4 messages2006-10-26 04:50 through 2006-10-26 15:30
Re: Where is Hull No on Cal 28 - And Is This A Coil, or What? See photos
slickbutfoxbuger2006-10-26 04:50
Yo, Bruce!
that's just got to be in the lazaret on the port, or the
transom.
i just had a chance to look at the pictures, and i just noticed
that you have a VDO-Marine knot-log. does it work? the transducer-end
of those things are sort-of rare. i just got my self several of the
VDO-Marine 4" analog clocks. but i am still trying to get one of the
old style matching VDO-Marine ADIS 360 Compass. i have a new 4" VDO-
Marine rudder angle indicator and sender unit. i like the line
because i can make it interface with the ST-50 seatalk stuff; and i
can make that work with all the NMEA-0180 and 0183 stuff.
5er
--- In Ca… [at] yahoogroups.com, "Bruce Stirling" <bruce@...> wrote:
> Another Cal 28 owner wrote asking if I knew where the hull number
was
> located. I have a photo of mine, but never located it on the boat,
yet.
> Anyone know where it is to be found? I suspect under sink, sette,
or in the
> rear storage compartment. See photo.
> Also, I ran across this (see photo) and wonder what it is. Looks
like some
> kind of coil. If it is a remnant of my old Atomic 4 inboard, I can
pull
> this out, too, right?
> Thanks,
> Bruce Stirling
RE: [Cal_Boats] Re: Where is Hull No on Cal 28 - And Is This A Coil, or What? See photos
Bruce Stirling2006-10-26 11:05 UTC
Yo, Bruce!
5er
I do? Is that the coil-like thing? Or are you looking at a different
photo? There is a knot meter located next to my compass, but I have yet to
see it work. Then again, I may not know how to turn it on! My brother,
Debbie, and I flipped every switch we found and never noticed anything "come
on." Then again, we were probably sitting at the dock at the time. . . . We
thought it was once connected to the old removed engine and/or we figured it
probably had something to do with unfouling the bottom. I think the knot
meter has an odometer, of sorts, built into it, too. Or was that a hour log
for the motor? Can't remember. After we had a guy dive the boat, nothing
changed. I just got in contact with the previous owner, who'd donated the
boat to Boat Angels, who sold it on Ebay. I will try to track down a few
things from him. He just offered to sell me the spinnaker pole found in the
photos of the boat. I thought someone ripped it off the boat in Oceanside
before I got there to pick it up. Said he might have a spinnaker, too, but
doesn't know their value. Any ideas on reasonable used values?
There are several knobs and cables located in the cockpit that once linked
to the inboard Atomic 4. I plan to haul them out one day and glass over the
holes. If you are interested in the old knobs, you can have them when I rip
them out. I think there is a "C" in the middle of the knob. Didn't know if
that was for "choke" or "Cal." If the knot meter doesn't work and I find
something else to put in the hole, you can have that, too, assuming you can
fix it. Several small holes where instruments once lived. A second marine
battery lives where the inboard was once mounted, under the mahogany engine
cover. I'd like to take the cover out, too, and reclaim the space. Don't
know exactly what to do with placement of the second battery. I always hate
to lose any wood, but this is kind of boxy, almost looks home made. Looks
like someone whacked off a leg of the companionway ladder, and the whacked
end rests on the engine compartment. Does this sound like original work to
those who knew the Cal 28 back in the day? If I take out the box, I need a
new ladder, too. Consequently, everything may just remain as is.
was
yet.
or in the
like some
pull
> Thanks,
> Bruce Stirling
Re: [Cal_Boats] Re: Where is Hull No on Cal 28 - And Is This A Coil, or What? See photos
Chris Campbell2006-10-26 14:10 UTC
slickbutfoxbuger wrote:
> i just noticed
My other boat has a VDO mechanical knotmeter/log that I installed in
about 1971. Actually, it's not a knotmeter because it's a MPH model
(that's why it's on sale). But because of the location of the
transducer, it's about as accurate when you read it in knots as when you
take the data to be MPH. One tack is fast, the other is slow, and
things kinda-sorta average out more or less. For accuracy, I'll choose
the GPS. We don't have a lot of current in the Great Lakes, usually, so
the difference between speed through the water and speed over ground
isn't as big a deal as elsewhere.
Does anybody service these old VDO mechanical devices? The pointer on
mine got bent a little bit when the yard guy turned the pressure washer
on it and pegged it once.
Has anybody ever suffered a failure of the long plastic hose that the
rotating drive cable runs inside of? You've got to use very large
radiused bends to avoid friction, so the run of the hose is quite long.
The transducer/drive unit is underwater (of course) and the plastic hose
is what keeps the water out of the boat. It's always kept me slightly
nervous to have this long potential leak inside my hull. There are lots
of what-ifs.
The device has been really durable and is blessedly non-electric, so
it's a true low-maintenance item.
slickbutfoxbuger2006-10-26 15:30
you have one of the propeller jobs, Chris;
VDO made both those and the paddle-wheel type in their VDO-
Marine line for a while. the sender unites for both are very hard to
find in new condition. but the gauges can be had everywhere. the ones
for the paddle-wheel measure in knots as i remember. and it is those
that i can interface with seatalk. the only place i have ever seen a
new transducer of either type is on e-bay......
fiver
--- In Ca… [at] yahoogroups.com, Chris Campbell <clcampbell@...>
> > i just noticed
end
in
model
when you
choose
usually, so
ground
on
washer
the
long.
hose
slightly
lots
> of what-ifs.
so
> Chris Campbell
