teak rails
Michael Kennedy2006-10-21 19:05 UTC
Shroyer wrote:
Hi Cal sailors' - many of us have a teak deck rail covering the leaky
hull
to deck seam. The teak rail will need to be removed to recaulk or
fiberglass the seam. The big question is after the leak repair do we
spend
time and money restoring the teak or use an alternative maintenance free
material. Does one even exist?
Kennedy wrote:
I went through this for months and decided to keep the teak. To
replace the rails and use the Dancing Bear alternative, I think you
have to seal the joint and that turns out to be a big job. It was
more expensive for me to do that than take off the old rails and seal
all the holes and the joint with epoxy, then replace new rails and
bed them with 5200. I looked at aluminum toe rails and they are very
expensive without the labor being included.
Shroyer wrote :
> I was fortunate to see the "teak free" Dancing Bear, a Cal 40 owned
> by Mark
> Schrader. A picture of Dancing Bear is at
> /www.transpacificyc.org/php-entry-sys/tp05-yacht_bio.php?
> yacht_id=129. Mark
> has replaced the teak with black King star board and it looks great,
> requires zero maintenance and easily works with wood working
> tools. King
> starboard prices, and a good description of it's uses, can be found at
> /www.wps.on.ca/plastic4boats/starboard.htm Mark also replaced the
> teak
> cabin rails with SS rails.
> After much soul searching I have decided to give up my slavery to
> oiled teak
> and go with black King starboard for the deck rail. I thank Mark
> for leading the way. I hope this information can be of use to some
> of you out there.
Kennedy wrote:
I talked to Mark and thought hard about it. I still think the teak is
cheaper than the alternative and I really researched it. It helps to
have a carpenter who has done the job on other 40s. The guy I'm going
to use did Fin Bevan's rails and has refinished but not rebedded
those on Psyche. That is a project being planned. The rails look good
but the joint leaks.
My teak job will be about $5,000. The glass joint job would have
required a haul-out and was close to $ 15,000 with everything. I also
changed to steel grab rails and they are available at Jamestown
Distributers for a couple of hundred dollars for all four rails, two
five foot and two two foot.
MIke Kennedy
Conquest Cal 40 96
> Keith Shroyer
> Cal 40 Kismet.
RE: [Cal_Boats] teak rails
John Raxter ~~~~~_/)~~~~2006-10-23 11:59 UTC
One of our original List members, Tom Leonard, removed all the teak from his
Cal 31 and replaced it with the "trex" lumber used for outdoor decks. His
claim was the material would mill as easy as real wood, and the grey color
imitated aged teak. There used to be photos in one of the FTP sites, but
the file transfers may have lost them over the transfers.
I remember from the photos, a great looking alternative for the maintenance
free trim. Pricing was well below Teak or Starboard materials as well.
John Raxter
Cal 33
Of Michael Kennedy
Sent: Saturday, October 21, 2006 3:05 PM
Subject: [Cal_Boats] teak rails
Shroyer wrote:
Hi Cal sailors' - many of us have a teak deck rail covering the leaky hull
fiberglass the seam. The big question is after the leak repair do we spend
Kennedy wrote:
I went through this for months and decided to keep the teak. To replace the
rails and use the Dancing Bear alternative, I think you have to seal the
joint and that turns out to be a big job. It was more expensive for me to do
that than take off the old rails and seal all the holes and the joint with
epoxy, then replace new rails and bed them with 5200. I looked at aluminum
toe rails and they are very expensive without the labor being included.
Shroyer wrote :
I was fortunate to see the "teak free" Dancing Bear, a Cal 40 owned by Mark
/www.transpacificyc.org/php-entry-sys/tp05-yacht_bio.php?yacht_id=129. Mark
requires zero maintenance and easily works with wood working tools. King
/www.wps.on.ca/plastic4boats/starboard.htm Mark also replaced the teak
After much soul searching I have decided to give up my slavery to oiled teak
and go with black King starboard for the deck rail. I thank Mark for leading
the way. I hope this information can be of use to some of you out there.
cheaper than the alternative and I really researched it. It helps to have a
carpenter who has done the job on other 40s. The guy I'm going to use did
Fin Bevan's rails and has refinished but not rebedded those on Psyche. That
is a project being planned. The rails look good but the joint leaks.
My teak job will be about $5,000. The glass joint job would have required a
haul-out and was close to $ 15,000 with everything. I also changed to steel
grab rails and they are available at Jamestown Distributers for a couple of
hundred dollars for all four rails, two five foot and two two foot.
MIke Kennedy
Conquest Cal 40 96
Keith Shroyer
Cal 40 Kismet.
