4 messages2006-10-23 15:42 UTCthrough 2006-10-23 18:32
Re: Cal 39-2 Mast Step Leaks
James Williams2006-10-23 15:42 UTC
Bob - It almost sounds as though you're saying the mast is deck stepped, but you can't mean that. ... We had a lot of leaking around our mast, and we couldn't get a boot to hold. So we used foam (not starbrite), which has worked well for two years and then cracked this past year and has started leaking a little again.
We're going to try to solve the problem differently. We're doing new standing rigging, switching out metal for rope halyards, and putting in new instruments and radar, and since pulling the mast is part of this project, we're also having a custom stainless collar made which will take a good mast boot.
Rather than "jump" on your deck to check for moisture, just use a top-quality moisture meter.
Jim Williams
"Spindrift" Cal 39-2 (1980)
Re: [Cal_Boats] Re: Cal 39-2 Mast Step Leaks
Bob Walden2006-10-23 16:45 UTC
Hi Jim;
The mast is keel-stepped, but also has a welded flange that sits on the deck and is through-bolted, instead of having partners and a mast boot.
What I'm going to do for now is to pull each of the bolts one at a time and re-caulk them, run a bead of caulk around the flange base, and finish up with a strip of boot tape over the caulk after it cures. This will be a stopgap for this winter but should keep things dry.
bw
Sent: Monday, October 23, 2006 8:42 AM
Subject: [Cal_Boats] Re: Cal 39-2 Mast Step Leaks
Jim Williams
Carl2006-10-23 17:16 UTC
Be careful when pulling the mast. The foam could be stuck real good. Don't
ask how I know!!!
Carl
Nauta
> boot.
> Jim Williams
Carl
mtkennedy12006-10-23 18:32
> ask how I know!!!
> Carl
> Nauta
Spar tite is applied with Vasoline on the mast and the collar to help slide it out if the mast is
pulled. If there are leaks through the seal, I've been advised to put more Vasoline along the
top edges.
Mike Kennedy
Conquest Cal 40 # 96
