RE: [Cal_Boats] Bow light?
One other point to check. On my Cal 27 the failure was due to corrosion at the
point where the wiring is attached to the light fixture at the BACK of the fixture.
I had to remove the fixture from the mast, take off the wires, sand the rings
crimped onto the wire, and the nuts that held them on. Then re-assemble.
That I didn't drop any of the little bits is quite possibly my proudest sailing accomplisment.
td
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com]On Behalf Of glen fromm
Sent: Sunday, November 12, 2006 10:29 PM
Subject: Re: [Cal_Boats] Bow light?
It's actually a "steaming light", it should be on, along with your navigation lights, if your motoring. First check that there is power to the switch and that a fuse hasn't blown, also check that power is going through the switch in the "on "position. If there is power, next check the wires at the base of the mast (if that's possible). If your getting power there, get a boson's chair and with the help of someone you trust and your best halyard, carefully go up the mast with a new bulb, fine sand paper, a screwdriver (tie a lanyard between you and the screwdriver so that if you drop it, it doesn't hit the person on deck that is holding the halyard that is keeping you up the mast...you see where I'm going with this?) and a test light. Once up the mast you should start breathing again, remove the lens, test the contacts with the test light (and the switch on) if there is power, remove the old bulb, clean the contacts with the sand paper and install the new bulb.
Of course if the problem is up top, other options may be partially stepping the mast (depending on the level of difficulty) or finding a nearby marina with a highboy lift and paying someone a few bucks to do it for you. Riggers are about $65 an hour and a good boson's chair is about $50. unless you can borrow one.
Glen Fromm
Cal 3-34
Moon Shadow
To: Cal_Boats@yahoogrou <mailto:Ca… [at] yahoogroups.com> ps.com
Sent: Sunday, November 12, 2006 7:38 PM
Subject: [Cal_Boats] Bow light?
There's a forward facing white light attached to my mast about 6'
above the spreaders. The switch on my circuit panel that's supposed
to turn it on is labeled "Bow Light". Is that the correct name for
this light?
This very same light won't come on. I'm hoping it's just a burned out
bulb. How the heck do I get up there to find out?
Matt
Cal 3-27
DISCLAIMER:
