13 messages2006-11-13 00:38 through 2006-11-20 19:09
Bow light?
mwrohde2006-11-13 00:38
There's a forward facing white light attached to my mast about 6'
above the spreaders. The switch on my circuit panel that's supposed
to turn it on is labeled "Bow Light". Is that the correct name for
this light?
This very same light won't come on. I'm hoping it's just a burned out
bulb. How the heck do I get up there to find out?
Matt
Cal 3-27
Re: Bow light?
mtkennedy12006-11-13 01:43
> this light?
Yes. It could also be called "steaming light" as it is used when under
power. Look up the rules of the road light rules.
Bosun's chair with a kid in it. What else are kids for ? If that's not
it, the wiring probably has a break, maybe at the connector where the
mast wires connect.
Mike Kennedy
Conquest cal 40 # 96
> Thanks,
> Matt
> Cal 3-27
Re: [Cal_Boats] Bow light?
glen fromm2006-11-13 03:28 UTC
It's actually a "steaming light", it should be on, along with your navigation lights, if your motoring. First check that there is power to the switch and that a fuse hasn't blown, also check that power is going through the switch in the "on "position. If there is power, next check the wires at the base of the mast (if that's possible). If your getting power there, get a boson's chair and with the help of someone you trust and your best halyard, carefully go up the mast with a new bulb, fine sand paper, a screwdriver (tie a lanyard between you and the screwdriver so that if you drop it, it doesn't hit the person on deck that is holding the halyard that is keeping you up the mast...you see where I'm going with this?) and a test light. Once up the mast you should start breathing again, remove the lens, test the contacts with the test light (and the switch on) if there is power, remove the old bulb, clean the contacts with the sand paper and install the new bulb.
Of course if the problem is up top, other options may be partially stepping the mast (depending on the level of difficulty) or finding a nearby marina with a highboy lift and paying someone a few bucks to do it for you. Riggers are about $65 an hour and a good boson's chair is about $50. unless you can borrow one.
Glen Fromm
Cal 3-34
Moon Shadow
Sent: Sunday, November 12, 2006 7:38 PM
Subject: [Cal_Boats] Bow light?
this light?
Matt
Cal 3-27
Chris Campbell2006-11-13 17:10 UTC
There's a contact cleaner called "DeOxit" used in electronic stuff that
removes oxidation and prevents it fro recurring. It might be worth
applying some of this to the contacts for longer-term function. I've
not seen reports on how it works in a marine environment.
RE: [Cal_Boats] Re: Bow light?
Husar Charlie2006-11-14 14:00 UTC
A few items on the bulb. Be prepared to clean out a corroded socket.
Have an ohmmeter along for a continuity check wit hswitch off (or do a
voltage check with the switch on). Usr the old Timmo lanocote trick for
bulb install. Mike meant to say "a reasonably smart kid", however, the
kid cannot be so smart as to know not to go up there.
Also, I always use bowlines instead of shackles for ties on bosuns
chairs, and use a second halyard for a safety when I find someone dumb
enough to climb the mast.
Behalf Of mtkennedy1
Sent: Sunday, November 12, 2006 8:43 PM
Subject: [Cal_Boats] Re: Bow light?
> this light?
mast wires connect.
Mike Kennedy
> Thanks,
> Matt
> Cal 3-27
Yahoo! Groups Links
Re: Bow light?
mtkennedy12006-11-14 16:26
--- In Ca… [at] yahoogroups.com, "Husar Charlie" <husar_charlie@...>
We always kept a football helmet wth the bosun's chair. I've had kids
dumb enough to go aloft under way when we had halyard problems. I had
hem wear a football helmet when aloft in the chair under way.
Shouldn't be necessary in the slip or on the mooring. :) That was to
keep them from getting any dumber. I also had a chair with a shackle
on the bottom to keep the chair from swinging around.
Mike Kennedy
Conquest Cal 40 # 96
> Cheers
> Charlie
Re: [Cal_Boats] Re: Bow light?
Chris Campbell2006-11-14 18:40 UTC
mtkennedy1 wrote:
> That was to
I've been wearing a hat for years and it doesn't seem to have prevented
evaporation of knowledge in my case.
Re: Bow light?
mtkennedy12006-11-14 19:33
--- In Ca… [at] yahoogroups.com, Chris Campbell <clcampbell@...> wrote:
> mtkennedy1 wrote:
> > That was to
Whacking your skull against the mast 40 feet in the air in rough seas
will speed up the process. I've actually got movie film of Davey, Timm
Lessley's pal, at the mast head in the chair when the spinnaker
shackle opened and we had to round up to avoid sailing over it. That
was about 1,000 miles out and he held on for dear life for a few
minutes until things settled down.
I have read about, but wasn't present for, a roundup in the Bay with
Commodore Tompkins at the masthead of a boat he was crewing on. That
was about 30 years ago when he and I were both in better shape. I
guess he was uncrossing halyards (like Davey was) when they broached
and rounded up. I expect the boat comes back up more slowly with a 170
pound crewman at the masthead.
Mike Kennedy
> Chris Campbell
Helmets
ti… [at] ch2m.com2006-11-14 20:48 UTC
I've been experimenting with different helmets since 1984, for sailing.
I still have not located a perfect choice, but my latest is a "scooter"
shorty helmet, from Taiwan. DOT bump protection, Warm, Waterproof, and
floats.
Our last race, Winners invitational, I got lots of "funny remarks" for
wearing
it. During the race, one of the competitors, had two head injuries, from
boom smacks, torn scalps... after the race... "hey, let me see that hat
of yours."
I raced bicycles in the 1970's, and helmets were suggested not
mandatory,
We didn't wear them, as the braincages were for sissies.
After a racer friend died of a head impact, I changed my opinion.
Has anyone else come across a dedicated sailing helmet>? I noticed AMRO
used something in the
Volvo around the world Race.
dEmO
Sent: Tuesday, November 14, 2006 11:34 AM
> mtkennedy1 wrote:
> > That was to
prevented
Mike Kennedy
> Chris Campbell
Chris Campbell2006-11-14 20:54 UTC
Don't people go to amusement parks on purpose and pay good money to do
things like this? Maybe it's just a matter of using the Tom Sawyer
principle--gee you can take a ride up my mast for $5, and for another
$10, we'll give you a good spin. Meanwhile, I've suddenly realized
there are reasons to be grateful that I no longer weigh 170 (figured
there must be some).
Re: [Cal_Boats] Helmets
Chris Campbell2006-11-14 21:34 UTC
> wearing
> hat of yours."
> I raced bicycles in the 1970's, and helmets were suggested not mandatory,
Long ago, my Dad figured out that the iceboat he had built was the ideal
vessel for causing head injuries, and he bought a helmet long before
they were required. I still use it. In fact, when I wrecked my thumb
in a capsize a couple winters back, I seem to recall landing mostly on
my head, but that didn't get sprained. Dad was an orthopedic surgeon so
he was well aware of the fragility of the human body.
I also disdained bike helmets, until I'd been over the handlebars
twice. Talk about a slow learner!! Now I wear it with religious
fervor. Just for kicks, this past summer I rode the bike three blocks
on residential streets to the hardware store, without a helmet. It made
me nervous.
And having said all that, most of my sailing is in fairly sedate
circumstances, and I'm not greatly inclined right now to go to a
helmet. Sun exposure and falling overboard are the greater dangers for
me. I'm better at covering up from the sun and at wearing the
inflatable PFD on the boat.
You guys who are in the athletic racing category can wear the helmets.
If some fierce racer invites me along, I'll bring the bike helmet.
RE: [Cal_Boats] Helmets
Husar Charlie2006-11-15 05:30 UTC
Timm, I have to admit I never see them in the wine commercials. We have
had a few boom smacked people over the years. Only takes one. I
haven't done it, but in some conditions it sure sounds smart.
Behalf Of ti… [at] ch2m.com
Sent: Tuesday, November 14, 2006 3:48 PM
Subject: [Cal_Boats] Helmets
floats.
wearing
of yours."
mandatory,
Scooter DOT Shorty
Silver<http://us.st11.yimg.com/us.st.yimg.com/I/yhst-3342088133151_1924_
14791363>
dEmO
> mtkennedy1 wrote:
> > That was to
prevented
Mike Kennedy
> Chris Campbell
Re: Bow light?
mwrohde2006-11-20 19:09
Thanks for all of your help. It turns out that the person I found
that was dumb enough to go up was me.
My dad came down to help. He had a climbing harness and he hoisted me
up on two halyards. It turned out that a previous mast-climber had
cut a wire to the light. All together I was hanging up there about an
hour fixing the wiring and replacing the bulb. That, at least, is now
working fine.
On to the next challenge . . .
