5 messages2006-10-09 19:01 through 2006-10-10 02:17 UTC
Flushing Saltwater From Honda Outboard
ddaye25632006-10-09 19:01
We've gotten our 10+ year old Honda 9.9 long shaft for our newly
acquired 70's Cal 25, back from its initial inspection & lube
servicing. Cooling water had only been dribbling but the tech said the
engine wasn't overheating, just had some salt buildup easily blown
out. It runs and pumps like a champ now, easily pushing us at hull
speed with half throttle.
Took our first real sail late yesterday afternoon in 2-5 kts within
our small bay, up to 15-18 when we peaked out into the open Puget Sound.
It's my first real sail on any Cal despite having been around many
back in their hayday. I'm _mightily_ impressed, from responsive
handling in very light air and slow speeds, to the kind way it takes
gusts that are more than the hoisted sail plan is meant for.
But back at the dock I couldn't manage to do a proper freshwater
flushing.
At the bottom midline of the shaft, just above the prop on each side,
are two small black fittings that seem to be water intakes. The manual
identifies them as such. There's no permanent hose connector shown as
an option in the manual. I've got a cheap 3rd party clamp-on hose
connector with rectangular rubber pads, for supplying fresh water, and
we turned the hose on full power. But when the motor was tilted with
the prop just above the water, it wasn't pumping water, and when we
tilted it the rest of the way down leaving the hose running hard, it
pumped normally again but the stream still had a noticeable salty taste.
I saw just above the lowest cavitation plate there are a couple more
small holes near the fwd side of the shaft. We tried putting the clamp
over those but still got salt water output.
Fortunately we're docked at the head of an inlet fed by fresh water,
so the water is only mildly salty. Still I need to be able to rinse
the motor.
Any ideas what I'm missing here? It's hard to believe there's enough
volume inside to hold more than 5-10 seconds of salt water before the
fresh should be coming out.
Re: [Cal_Boats] Flushing Saltwater From Honda Outboard
Chris Campbell2006-10-09 19:41 UTC
> flushing.
Maybe some salty folks have better advice, but most outboards use a
rubber impeller that seals against the pump housing and flexes to
displace the water at one point in its rotation. This is basically "in
series" with the cooling water intake and outlet, so I'm guessing that
your flushing hose didn't have enough pressure to push past the impeller
vanes.
Why not see if there's a Honda web site with flushing instructions?
RE: [Cal_Boats] Flushing Saltwater From Honda Outboard
Bruce Stirling2006-10-09 21:55 UTC
The location on the Nissan 9.8 outboard is very hard to get to from out
boat. Another guy suggested getting a plastic garbage can and placing it
around the prop as it sits in the water. Fill the garbage can with fresh
water and run the boat until only fresh warter comes out of the engine.
This is what I must do. Here is a photo of my set up online:
http://www.stirlinglaw.com/cal28/cal28photos/Cal%2028%205.jpg
I just run the engine in neutral, no damage to the garbage can.
Bruce Stirling
Of ddaye2563
Sent: Monday, October 09, 2006 12:02 PM
Subject: [Cal_Boats] Flushing Saltwater From Honda Outboard
flushing.
the motor.
Bob Ellison2006-10-09 21:55 UTC
I had a Honda 5 on our previous boat. It had a flushing attachment that
screwed into a hole on the lower unit. On ours the screw was missing, so
you could see the threads. The hole was about the size as the gear oil
drain and fill. I gave the fitting to my father for his Honda 10 when we
sold the boat. I don't think his has the fitting in the same location.
I'll try to see if he figured it out.
Bob
Sent: Monday, October 09, 2006 3:01 PM
> flushing.
> the motor.
> Yahoo! Groups Links
Paulson2006-10-10 02:17 UTC
We flush our outboard in a 5 gallon bucket
works great
Dave Paulson
Channel Islands
Ca
Sent: Monday, October 09, 2006 2:55 PM
Subject: RE: [Cal_Boats] Flushing Saltwater From Honda Outboard
The location on the Nissan 9.8 outboard is very hard to get to from out boat. Another guy suggested getting a plastic garbage can and placing it around the prop as it sits in the water. Fill the garbage can with fresh water and run the boat until only fresh warter comes out of the engine. This is what I must do. Here is a photo of my set up online:
Bruce Stirling
-----Original Message-----
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com]On Behalf Of ddaye2563
flushing.
the motor.
