corrosion control
corrosion control
6 messages2006-10-14 15:31 UTCthrough 2006-10-18 13:26 UTC
corrosion control
r good2006-10-14 15:31 UTC
>I take > a can of WD-40 with me every now and then into the engine compartment and >spray down just about everything that is likely to rust or corrode. WD-40 leaves very little protective coating after it dries out. Buy a gallon can of WD-40, ad a couple ounces of good quality oil to it. Shake well. Dispense with a spray bottle. The slight oil coating left behind will enhance the protective ability many times over. Learned from a machine shop where they ground cams and cranks which sometimes sat on the shelf for a long time. After adopting this method of protection, they no longer had a problem with the development of reddish-brown patina. Reggie
Re: [Cal_Boats] corrosion control
Chris Campbell2006-10-17 14:22 UTC
r good wrote: > > > WD-40 leaves very little protective coating after it dries out. Buy a > gallon can of WD-40, ad a couple ounces of good quality oil to it. Shake > well. Dispense with a spray bottle. The slight oil coating left behind > will enhance the protective ability many times over. > On this general subject, I used to be able to buy a wax-based automotive rustproofing in an aerosol spray can. It had a long plastic tube and a little nozzle at the end of that, so you could reach into enclosed panels. The coating was waxy-greasy and retained some flexibility. The retailer went out of business and I didn't keep my last can so I don't know the name of the stuff. Does anybody know the name of a similar product? I've been hunting for some time. Chris Campbell
Jonathan Brush2006-10-17 15:13 UTC
Chris: I would go to Wurth at http://uucurl.com/x.php?p=2093. Check out their "Body Wax" (no not that kind). Might be what you are looking for. I haven't used this particular product but have used their "Rost-Off" (their version of penetrating oil) with good results. Jon Brush Cal 21 #508 On 10/17/06, Chris Campbell <cl… [at] charterinternet.com> wrote: > > r good wrote: > > > WD-40 leaves very little protective coating after it dries out. Buy a > gallon can of WD-40, ad a couple ounces of good quality oil to it. Shake > well. Dispense with a spray bottle. The slight oil coating left behind > will enhance the protective ability many times over. > > > > > > > > On this general subject, I used to be able to buy a wax-based automotive > rustproofing in an aerosol spray can. It had a long plastic tube and a > little nozzle at the end of that, so you could reach into enclosed panels. > The coating was waxy-greasy and retained some flexibility. > > The retailer went out of business and I didn't keep my last can so I don't > know the name of the stuff. Does anybody know the name of a similar > product? I've been hunting for some time. > > Chris Campbell > > >
Chris Campbell2006-10-17 21:27 UTC
Jonathan Brush wrote: > Chris: > I would go to Wurth at http://uucurl.com/x.php?p=2093 > <http://uucurl.com/x.php?p=2093>. Check out their "Body Wax" (no not > that kind). Might be what you are looking for. I haven't used this > particular product but have used their "Rost-Off" (their version of > penetrating oil) with good results. Thanks, Jon. I e-mailed them about their "Body Protection" aerosol spray product. Chris Campbell
Jonathan Brush2006-10-18 00:32 UTC
Chris, Let us know what you find out. Jon Brush On 10/17/06, Chris Campbell <cl… [at] charterinternet.com> wrote: > > Jonathan Brush wrote: > > Chris: > I would go to Wurth at http://uucurl.com/x.php?p=2093. Check out their > "Body Wax" (no not that kind). Might be what you are looking for. I haven't > used this particular product but have used their "Rost-Off" (their version > of penetrating oil) with good results. > > > > > > Thanks, Jon. I e-mailed them about their "Body Protection" aerosol spray > product. > > Chris Campbell > > >
RE: [Cal_Boats] corrosion control
Downing, Thomas2006-10-18 13:26 UTC
You could try any decent machine tool shop. There are products for just this use - protecting bits when not in use. td From: Ca… [at] yahoogroups.com on behalf of Chris Campbell Sent: Tue 10/17/2006 10:22 AM To: Ca… [at] yahoogroups.com Subject: Re: [Cal_Boats] corrosion control r good wrote: > > > WD-40 leaves very little protective coating after it dries out. Buy a > gallon can of WD-40, ad a couple ounces of good quality oil to it. Shake > well. Dispense with a spray bottle. The slight oil coating left behind > will enhance the protective ability many times over. > On this general subject, I used to be able to buy a wax-based automotive rustproofing in an aerosol spray can. It had a long plastic tube and a little nozzle at the end of that, so you could reach into enclosed panels. The coating was waxy-greasy and retained some flexibility. The retailer went out of business and I didn't keep my last can so I don't know the name of the stuff. Does anybody know the name of a similar product? I've been hunting for some time. Chris Campbell DISCLAIMER: Important Notice ************************************************* This e-mail may contain information that is confidential, privileged or otherwise protected from disclosure. If you are not an intended recipient of this e-mail, do not duplicate or redistribute it by any means. Please delete it and any attachments and notify the sender that you have received it in error. Unintended recipients are prohibited from taking action on the basis of information in this e-mail.E-mail messages may contain computer viruses or other defects, may not be accurately replicated on other systems, or may be intercepted, deleted or interfered with without the knowledge of the sender or the intended recipient. If you are not comfortable with the risks associated with e-mail messages, you may decide not to use e-mail to communicate with IPC. IPC reserves the right, to the extent and under circumstances permitted by applicable law, to retain, monitor and intercept e-mail messages to and from its systems.
