! Thank you for sharing those pictures. Your son looks like he loves sailing, also. I have a son who just turned 9 who is learning to love it..(on our little boat---a 21ft Spirit--he was afraid to heel.) I also have a severely disabled 6 yr old who LOVES to heel! Thanks again for sharing your pictures, we are getting a whole lot of great ideas!
