58 messages2006-11-22 05:02 UTCthrough 2006-12-07 14:58
Re: [Cal_Boats] MOB Lessons learned
ai… [at] aol.com2006-11-22 05:02 UTC
Thanks for a great re-cap Randy! As skipper of a racing team, I now know I
will be doing more MOB drills with my crew members. As I see it, I should have
drills where I am in charge (as the skipper) and also a chain of command, if
it is I, that falls overboard.
Even though we read stories like this semi-regularly, it does not hit home
nearly as much, as when it comes from the mouth of someone you know. Your
incident has certainly brought safety back to the forefront in my mind. I believe
your skipper failed miserably, and although it is easy to sit here and say I
would not have made the same mistakes, we never really know how we will
react until faced with the same situation. That is of course where the drills
come into play.
Thanks again Randy;
Daniel Casey
"Air Time"
Cal 9.2R #75
Santa Barbara, Ca.
Tom Tilley2006-11-22 18:14 UTC
Randy -
I finally got a few minutes to read your write-up on events and your survival. Great writing - you definitely conveyed the feeling while maintaining an objective description of being in the water.
I'll use some of your lessons to change what I carry on my infatible pfd as well get more serious about using jacklines on a more regular basis since I single-hand a lot on the Bay. Your description has definitely given me pause to think about some of my practices - as well as reminding me that I haven't practiced MOB drills for quite a while.
Welcome back - and I hope you never have to go there again.
Tom Tilley
1982 Cal 9.2 "Lenochka" Hull #53
San Mateo, CA
Sponsored Link
Online or Campus degree Associate's, Bachelor's, or Master's
in less than one year.www.findtherightschool.com
Randy Alcorn2006-11-23 02:41 UTC
Thank you Dan for your support,
I see this bigger than my skipper failing me.
There was two boats and 4 people out there, that didn't know what to do in an MOB situation.
respectfully,
Randy
ai… [at] aol.com wrote:
Thanks for a great re-cap Randy! As skipper of a racing team, I now know I will be doing more MOB drills with my crew members. As I see it, I should have drills where I am in charge (as the skipper) and also a chain of command, if it is I, that falls overboard.
Even though we read stories like this semi-regularly, it does not hit home nearly as much, as when it comes from the mouth of someone you know. Your incident has certainly brought safety back to the forefront in my mind. I believe your skipper failed miserably, and although it is easy to sit here and say I would not have made the same mistakes, we never really know how we will react until faced with the same situation. That is of course where the drills come into play.
Thanks again Randy;
Daniel Casey
"Air Time"
Cal 9.2R #75
Santa Barbara, Ca.
Want to start your own business? Learn how on Yahoo! Small Business.
Chris Campbell2006-11-27 14:43 UTC
OK, guys, how about a discussion of which MOB (COB) procedures you use,
and why. Most of my sailing is single-handed these days so I haven't
been diligent about practicing. I read the articles from time to time
but don't have enough experience with real-worlds COB conditions to know
what actually works. It's likely that list members have some firm
opinions on this (can you imagine any sailing subject on which sailors
don't have firm opinions? We won't even get into which knot is
appropriate for securing the anchor rode....)
Re: MOB discussion... .. (was) Lessons learned
slickbutfoxbuger2006-11-27 15:39
use,
haven't
time
know
sailors
> Chris Campbell
frankly, now that all the back slapping has died down......
i just can't understand why every one of you guys don't have
a "T" track of some sort running up both sides of your cabin trunk to
the fore-deck; and when you go forward, you can just "snap" into a
traveler that stay's on the "T" track with a short heavy safety line
that has an approved safety shock-link in it just incase you do
decide to float-test your *PFD*.
it is this very simple and idiot-proof system that has been
used on every bloody round-hulled pig-boat the Navy ever built.
the other thing that i will have on BB-54 is a solid top-rail
on the railings from the cockpit to just a foot or so forward of the
mast-step. i will also raze the hand-rail height from it's current
and assenine height of just 18". to the minimum required height of
30". i will also add both a solid middle rail, and a solid toe-rail
at 2" off the deck.
and i will tell you all another thing;
you are not going to ever get a dripping wet adult out of
the water with just one or two people if that wet person has been in
the water for 30 minutes and you need to pull him 3' or more up over
the side of a boat in a rolling windy sea. in fact, you are not even
going to be able to get a decent hold on the guy! so two things.
don't ever jump in the cold water with him!
and do have a plan to get a man out of the water after you find
him. even if that means cutting the rigging off the damn boom and
using that. sails and rigging can be replaced, humans can't!
but it is always better to have a set of lifting gear ahead of
time. and not just a puny 4 to 1 with 5/16 or 3/8 line. that wet
piece of near dead fish meat you will be pilling out of the water is
likely to be limp even if he is still talking to you. get your self
really good ball-gearing 6 to 1 blocks with 1/2" line that you can
get your cold wore-out hands around. and make damn sure that every
person on board has a *PFD* with a built-in lifting *D* ring. you are
not going to be able to get one on that near dead fish while he is in
the water and bouncing under you damn hull.
and lastly;
you better make sure that everyone on board can get that tub
your sailing turned into the wind and stopped so they don't drag you
until you drown .....
fiver,
Master of The "BB-54"
one of the famous Cal-28 flush-decks
out of Sierra-5, Papa Hotel (in days gone by)
now resting outside my shop
Federal Way, Wa.
(built like a Battleship; sails like a Sub......)
Re: MOB discussion (Fiver and all)
Rog Jones2006-11-27 18:10 UTC
There are many different ways to get someone back aboard. The one thing that
we can probably all agree on is that a swim step or a stern ladder and a
Life Sling can be a big help.
Upon a man overboard and assuming someone else is aboard, immediately start
shouting, "Man Overboard!" The GPS MOB button should be triggered right then
and there. If you have a man overboard pole and float, toss it in. Any
non-living thing that floats should be dumped over the side or tossed to the
swimmer for floatation and to act as markers to find the swimmer when you
return. If you have a Life Sling (you should), toss it out or to the swimmer
at once. If the swimmer can't reach it, at least you can swing around and
drag it over him. I do turn on the engine, but do not engage the prop if the
Life Sling is out (tangles) or I am close to the swimmer (possibility of
serious prop chop). Immediately, one person is told to continuously point at
the MOB and never, ever look away. That person should have NO OTHER DUTIES.
If you have one (and you should) drop the stern laldder/swimstep. I like to
immediately jibe or tack - forget about the sail trim niceties, let stuff
flog. Upon return I put the swimmer in the lee of the boat, then using
anything that you can get over the side - sheets, boat hooks, whatever -
help the swimmer back to the swim step or stern ladder. There are a million
ways to accomplish this maneuver and none of them are necessarily pretty. If
they are wearing a harness, hook it and get a line through it immediately
and tie it off to a winch. If not, get a line around them under their
shoulders and tie a bowline or a carrick bend. Then tie off to the winch.
Now you've got 'em.
We have six personal GPS EPIRBS (one in each of our inflatables). If you can
afford them, they are a very good idea.
There is apparently a device that you can add to the inflatable that
contains a self-deploying man overboard locator helium balloon on a
twenty-foot tether that is hooked to the inflatable's harness. That would
make a swimmer easier to find and to catch for a recovery. I have never seen
one of these, though I have looked at the patent (U.S. Patent 6,805,070)
assigned to Boeing).
Smoke blows flat in a high wind and cannot be easily seen by a rescue boat
in heavy swells. Dye markers are nice, too, but again only if you are
expecting an aerial search. You have to get something up above the wave tops
to be seen by a boat, even a few yards away. A head is very, very hard to
spot in high seas. Same problem with many PFDs as they are dark in color.
For visibility, yellow works better than almost anything. Dark foulies and
dark clothing make you almost invisible. That includes red.
I recommend that everyone wears an inflatable with a built-in harness when
out racing or beyond an easy swim from land in warm water. In cold
water/weather, everyone should wear one. Period. Death by drowning and/or
hypothermia is probably a lousy way to end a day. Underway on my boat,
everyone MUST properly wear a PFD.
Our inflatable/harnesses all have an adjustable, two-inch nylon web crotch
strap sewn into the back with a snap that hooks onto the D rings of the
harness in front of the sternum. If you go overboard, you are immediately
snatched into a head-high seated position. If you need to be air-lifted, all
that is necessary is to snap into the D rings and you will not slip out of
the harness. These are not a hindrance when working the foredeck, despite
all the crap you might hear to the contrary. The newer, lightweight
inflatables are very comfortable and become almost unnoticeable when you are
used to them. I'm to the point where I feel funny if I don't have mine on.
As the body becomes hypothermic, it shrinks somewhat and without a crotch
strap you may slip out of the PFD. I related (more than once) the story of
the fishing boat that may-dayed from an area just north of the Golden Gate.
There were seven people aboard and they were sinking in sight of land. They
were abandoning ship. All aboard were wearing inflatables. The rescue boat
and helicopter got there in twenty minutes. They found one dead floater and
six empty PFDs. The chopper pilot or rescue swimmer wrote about this in
Practical Sailor about five years ago. The Coast Guard PFDs now all have
heavy-duty crotch straps.
Don't forget the rules of sailing:
1. Keep the water out of the boat.
2. Keep the people in the boat.
3. Have fun.
4. Always look good.
\Rog
Cal 29+ #1
Swiss Navy
Cal 2-30 #77
St. Lori's Comet
mtkennedy12006-11-27 20:00
>snipped
In Mexico, near Cabo, a few years ago, a charter fishing boat went down and the
passengers all went into 80 degree water in PFDs. They were found and recovered in 12
hours. All were dead of hypothermia. Warm water is still a good conductor and is colder
than you are or than you can survive.
It makes the survival of that middle aged woman who fell off the cruise ship in the south
Atlantic a few years ago even more amazing. She must have been really fat. They found
her treading water three days after she went in.
Mike Kennedy
Conquest Cal 40 # 96
mtkennedy12006-11-27 23:30
--- In Ca… [at] yahoogroups.com, "slickbutfoxbuger" <fiverhrairoo@...> wrote:
> use,
> > and why.
snipped
We have in the past used a length of covered wire similar to a lifeline that is attached at
the bow to a pad eye and near the cockpit to another pad eye. This line runs along the
cabin on each side and it is easy to snap a lifeline to the cable and go from cockpit to bow
without having to unsnap and reattach a safety harness but, once back in fair weather or
at a mooring, the cable can be coiled up and stowed. This will keep you attached to the
boat. That is better than all the GPS and spotter aids when somebody is no longer attached
to the boat.
When we went through the hurricane in the 1977 La Paz Race, we all wore bathing suits,
PFDs and safety harnesses all night. It was that hot and blowing 60+. My memory is fading
but I think we had the wire cable rigged for that race.
Mike Kennedy
Re: [Cal_Boats] Re: MOB discussion... .. (was) Lessons learned
Bob Walden2006-11-27 23:59 UTC
We rig jacklines on our Farr 36 when we race offshore, no matter what the
conditions are forecast. And we have a permanently mounted wire jackline in
the cockpit.
We also always carry a MOM-8 module and an EPIRB, and there's usually about
3-4 GPS's around to punch the MOB button on. We also routinely carry a
lifesling and a throw-rope in a bag attached to the stern rail.
On the other hand...do we actually ever snap on? It has to be pretty wild to
get us to do so. It's really hard to work a competitive racer while wearing
a tether. The tactician, driver and main trimmer could snap on most of the
time but are at the least risk. The bowman and mastman are at the most risk
but require a lot of mobility. The cockpit crew have a hard enough time
right now getting off the rail and into their tacking positions without
dealing with teathers. It would become an I Love Lucy sketch instanly, with
everyone tangled in everyone else's tether.
It's a tough choice. For cruising, I have no doubts, especially after the
incident last year where a father lost his teenage son right out of the
cockpit, here off of Point Reyes. After that, frankly, in my boat when we're
cruising offshore, we snap on, even in the cockpit. Hell, we're just sitting
there, there's no reason NOT to.
But on a racer, it's a different issue. Yes, you might be safer, but can you
still really compete? You'd be safer still back at the dock, but that's not
what boats are for.
In the end I suspect on the racer we'll continue to wait until conditions
are atrocious before we snap on, and we'll stress safety and situational
awareness, one hand for you the other for the boat, keep your center of
balance low, and watch out for each other. That last one is important, I
think: on a racer, with a crew of 10+ during some of the more exciting
rodeos, you could easily have a MOB and not even notice it! I try to get
people to "buddy up" and keep an eye on each other, and I do a headcount as
soon as I can think about it after any wildness has occurred.
bw
Cal 39-2 "Sea Star"
Richmond, CA
Sent: Monday, November 27, 2006 3:30 PM
Subject: [Cal_Boats] Re: MOB discussion... .. (was) Lessons learned
>> use,
>> > and why.
> snipped
> that is attached at
> runs along the
> from cockpit to bow
> fair weather or
> attached to the
> longer attached
> to the boat.
> bathing suits,
> memory is fading
> Mike Kennedy
> Yahoo! Groups Links
Re: [Cal_Boats] Re: MOB discussion (Fiver and all)
John Dawson2006-11-28 00:50 UTC
Well said, Rog.
As a Seascout vessel doing open ocean races, we adopted a rule of always, spelled ALWAYS, wearing a PFD on deck, from the starting line at Annapolis inside the Chesapeake, to the dinghy at St. Georges. That applies to adults and youths both. Usually they are not worn extensively in part because the need is not apparent, and partly because you look like sissies when you are the only one on board or the only boat in the fleet using them. Our practise is so absolute that we have become insensitive to our status as sissies, and actually take pride in the practise. In addition, we use tethers ALOT - at night, in rough weather, on a two-person watch, or in lively open water.
Note that the new Mustang hydrostatic inflatable PFDs are now available. And now required in Maryland waters are the infant PFDs with head flotation, grab-strap and crotch strap. Also a much improved pet PFD than the solid yellow ones.
John Dawson
Kefi, Balto.
Rog Jones <ro… [at] nvsailing.org> wrote:
There are many different ways to get someone back aboard. The one thing that we can probably all agree on is that a swim step or a stern ladder and a Life Sling can be a big help.
Upon a man overboard and assuming someone else is aboard, immediately start shouting, Man Overboard! The GPS MOB button should be triggered right then and there. If you have a man overboard pole and float, toss it in. Any non-living thing that floats should be dumped over the side or tossed to the swimmer for floatation and to act as markers to find the swimmer when you return. If you have a Life Sling (you should), toss it out or to the swimmer at once. If the swimmer cant reach it, at least you can swing around and drag it over him. I do turn on the engine, but do not engage the prop if the Life Sling is out (tangles) or I am close to the swimmer (possibility of serious prop chop). Immediately, one person is told to continuously point at the MOB and never, ever look away. That person should have NO OTHER DUTIES. If you have one (and you should) drop the stern laldder/swimstep. I like to immediately jibe or tack forget about the sail trim niceties, let stuff flog.
Upon return I put the swimmer in the lee of the boat, then using anything that you can get over the side sheets, boat hooks, whatever help the swimmer back to the swim step or stern ladder. There are a million ways to accomplish this maneuver and none of them are necessarily pretty. If they are wearing a harness, hook it and get a line through it immediately and tie it off to a winch. If not, get a line around them under their shoulders and tie a bowline or a carrick bend. Then tie off to the winch. Now youve got em.
We have six personal GPS EPIRBS (one in each of our inflatables). If you can afford them, they are a very good idea.
There is apparently a device that you can add to the inflatable that contains a self-deploying man overboard locator helium balloon on a twenty-foot tether that is hooked to the inflatables harness. That would make a swimmer easier to find and to catch for a recovery. I have never seen one of these, though I have looked at the patent (U.S. Patent 6,805,070) assigned to Boeing).
Smoke blows flat in a high wind and cannot be easily seen by a rescue boat in heavy swells. Dye markers are nice, too, but again only if you are expecting an aerial search. You have to get something up above the wave tops to be seen by a boat, even a few yards away. A head is very, very hard to spot in high seas. Same problem with many PFDs as they are dark in color.
For visibility, yellow works better than almost anything. Dark foulies and dark clothing make you almost invisible. That includes red.
I recommend that everyone wears an inflatable with a built-in harness when out racing or beyond an easy swim from land in warm water. In cold water/weather, everyone should wear one. Period. Death by drowning and/or hypothermia is probably a lousy way to end a day. Underway on my boat, everyone MUST properly wear a PFD.
Our inflatable/harnesses all have an adjustable, two-inch nylon web crotch strap sewn into the back with a snap that hooks onto the D rings of the harness in front of the sternum. If you go overboard, you are immediately snatched into a head-high seated position. If you need to be air-lifted, all that is necessary is to snap into the D rings and you will not slip out of the harness. These are not a hindrance when working the foredeck, despite all the crap you might hear to the contrary. The newer, lightweight inflatables are very comfortable and become almost unnoticeable when you are used to them. Im to the point where I feel funny if I dont have mine on.
As the body becomes hypothermic, it shrinks somewhat and without a crotch strap you may slip out of the PFD. I related (more than once) the story of the fishing boat that may-dayed from an area just north of the Golden Gate. There were seven people aboard and they were sinking in sight of land. They were abandoning ship. All aboard were wearing inflatables. The rescue boat and helicopter got there in twenty minutes. They found one dead floater and six empty PFDs. The chopper pilot or rescue swimmer wrote about this in Practical Sailor about five years ago. The Coast Guard PFDs now all have heavy-duty crotch straps.
Dont forget the rules of sailing:
Have fun.
Always look good.
\Rog
Cal 29+ #1
Swiss Navy
Cal 2-30 #77
St. Lori's Comet
Access over 1 million songs - Yahoo! Music Unlimited.
Improved Pet PFD? (Was MOB discussion) (John D)
Rog Jones2006-11-28 01:33 UTC
Hi, John -
Where can I learn more about the improved pet PFD? We sail with at least one
of our seven dogs pretty much every time.
Thanks.
\Rog
Of John Dawson
Sent: Monday, November 27, 2006 4:50 PM
Subject: Re: [Cal_Boats] Re: MOB discussion (Fiver and all)
Well said, Rog.
yellow ones.
John Dawson
Kefi, Balto.
Now you've got 'em.
3. Have fun.
\Rog
Cal 29+ #1
Swiss Navy
Cal 2-30 #77
St. Lori's Comet
<http://pa.yahoo.com/*http:/us.rd.yahoo.com/evt=36035/*http:/music.yahoo.com
/unlimited/> Music Unlimited.
Re: [Cal_Boats] Improved Pet PFD and used liferafts (Rog and all)
John Dawson2006-11-28 03:04 UTC
The pet PFD is WM labelled, and is red/yellow. I don't know who the manufacturer is offhand although it probably is Stearns if I had to guess. Its the same basic design as predecessors but looks 100% more robust and better made and fitting, and looks like you could haul an average dog aboard with it, unlike the previous lightweight models sold by WM and Petsmart. I was told the small version comes with the stuffed dog that models it in stores.
On another note, I have a problem about liferafts. We bought a new ISAF 8-man raft this year, and have an offshore Avon 6-man cannister raft no longer being used. I would like to sell it to a fellow that fishes offshore, but pricing it is very difficult. Anyone have an inkling of how long these rafts are viable? A general idea of their lifespan would help to prorate it. The repack services are being very unhelpful in making generalities here.
Here's the scoop. Its about 12-14 years old, bought when our Mason43 changed owners and brought the boat to the East Coast. So its never been used, always kept with the same boat, and serviced (and approved) by the leading repacker for the mid-Atlantic in 2004 and 2005. (We skipped this year due to the new purchase.) Summary: the age and history are known, and its condition has been certified as recently as last year. It lives in a hard cannister in its sealed envelope; we are only asking under $300-500 for it. A reinspection will probably cost near $400.
So, what is a reasonable lifespan, or when would you (ie the Cal list) opt to replace an expensive item for ocean safety?
John D.
Hi, John
Where can I learn more about the improved pet PFD? We sail with at least one of our seven dogs pretty much every time.
Thanks.
\Rog
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of John Dawson
Well said, Rog.
John Dawson
Kefi, Balto.
flog. Upon return I put the swimmer in the lee of the boat, then using anything that you can get over the side sheets, boat hooks, whatever help the swimmer back to the swim step or stern ladder. There are a million ways to accomplish this maneuver and none of them are necessarily pretty. If they are wearing a harness, hook it and get a line through it immediately and tie it off to a winch. If not, get a line around them under their shoulders and tie a bowline or a carrick bend. Then tie off to the winch. Now youve got em.
Have fun.
Always look good.
\Rog
Cal 29+ #1
Swiss Navy
Cal 2-30 #77
St. Lori's Comet
Cheap Talk? Check out Yahoo! Messenger's low PC-to-Phone call rates.
Re: [Cal_Boats] MOB discussion (Rog)
John Dawson2006-11-28 03:08 UTC
Rog,
My friend Steve notes that when a PFD is in the water, they suddenly go from a dark color to yellow.
John
Hi, John
Thanks.
\Rog
Well said, Rog.
John Dawson
Kefi, Balto.
Have fun.
Always look good.
\Rog
Cal 29+ #1
Swiss Navy
Cal 2-30 #77
St. Lori's Comet
Re: MOB discussion (Rog)
mtkennedy12006-11-28 03:46
--- In Ca… [at] yahoogroups.com, John Dawson <jdawson229@...> wrote:
> Rog,
to yellow.
You folks might be interested to know that I ordered two of the Mustang inflatable PFDs with
safety harness from the new Sailnet site and they cancelled the order with no explanation
today. I suspect the price was too good. Guess that was a failed test. Annapolis Performance
Sailing had them on sale but they were gone by the time I saw the sale. No more Sailnet for
me.
Mike Kennedy
Marsh Wise2006-11-28 04:02 UTC
Nice, why not write this up in a non-insulting like article w/ real
directions and some diagrams? Sounds like good info, but hard to read.
Marsh
>use,
>haven't
>time
>know
>sailors
>>Chris Campbell
>at 2" off the deck.
> and lastly;
>fiver,
>Federal Way, Wa.
>Yahoo! Groups Links
RE: [Cal_Boats] Re: MOB discussion... .. (was) Lessons learned (Marsh)
Rog Jones2006-11-28 14:26 UTC
Marsh -
There is a brief article in the current 'lectronic Latitude
(www.latitude38.com <http://www.latitude38.com/> ) and there will be a full
article in the next regular Latitude 38. Randy may have been knocked
overboard, but the knockout result of this near-tragedy is going to help
every sailor who takes the time to read Latitude 38, which, it just happens,
is the most widely circulated of all sailing magazines.
Thanks again, Randy!!
\Rog
Cal 29+ #1
Swiss Navy
Cal 2-30 #77
St. Lori's Comet
Of Marsh Wise
Sent: Monday, November 27, 2006 8:02 PM
Subject: Re: [Cal_Boats] Re: MOB discussion... .. (was) Lessons learned
Marsh
RE: [Cal_Boats] Re: MOB discussion (Mike)
Rog Jones2006-11-28 17:32 UTC
Hi, Mike -
The Mustang vests need crotch straps. If you buy them (or anybody else's),
be sure to take them down to a sailmaker or a canvas shop and have the
straps added. Also, the 1-inch attachable crotch straps you buy at W-M are
too flimsy. You need 2-inch nylon to properly support most people's weight
in a lift.
W-M will match anybody's advertised price on items they stock or have in
their catalog - the do stock or catalog Mustang vests - by the way, so you
can simply print out the best ad you can find from the internet and take it
to W-M and get the same price without paying for shipping. I do that for
almost all the stuff I buy for the kids' program and for our boats.
One really nice thing that Mustang makes, are their cold-water survival
suits. They really work.
\Rog
Of mtkennedy1
Sent: Monday, November 27, 2006 7:46 PM
Subject: [Cal_Boats] Re: MOB discussion (Rog)
--- In Cal_Boats@yahoogrou <mailto:Cal_Boats%40yahoogroups.com> ps.com, John
> Rog,
from a dark color
to yellow.
no explanation
more Sailnet for
me.
Mike Kennedy
mtkennedy12006-11-28 19:11
> Hi, Mike -
> in a lift.
Spinlock also makes a similar combo vest that has leg straps. According to Sailing World,
that makes them not Coast Guard approved.
Mike Kennedy
RE: [Cal_Boats] Internet matching (was MOB discussion )
John Dawson2006-11-28 19:21 UTC
Unfortunately I have to report that WM (or the retailers in charge of it now) is absolutely putting the screws to EVERYTHING they can find in order to make Wall Street happy. The return policy is changing, the associate discounts have been reduced, time off will be altered, Internet matching (even for their own site) will soon be a thing of the past, inventory is being 'simplified' to make your shopping choices easier, and the experiment with lower prices is over. Sorry.
You didn't hear it here.
Hi, Mike
The Mustang vests need crotch straps. If you buy them (or anybody elses), be sure to take them down to a sailmaker or a canvas shop and have the straps added. Also, the 1-inch attachable crotch straps you buy at W-M are too flimsy. You need 2-inch nylon to properly support most peoples weight in a lift.
W-M will match anybodys advertised price on items they stock or have in their catalog the do stock or catalog Mustang vests by the way, so you can simply print out the best ad you can find from the internet and take it to W-M and get the same price without paying for shipping. I do that for almost all the stuff I buy for the kids program and for our boats.
One really nice thing that Mustang makes, are their cold-water survival suits. They really work.
\Rog
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of mtkennedy1
> Rog,
to yellow.
me.
Mike Kennedy
Rog Jones2006-11-28 19:31 UTC
Hi, Mike -
I don't know from Coast Guard approved. As a member of the Coast Guard
Auxiliary, though, I can tell you that all the newer Government Issue vest
that the CG uses have crotch straps.
Later.
\Rog
Sailing World,
Mike Kennedy
Re: Internet matching (was MOB discussion )
mtkennedy12006-11-28 19:50
over. Sorry.
Maybe they could simplify and use the time to keep 1/4 nylock nuts and bolts in stock. The
fastener bins do not have bar codes and the store staff tell me that this means they don't get
replentished sometimes for months. I now buy these fasteners from jamestown, which is still
cheaper even with shipping from Rhode Island.
MIke Kennedy
Re: [Cal_Boats] Internet matching (was MOB discussion )
Chris Campbell2006-11-28 20:48 UTC
Old-time listoids will be rolling their eyes when Chris begins his
biennial West Marine rant but here goes. This is the difference between
your old local chandlery and West Marine. WM must answer to Wall
Street, which means attaining what the bean-counters regard as a proper
return on investment and all that. Your local boat-stuff peddler only
has to answer to his own need for income, his creditors, and maybe some
partners. If he's making a comfortable living, he's happy. He can
afford to do things that make his local customers happy and that bring
them back to the store.
He can even decide who his customers are! He can target people who own
boats and make a business of meeting their needs--a local niche. Wall
Street doesn't ask if WM is making the boat folks happy. If they can
make gobs of money selling boat-themed casual clothing to people who
hang out on the docks or on the beach, that's good enough for Wall
Street. Wall Street doesn't care if you find your favorite varnish, or
that cool Harken block, or the bottom paint you need on the shelves or
in the catalog.
The free-market theory is that you can choose to go to the local guy if
WM doesn't meet your needs. Problem is, WM is like that other big
player with the same initials, Wal-Mart. Once they've run all the local
competitors out of business, you're stuck with what they choose to
offer. Your choices have gone out of business. West Marine has done
that in the communities where I live and sail.
I still maintain that organizations like West Marine owe something to
their customers. One thing they owe is certain levels of service, and
one component of service is offering stuff that the customers need, even
if it's not a high-volume item. Efficiency is not the only criterion
for performance.
West Marine's inventory has been shrinking for years, offering less and
less choice, fewer and fewer options. Those cool little doo-dads that
we sailors need from time to time have disappeared from the shelves. A
number of years ago in an unguarded moment a clerk ("associate")
explained that most people don't know what they're doing, and all those
choices just confused them (so West diminished the choices to satisfy
the dim-witted). Frankly, I like choices when choosing allows me to
meet my boat's specific needs. And I dislike being taken for
dim-witted. Even if I am.
I have been searching West's shelves in two locations for the nice waxed
whipping twine they used to carry. It was exactly the right form and
weight for my uses. After multiple trips, and "associate" caught me
before I trotted out the door in disgust. I explained what they were
lacking--still--and he explained that some big corporate reorganization
of the sailing stock was going on, and they were not refilling inventory
until that was done. Now I know the whole story.
So West Marine has been Milton-Friedmanized, and we are all the losers
for it. Makes me grumpy as hell, in case you didn't notice.
Harrumph.
Randy Alcorn2006-11-28 20:54 UTC
Hi Rog,
I am trying catch up on the this.
I think you got a wonderful start for us to make a safety sheet we can teach crew and skippers.
I crewed on a Olson 30 this weekend and the skipper went over his MOB drill. He had us all repeat it out loud.
Can I add two things to your list?
1. The Coast Guard wants to be contacted. With all that is going on, I don't know when and what if you are short crew? I was glad to find out that the other two helos where 20 min.
2. Something we always practice on my boat is a figure eight. We jibe or tack and head above the victum and then turn around and return circling with the recovery gear in the water.
Hope this helps.
Randy
CAL 2-29
Out Patient
Channel Islands CA
Have fun.
Always look good.
\Rog
Cal 29+ #1
Swiss Navy
Cal 2-30 #77
St. Lori's Comet
Check out the all-new Yahoo! Mail beta - Fire up a more powerful email and get things done faster.
Randy Alcorn2006-11-28 21:32 UTC
Hi Chris,
I single hand majority of the time, I belong to the Pacific Singlehanded Sailing Association. They have a lot of single handed long distance races. You are allowed to use a Auto pilot, which I have not gotten one yet. It allows for Sail Changes, spinnaker sets and just taking it easy. I hope to be set up for the 2007 season.
Jacklines are on deck all the time. The only time I am not teathered in is when I am in the cock pit, if it gets rough then I clip in. At night for some reason, I am to edgy and always stay clipped in. Even when I dose off for a second.
I think the time most single handed skippers fall over board are when they are facing aft, over the stern.
I missed the meeting where they had the guy whose power boat crashed into Catalina Island. He was taking care of buisness when he went over board. He swam to a channel bouy and fought the seals off it so he could get out of the water. His brother was the one who found him. He was in pretty sad shape, but made it and he is talking about it.
I would have to say, make sure you have a way to get back on the boat, I am going to a built in ladder off the stern. I have a folding ladder now and a recent trip to the islands taught me a valuable lesson why a ladder should be ready at all times.
Then if all else fails, carry an EPIRB and hope time is on our side.
Randy
CAL 2-29
Out Patient
Channel Islands Ca
OK, guys, how about a discussion of which MOB (COB) procedures you use, and why. Most of my sailing is single-handed these days so I haven't been diligent about practicing. I read the articles from time to time but don't have enough experience with real-worlds COB conditions to know what actually works. It's likely that list members have some firm opinions on this (can you imagine any sailing subject on which sailors don't have firm opinions? We won't even get into which knot is appropriate for securing the anchor rode....)
Bob Walden2006-11-28 21:32 UTC
I teach for an ASA sailing school, and I also attended last year's MOB symposium here in sf bay (report at http://www.boatus.com/foundation/findings/COBfinalreport/).
As far as maneuvers go, there's many to choose from. The right one is the one that works.
All rescues are done in 3 stages: return, make contact, and recover. Return means getting within reaching or at least line-throwing range. The latter is only realistic if the MOB is concious. Contact means connecting the MOB to the boat, either grabbing by hand or with a line. Recovery is often the hardest part: getting them aboard. Mid-ships for most sailboats works the best (we did dozens of real recoveries of 200-pound divers, using all possible equipment including none, and with both cooperative and simulated unconcious swimmers. It's a bear.)
I would say that in all cases it works best to approach the MOB on a close reach course--assuming you're sailing. If you're close reaching you have maximum control: you're heading upwind, so luffing decelerates you and hardening up accelerates you. You can usually do it with only the main, and letting the jib either luff or strike it.
There's a fair amount of controversy about the side of the boat to bring the MOB along. If you go upwind of him, you can let the wind push you down to him, but if the seas are rough, he might be driven under. If you go downwind of him, you'll quickly drift away from him. Tradeoffs either way.
If you're close-hauled when the MOB event occurs, the quick stop is very good. You basically just tack immediately and keep turning in a tight circle, bleeding off speed, and deploy your lifesling or any line with floatation, with a goal of wrapping it around the MOB. Once he has it in hand, you can heave to and start recovery.
If you have a kite up (something I have not practiced), I'd say that you'd want to head up, do an emergency guy-drop douse (blow the tack, in other words), get the kite down, then get the MOB lined up on a close-reach course and go to them.
Whatever the maneuver, someone on board needs to have no other job but to POINT and LOOK and the MOB, never taking their eyes or finger off, even for a moment, until the MOB is alongside. Randy's ordeal underlines the importance of this. Losing sight of the MOB is usually fatal (thank God not in Randy's case). By pointing, the pointer both keeps their own visual reference, and the driver can also just look at the pointer's hand to see where the MOB is--the driver doesn't really need to look for the MOB themselves.
Punching the MOB function on a GPS is also a good thing. So is throwing all available flotation as soon as possible.
There's a ton more to say. Have a look at the symposium findings at http://www.boatus.com/foundation/findings/COBfinalreport/.
bw
Sent: Tuesday, November 28, 2006 12:54 PM
Hi Rog,
Hope this helps.
Randy
CAL 2-29
Out Patient
Channel Islands CA
Upon a man overboard and assuming someone else is aboard, immediately start shouting, "Man Overboard!" The GPS MOB button should be triggered right then and there. If you have a man overboard pole and float, toss it in. Any non-living thing that floats should be dumped over the side or tossed to the swimmer for floatation and to act as markers to find the swimmer when you return. If you have a Life Sling (you should), toss it out or to the swimmer at once. If the swimmer can't reach it, at least you can swing around and drag it over him. I do turn on the engine, but do not engage the prop if the Life Sling is out (tangles) or I am close to the swimmer (possibility of serious prop chop). Immediately, one person is told to continuously point at the MOB and never, ever look away. That person should have NO OTHER DUTIES. If you have one (and you should) drop the stern laldder/swimstep. I like to immediately jibe or tack - forget about the sail trim niceties, let stuff flog. Upon return I put the swimmer in the lee of the boat, then using anything that you can get over the side - sheets, boat hooks, whatever - help the swimmer back to the swim step or stern ladder. There are a million ways to accomplish this maneuver and none of them are necessarily pretty. If they are wearing a harness, hook it and get a line through it immediately and tie it off to a winch. If not, get a line around them under their shoulders and tie a bowline or a carrick bend. Then tie off to the winch. Now you've got 'em.
There is apparently a device that you can add to the inflatable that contains a self-deploying man overboard locator helium balloon on a twenty-foot tether that is hooked to the inflatable's harness. That would make a swimmer easier to find and to catch for a recovery. I have never seen one of these, though I have looked at the patent (U.S. Patent 6,805,070) assigned to Boeing).
Our inflatable/harnesses all have an adjustable, two-inch nylon web crotch strap sewn into the back with a snap that hooks onto the D rings of the harness in front of the sternum. If you go overboard, you are immediately snatched into a head-high seated position. If you need to be air-lifted, all that is necessary is to snap into the D rings and you will not slip out of the harness. These are not a hindrance when working the foredeck, despite all the crap you might hear to the contrary. The newer, lightweight inflatables are very comfortable and become almost unnoticeable when you are used to them. I'm to the point where I feel funny if I don't have mine on.
1.. Keep the water out of the boat.
2.. Keep the people in the boat.
3.. Have fun.
4.. Always look good.
\Rog
Cal 29+ #1
Swiss Navy
Cal 2-30 #77
St. Lori's Comet
RE: [Cal_Boats] Re: MOB discussion (Randy and Alfredl)
Rog Jones2006-11-28 21:50 UTC
Hiya, Randy -
I deliberately didn't suggest a pattern, though I too like the figure 8 when
it's appropriate. Don't know if you saw last summer's West Marine/US Sailing
MOB drills in the Bay that were reviewed in Latitude 38, but there are a
bunch of patterns and what you do depends largely on what works in a given
situation and what you're good at. The ONLY real MOB I've been involved with
was when we were on a beat, completing a headsail change and the other
foredeck guy, crouching right next to me got washed over the side in the
middle of the Catalina Channel about 12 miles off of South Entrance in about
thirty knots of air and lumpy cold seas. This was before there were
inflatables and nobody wore PFDs. The skipper almost instantly put the helm
over onto the opposite tack to stall the boat, released the sheets (main and
jib) and we literally drifted broadside right down onto our crew member.
This was in a Cal 34.
We didn't call the Coast Guard, but you are absolutely right that should be
included in the list.
How about somebody writes this up as an MOB procedure, let's everyone
contribute and then posts it on this website as a file that can be
downloaded, like say, a PDF - hey, wait, how about Alfred? He's the writer,
here.
\Rog
Cal 29+ #1
Swiss Navy
Cal 2-30 #77
St. Lori's Comet
Of Randy Alcorn
Sent: Tuesday, November 28, 2006 12:55 PM
Hi Rog,
crew and skippers.
Hope this helps.
Randy
CAL 2-29
Out Patient
Channel Islands CA
._,___
Bob Walden2006-11-28 22:03 UTC
I clip on all the time, even in the cockpit in broad daylight, when cruising in the open ocean. Racing's a different issue, but when cruising, in my opinion there isn't any reason NOT to clip on. I've come to this position for myself and I realize others will have different positions on this, and that's OK, I wouldn't want to say anyone is right or wrong on this issue. We all just have to make up our own minds.
Here's the story that convinced me to do this:
http://pdxhamlins.net/andy/
The above accident happened right here near SF, and 5 foot seas are below average here. "Sneaker" wave sets happen all the time, and it doesn't take a 20-footer to cause havoc.
So now when we're not in the cabin, we're clipped on, and when we go below, we stay clipped on until we're below the companionway. The tethers stay hanging down into the cabin, and we clip on again before we climb the ladder.
And we keep the hatch closed and hatchboards in.
bw
Sent: Tuesday, November 28, 2006 1:32 PM
Subject: Re: [Cal_Boats] MOB Lessons learned
Hi Chris,
Randy
CAL 2-29
Out Patient
Channel Islands Ca
Re: MOB Lessons learned
mtkennedy12006-11-28 22:23
--- In Ca… [at] yahoogroups.com, Randy Alcorn <saylorran@...> wrote:
> Hi Chris,
snipped
over the stern.
Buddy Ebsen's famous advice to a young crewman comes to mind. When asked if he could
pee off the stern, Ebsen said it was OK but most of the people found drowned have their flys
unzipped. Keep one hand holding on.
Mike Kennedy
Re: [Cal_Boats] Nuts! (was Internet matching)
John Dawson2006-11-29 03:28 UTC
Excuse me Mike, but they are feeding you Spam here.
Its true the fastener section is not replenished by computer barcodes; its a little hard to put little barcodes on each nut or have cashiers look up the right barcode for each washer. Thats why they are sold on the honor system - you tell them quantity and price, right? The fasteners are replenished by a person looking thru the section and punching in the desired WM sku into the computer, just like they order the bags for the front counter, can be done every week. Then they come on the WM truck from the warehouse just like everything else in the store. Its the only merchandise in the store actually ordered by humans, and the humans are being lax if the bins are empty.
All thats happening is the task is getting neglected haphazardly; either the store manager has not designated a specific person to stay on top of this, or the designated person is doing it when they get around to it. Perhaps the manager does it him/herself monthly and the staff are at his/her mercy. Do them a favor and confront the store manager, suggest he/she designate a person and check on them regularly. It only takes a few minutes a week. They might complain about getting the little bins overstocked; I can suggest a method for managing that little problem too.
If you get more excuses, mention the words "Showtime" and "district manager" in the same sentence and watch those bins spill over.
You did hear it here.
John D.
over. Sorry.
MIke Kennedy
Re: Nuts! (was Internet matching)
mtkennedy12006-11-29 04:02
I don't mean to offend you but that is why I was told they have been out of the most
common sizes of bolt and nut for MONTHS ! The same is true of the Long Beach store at
Alamitos Bay.
I don't care what WM does one way or another but don't tell me I am telling the list
something that is not true. The bar codes are on the front of the bins but no one checks
the bins. I was told that by the employees of the San Pedro store. Would you like to meet
me there Thursday and ask them ?
MIke Kennedy Conquest Cal 40 # 96
Janet PLume2006-11-29 04:34 UTC
Chris:
Sounds dire. When our WM in nola reopens hopefully in February - at least that
is the gossip - I will have to drop by to find out. Unfortunately I have found
their selection to be seriously wanting in recent years.
Janet Plume, Editor/Gulf Shipper
826 Fern Street
New Orleans, La. 70118
504-866-7076
cell: 504-250-4539
email: jp… [at] joc.com
We are what we repeatedly do. Excellence, then, is not an act, but a habit.
Sent: Tuesday, November 28, 2006 2:48 PM
Subject: Re: [Cal_Boats] Internet matching (was MOB discussion )
Old-time listoids will be rolling their eyes when Chris begins his biennial West
Marine rant but here goes. This is the difference between your old local
chandlery and West Marine. WM must answer to Wall Street, which means attaining
what the bean-counters regard as a proper return on investment and all that.
Your local boat-stuff peddler only has to answer to his own need for income, his
creditors, and maybe some partners. If he's making a comfortable living, he's
happy. He can afford to do things that make his local customers happy and that
bring them back to the store.
He can even decide who his customers are! He can target people who own boats
and make a business of meeting their needs--a local niche. Wall Street doesn't
ask if WM is making the boat folks happy. If they can make gobs of money
selling boat-themed casual clothing to people who hang out on the docks or on
the beach, that's good enough for Wall Street. Wall Street doesn't care if you
find your favorite varnish, or that cool Harken block, or the bottom paint you
need on the shelves or in the catalog.
The free-market theory is that you can choose to go to the local guy if WM
doesn't meet your needs. Problem is, WM is like that other big player with the
same initials, Wal-Mart. Once they've run all the local competitors out of
business, you're stuck with what they choose to offer. Your choices have gone
out of business. West Marine has done that in the communities where I live and
sail.
I still maintain that organizations like West Marine owe something to their
customers. One thing they owe is certain levels of service, and one component
of service is offering stuff that the customers need, even if it's not a
high-volume item. Efficiency is not the only criterion for performance.
West Marine's inventory has been shrinking for years, offering less and less
choice, fewer and fewer options. Those cool little doo-dads that we sailors
need from time to time have disappeared from the shelves. A number of years ago
in an unguarded moment a clerk ("associate") explained that most people don't
know what they're doing, and all those choices just confused them (so West
diminished the choices to satisfy the dim-witted). Frankly, I like choices
when choosing allows me to meet my boat's specific needs. And I dislike being
taken for dim-witted. Even if I am.
whipping twine they used to carry. It was exactly the right form and weight for
my uses. After multiple trips, and "associate" caught me before I trotted out
the door in disgust. I explained what they were lacking--still--and he explained
that some big corporate reorganization of the sailing stock was going on, and
they were not refilling inventory until that was done. Now I know the whole
story.
So West Marine has been Milton-Friedmanized, and we are all the losers for it.
Harrumph.
Re: [Cal_Boats] Re: Nuts! (was Internet matching) (Mike)
John Dawson2006-11-29 05:33 UTC
I'll call that store tomorrow and ask them what the problem is. Seems unlikely to me there is a fastener shortage on the West Coast that doesn't exist on the East Coast, or that their procedures are completely different. I'm not questioning that thats what they told you, I just don't understand it because I've ordered fasteners for four years and the only time we are out of something is if I get lazy.
Yes there are barcodes on the labels, and WM skus also. Fasteners are not sold by barcodes, they are not tracked by barcodes, they are not counted at inventory by barcode, and they are not ordered for the bins by barcodes unless we are talking about bulk bags of them. Perhaps that is what you are referring to. The WM sku is entered by hand into the Intrepid program under 'fasteners, letters, whatever" menu to fill the bins in every store I know. You say 'no one checks the bins', well, the computer doesn't either so that's the problem.
I understand you are frustrated and angry at their apparent incompetence, but I'm trying to help, not offend you.
John D.
Alamitos Bay.
Re: [Cal_Boats] West Marine (was too many topics to list)
Scott Sauvageot2006-11-29 06:31 UTC
Ok, I understand that it's frustrating to go to the store and not find what
you want or need. I experience the same thing here in Annapolis. The
bottom line, however is that there are always other options for getting what
you want. if WM is plainly unreliable, then research the other options and
stop shopping there. I find them great for all sorts of odds & ends, but
don't shop for fasteners there any longer.
I also don't think it's fair to pick on the bean counters or Wall Street for
the problems of the selection at West Marine. I'm an accountant and an avid
sailor. You can blame the boating public for settling for their second
choice instead of going out and finding what they want. If people stopped
shopping at West, then the shareholders would take notice. I am an
accountant, so I resent the notion that it's my peers fault that WM has
changed it's focus from sailors to powerboaters. Most powerboaters don't do
their own work on their boat, except to add cutsie cushions or drink
holders. They enjoy the "smack the throttle and go" mentality as if they
were driving a car. As the power gemagraphic is increasing at a faster rate
than sailing, WM is simply going with where the $$$$ are. It's the sailing
communities fault for not promoting ourselves and winning people over to
sailing instead of powerboating.
Just my $.02.
Scott S.
Accountant/Sailor
Cal 25 #1651 Indefatigable
Annapolis, MD
>From: Chris Campbell <cl… [at] charterinternet.com>
>Date: Tue, 28 Nov 2006 15:48:22 -0500
>West Marine rant but here goes. This is the difference between your old
>local chandlery and West Marine. WM must answer to Wall Street, which
>means attaining what the bean-counters regard as a proper return on
>investment and all that. Your local boat-stuff peddler only has to answer
>to his own need for income, his creditors, and maybe some partners. If
>he's making a comfortable living, he's happy. He can afford to do things
>that make his local customers happy and that bring them back to the store.
>Street doesn't ask if WM is making the boat folks happy. If they can make
>gobs of money selling boat-themed casual clothing to people who hang out on
>the docks or on the beach, that's good enough for Wall Street. Wall Street
>doesn't care if you find your favorite varnish, or that cool Harken block,
>or the bottom paint you need on the shelves or in the catalog.
>the same initials, Wal-Mart. Once they've run all the local competitors
>out of business, you're stuck with what they choose to offer. Your choices
>have gone out of business. West Marine has done that in the communities
>their customers. One thing they owe is certain levels of service, and one
>component of service is offering stuff that the customers need, even if
>it's not a high-volume item. Efficiency is not the only criterion for
>performance.
>less choice, fewer and fewer options. Those cool little doo-dads that we
>sailors need from time to time have disappeared from the shelves. A number
>of years ago in an unguarded moment a clerk ("associate") explained that
>most people don't know what they're doing, and all those choices just
>confused them (so West diminished the choices to satisfy the dim-witted).
>Frankly, I like choices when choosing allows me to meet my boat's specific
>needs. And I dislike being taken for dim-witted. Even if I am.
>weight for my uses. After multiple trips, and "associate" caught me before
>lacking--still--and he explained that some big corporate reorganization of
>the sailing stock was going on, and they were not refilling inventory until
>Harrumph.
>Chris Campbell
Share your latest news with your friends with the Windows Live Spaces
friends module.
http://clk.atdmt.com/MSN/go/msnnkwsp0070000001msn/direct/01/?href=http://spaces.live.com/spacesapi.aspx?wx_action=create&wx_url=/friends.aspx&mk
Marsh Wise2006-11-29 09:27 UTC
Yeah, but Scott, it's sooooo satisfying :-Þ
Marsh
Chris Campbell2006-11-29 16:16 UTC
> what
> getting what
> you want.
The problem is that they've driven out the local competitors--by coming
in, offering great selection and prices, and then after the local guys
have given up, greatly reducing their stock and service.
> Street for
> avid
I wasn't trying to blame accountants for executive policy choices. My
reference to bean-counters was intended to refer to those Wall Street
analysts who decide what kind of earnings are acceptable. They have a
lot of influence on large publicly-traded organizations, in a way that
small local retailers are not affected.
> rate
It's not just numbers of boaters. The cushions and drink holders
probably have larger markup. I know that capitalists pursue profits.
There's just this quaint notion that maximizing profit is not the only
virtue. There is the notion of serving your community, sometimes at a
cost, sometimes in the interest of long-term success, sometimes just
because it's the right thing to do. My family background and personal
career are all in the professions. Not many retailers among us. All my
life I've been told that you have obligations to your community and that
maximizing income cannot be the highest or only goal. My dad made a
comfortable but not maximum income as a physician, because he made
service one of his values. Some of his colleagues made a lot more money
and spent a lot more time playing, but they did not appear to have
notably happier lives. I don't think it's unreasonable to expect
corporations to conform to notions of behavior that we apply to people.
That's why I feel free to criticize WM. And to reiterate, I'm not
dumping on accountants. My uncle, as decent and honest a guy as you'd
ever find, one of those guys who went ashore on D-Day and never talked
about it, was one. I am lamenting the influence that has been gained
by Wall Street analysts.
mtkennedy12006-11-30 01:17
--- In Ca… [at] yahoogroups.com, "mtkennedy1" <mtkennedy1@...> wrote:
> > use,
> > > and why.
I posted a comment the other day that I had ordered Mustang PFD/Harness sets from
Sailnet and then, without explanation, got an e-mail that the order had been cancelled. I
posted a comment that maybe the price had been too good and I was unhappy that they
had cancelled the sale with no explanation. Today I got an e-mail from Rog that he told
somebody he knows who told somebody in the company about the complaint.
Here is te original e-mail:
***Do not reply to this e-mail. UPS and Marine.com / SailNet.com will not receive your
reply.
At the request of Marine.com / SailNet.com, this notice alerts you the following shipment
has been cancelled.
Original Shipment Detail
Ship To:
University of Southern Californi
Michael Kennedy
XXXXXXXXXXX
MISSION VIEJO
CA
926916201
US
Number of Packages: 1
UPS Service: GROUND
Weight: 5.0 LBS
Lead Tracking Number: 1ZYE74840396955877
Reference Number 1: 765453
I don't see any explanation. The guy at Sailnet wants an apology for the post but, aside
from acknowledging that they responded to Rog a lot faster than they would respond to
one of us, I don't see any reason to apologize.
I haven't gotten the vests yet. I'll be glad to see them when they arrive and I will so inform
the group.
If you want something done in marine supply, Rog is the guy to get it done.
I bought a lot of stuff from them in their previous incarnation. Maybe I'll buy some more
but they need to work on communication.
Mike Kennedy
Sailnet and West Marine and mistakes (was MOB discussion)(Mike K)
Rog Jones2006-11-30 04:06 UTC
Hi, Mike -
You are a cardiac surgeon. Mistakes you make cause lives. Those I or Sailnet
or West Marine or most retailers make usually just cause inconveniences.
Sailnet does a huge amount for the sailing community by providing forums and
informational articles and a lot of other stuff in addition to just selling
us gear. West Marine is there for Transpac and Pacific Cup and so many other
events I can't name them all.
The email I got didn't ask for an apology, it acknowledged Sailnet had made
a mistake and tried to correct it and hoped for you to post a note saying
they'd screwed up and were trying to make it right for you. I think that's a
good thing and can't blame them.
According to Chris Colton, the fellow who sent me the note, you should have
your vests on Friday. Hopefully that will be the case. I know these people,
Mike, and they are good people and trying hard to do a good thing.
I agree, Sailnet and West Marine (for different reasons) need to work on
their communications. But we could all learn to be a little better at that.
Except me, of course. I'm perfect and have never failed to properly
communicate. BTW I am running for office next year. That way I can be with
the government and be here to help whenever you need me. Hehehe.
\Rog
Cal 29+ #1
Swiss Navy
Cal 2-30 #77
St. Lori's Comet
from
cancelled. I
that they
that he told
receive your
reply.
following shipment
has been cancelled.
Ship To:
Michael Kennedy
XXXXXXXXXXX
MISSION VIEJO
CA
926916201
US
UPS Service: GROUND
Weight: 5.0 LBS
post but, aside
respond to
the group.
buy some more
Mike Kennedy
Re: Sailnet and West Marine and mistakes (was MOB discussion)(Mike K)
mtkennedy12006-11-30 05:07
> Hi, Mike -
"I would like to think that Mr. Kennedy posted a subsequent post to his thread and either
retracted his statement or described what turned out to be the full story."
I took the term "retracted" as a request for an apology but stand corrected. My problem
was that I got no explanation. The text almost suggested that the credit card had been
declined or some other problem with my credit. Maybe I'm too sensitive but when I was a
medical student, I attempted to buy a refrigerator on credit from Sears. It was about $250.
I finally called to ask if it was delayed and the operator said "You won't be getting that
refrigerator." I had flunked the credit test. I asked if it had ever occurred to them that I
would pay cash if the credit was declined. No it hadn't. I bought one somewhere else.
Cancelling a sale suggests something other than a delivery problem.
MIke Kennedy
Speaking of Good Communications (was Sailnet and West Mrine - MOB discussion)(Mike K)
Bruce Stirling2006-11-30 05:36 UTC
I just want to inform the group that the good people at Sailboat Owners, and
specifically, Dave Groshong, responded to an email I sent informing them of
the loss of 1/2 of my outboard "power thruster." Dave had the manufacturer
call me to discuss what happened. Even though I did not request relief, the
manufacturer offered to send me another thruster fin to replace the one
lost. At this time, there is nothing to attach the fin to, so told him
maybe sometime in the future. We had a great discussion. I said I would
send him photos to document his database. Great people!
Bruce Stirling
Gangfurd
Cal 28 - Hull 28
http://www.stirlinglaw.com/cal28
Of Rog Jones
Sent: Wednesday, November 29, 2006 9:06 PM
Subject: [Cal_Boats] Sailnet and West Marine and mistakes (was MOB
discussion)(Mike K)
Hi, Mike -
\Rog
Cal 29+ #1
Swiss Navy
Cal 2-30 #77
St. Lori's Comet
from
cancelled. I
that they
that he told
receive your
reply.
following shipment
has been cancelled.
Ship To:
Michael Kennedy
XXXXXXXXXXX
MISSION VIEJO
CA
926916201
US
UPS Service: GROUND
Weight: 5.0 LBS
post but, aside
respond to
the group.
buy some more
Mike Kennedy
Mark Alan Stahnke (MAS Consulting)2006-12-05 18:28 UTC
Regarding the PFD's, is the West Marine 4000 series with harness and crotch strap accessory, the way to go, or is there a much better PFD available?
Mark
Pelican Cal 2-29
San Pedro
Sent: Monday, November 27, 2006 7:08 PM
Subject: Re: [Cal_Boats] MOB discussion (Rog)
Rog,
John
Hi, John -
Thanks.
\Rog
Well said, Rog.
John Dawson
Kefi, Balto.
3.. Have fun.
\Rog
Cal 29+ #1
Swiss Navy
Cal 2-30 #77
St. Lori's Comet
PFDs with crotch straps (Mark S) (was MOB discussion)
Rog Jones2006-12-06 19:24 UTC
Hi, Mark -
Sorry for the delayed reply. Been in SoCal (actually, San Pedro!) these past
few days and too busy for emails.
We tested the Stearns "universal crotch strap" accessory by lifting a 200
pound adult with a dock hoist to see how it worked. It began to tear at the
seams and was incredibly uncomfortable because the webbing is son narrow.
The 4000 Series is a really high-quality workhorse of a PFD/harness and
we've used them on our boats for some time.
I suggest that you simply have a 2" - 3" wide, nylon webbing strap with a
stainless steel D ring on the loose end professionally sewn into the back of
the harness on your 4000 Series PFD. Ours are length-adjustable, but I think
that's overkill as you will see if you first have the strap sewn in and then
measure for where you want the D ring. Unless the wearer is incredibly small
or incredibly large, no length adjustment is needed. I think the total cost
for the materials and the professional sewing ran us something like $12 per
PFD.
Hope this helps.
\Rog
Cal 29+ #1
Swiss Navy
Cal 2-30 #77
St. Lori's Comet
Re: PFDs with crotch straps (Mark S) (was MOB discussion)
mtkennedy12006-12-06 20:30
> Hi, Mark -
We finally got the Mustang PFDs from Sailnet and I was disappointed to find I'd gotten the
model without the harness. It was probably my fault for not realizing the fact that the
model numbers are one digit off.
I'll probably have to modify them eventually for a webbing belt. They do appear to have
crotch straps but no harness belt.
Mike Kennedy
PS Rog bought me breakfast and he is a big tipper.
Re: [Cal_Boats] PFDs with crotch straps (Mark S) (was MOB discussion)
Mark Alan Stahnke (MAS Consulting)2006-12-06 20:44 UTC
Rog, Thanks that's exactly what I wanted to know. Additionally, since this mob came up, I am in the process of rigging a block and tackle 6:1 harkens lift. I was wondering how the tang for the topping lift would work for the lift attachment or from where the backstay splits or abandon the block and tackle for the elevator method....line around the forward cleat back to a winch. The elevator doesn't seem to address the incapacitated though. I do want to be prepared for the worst! and prey to god I don't have to.
Mark
Sent: Wednesday, December 06, 2006 11:24 AM
Subject: [Cal_Boats] PFDs with crotch straps (Mark S) (was MOB discussion)
Hi, Mark -
Sorry for the delayed reply. Been in SoCal (actually, San Pedro!) these past few days and too busy for emails.
We tested the Stearns "universal crotch strap" accessory by lifting a 200 pound adult with a dock hoist to see how it worked. It began to tear at the seams and was incredibly uncomfortable because the webbing is son narrow. The 4000 Series is a really high-quality workhorse of a PFD/harness and we've used them on our boats for some time.
I suggest that you simply have a 2" - 3" wide, nylon webbing strap with a stainless steel D ring on the loose end professionally sewn into the back of the harness on your 4000 Series PFD. Ours are length-adjustable, but I think that's overkill as you will see if you first have the strap sewn in and then measure for where you want the D ring. Unless the wearer is incredibly small or incredibly large, no length adjustment is needed. I think the total cost for the materials and the professional sewing ran us something like $12 per PFD.
Hope this helps.
\Rog
Cal 29+ #1
Swiss Navy
Cal 2-30 #77
St. Lori's Comet
Lifting devices for MOBs (was PFDs with crotch straps) (Mark S)
Rog Jones2006-12-06 21:27 UTC
It's definitely nice to have something above deck level to get a MOB back on
the boat. Me, I like the LifeSling, due to an incident coming back from the
1972 Ensenada Race. But again, I think I should defer to others who can make
suggestions about where to mount lifting blocks, etc.
Good luck on this.
\Rog
Of Mark Alan Stahnke (MAS Consulting)
Sent: Wednesday, December 06, 2006 12:45 PM
Subject: Re: [Cal_Boats] PFDs with crotch straps (Mark S) (was MOB
discussion)
Mark
To: Cal_Boats@yahoogrou <mailto:Ca… [at] yahoogroups.com> ps.com
Hi, Mark -
PFD.
Hope this helps.
\Rog
Cal 29+ #1
Swiss Navy
Cal 2-30 #77
St. Lori's Comet
Bob Walden2006-12-06 21:32 UTC
Mark;
Great topic! Recovery is the hardest part. When we were doing MOB drills with live volunteers last year, we found that the only thing we could really do with an unconcious mob was get down in the water with them to get a line around them. The d-rings on sospender-type harnesses or PFDs just don't work for an unconcious person; the mob is limp, their arms go up in the air when you start to lift and they slide out of the harness. It's also real hard to get to them when the vest is inflated; they're behind the balloons.
Some folks advocate putting a carabiner on the d-rings so you have something you can get ahold of to clip on to. Might work.
The best way we found to recover someone was with the lifesling. We put the sling on them backwards, with the rope behind them, and had them keep their arms down over the padded lifesling. We lifed with them facing away from the boat, sliding them up the hull until their butt was on the toerail, then man-handled them under the lifeline.
If the mob was "Unconcious" (not helping us), we did the same thing but we had to put a crew in the water to do it, because we had to get the lifesling around them and then tie their arms down to keep them in the sling. We crossed their arms over their chest, on top of and over the sling, and tied a short line around them to keep their arms in place during the lift. Needless to say, the extra crew in the water is a worry; they need PFDs, lines tide to them, etc. But it's nearly impossible to hoist an unconcious person to deck level without someone going in to assist. I guess if your freeboard was low enough that you could reach down and tie a line or the sling around the person from deck level you could avoid this, but that's the minority of boats that have that low a freeboard.
Also, mid-ships is where to do all of this, unless a) you have a sugar scoop stern and b) it's nearly dead calm.
bw
Sent: Wednesday, December 06, 2006 12:44 PM
Subject: Re: [Cal_Boats] PFDs with crotch straps (Mark S) (was MOB discussion)
Mark
Hi, Mark -
Hope this helps.
\Rog
Cal 29+ #1
Swiss Navy
Cal 2-30 #77
St. Lori's Comet
Re: [Cal_Boats] Lifting devices for MOBs (was PFDs with crotch straps) (Mark S)
Bob Walden2006-12-06 21:36 UTC
In the MOB trials, we tested with "handy-billies", just block and tackle gear with snap-hooks at each end, with (I think) 6:1 purchase. We put the handy-billy on a spare halyard and hoisted it up so the top block was about 6' above the deck. Then we lowered the handy-billy hook down to the MOB and did the lift using the 6:1 blocks. Still not easy with a 200 lb-er, soaking wet more like 300 lbs. And you have to get them really high to get onto the deck.
I used to think the boom would work for this, but after trying it, most booms are just too low.
bw
Sent: Wednesday, December 06, 2006 1:27 PM
Subject: [Cal_Boats] Lifting devices for MOBs (was PFDs with crotch straps) (Mark S)
It's definitely nice to have something above deck level to get a MOB back on the boat. Me, I like the LifeSling, due to an incident coming back from the 1972 Ensenada Race. But again, I think I should defer to others who can make suggestions about where to mount lifting blocks, etc.
Good luck on this.
\Rog
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Mark Alan Stahnke (MAS Consulting)
Mark
Hi, Mark -
Hope this helps.
\Rog
Cal 29+ #1
Swiss Navy
Cal 2-30 #77
St. Lori's Comet
RE: [Cal_Boats] Lifting devices for MOBs (Bob W)
Rog Jones2006-12-06 22:23 UTC
Hi, Bob -
Two things:
First, please, can you again post the URL for the MOB work you did last
summer?
Second, in 1972, without any help, I had to get four guys over the stern and
on board a Cal 2-30 which has a sloping rear end, but no scoop. The boat had
a stainless steel swim ladder with wooden steps that dropped down out of the
stern pulpit, leaving the pulpit open on most of the starboard half, but
only from shear level down. These guys had been clinging to a broken and
overturned trapeze of a catamaran - the beams between the amas had broken in
half but the amas were still floating upside down - for about four hours in
the dark in very cold water, with breaking seas continually knocking them
back into the water. They couldn't offer a lot of help, but some. That is,
they were weak from the cold, but not unconscious. It took about three hours
since the rest of my crew and the skipper were down below vomiting or
unconscious after too many Husong's Tavern agave concoctions. Being, for all
practical purposes alone, and not having a clue what else to do, I simply
got the main down (we were motorsailing from Ensenada to San Diego), put the
boat in neutral and let the wind shove the boat down onto the broken cat
each time. It was dark and noisy and I was very scared and running on
adrenalin. With the main centered and locked down by the mainsheet, I used a
snatch block through the boom bale that secured the top of the vang and ran
the LifeSling line through it to a sheet winch. I kept tossing the LifeSling
until each person got it and then got into it and dragged them aboard,
facing the boat, up the ladder, through the opening in the stern pulpit. It
was exhausting, even with the winch. As soon as I got the first guy aboard,
by which time we'd drifted away from the catamaran, I engaged the prop again
and got upwind and repeated the process. Possibly the most terrifying thing
I've been through since my days in West Pac. Couldn't do it today, I think.
I just don't have that much endurance or adrenalin. The point here is that
it would be swell to have done stuff amidships, but when you are alone or
short-handed, that may not be an option. The swim ladder was great because
it gave the guys I was picking up something to hang onto as I winched them
up a little at a time.
Thanks for all you do for this list. And for the experience you bring to us.
\Rog
Cal 29+ #1
Swiss Navy
Cal 2-30 #77
St. Lori's Comet
_
Re: [Cal_Boats] Lifting devices for MOBs (Bob W)
Bob Walden2006-12-06 23:15 UTC
The COB symposium's final report is at http://www.boatus.com/foundation/findings/COBfinalreport/.
Wow rog, what a story. My hat's off to you. Nobody could have done more.
bw
Sent: Wednesday, December 06, 2006 2:23 PM
Subject: RE: [Cal_Boats] Lifting devices for MOBs (Bob W)
Hi, Bob -
Two things:
First, please, can you again post the URL for the MOB work you did last summer?
Second, in 1972, without any help, I had to get four guys over the stern and on board a Cal 2-30 which has a sloping rear end, but no scoop. The boat had a stainless steel swim ladder with wooden steps that dropped down out of the stern pulpit, leaving the pulpit open on most of the starboard half, but only from shear level down. These guys had been clinging to a broken and overturned trapeze of a catamaran - the beams between the amas had broken in half but the amas were still floating upside down - for about four hours in the dark in very cold water, with breaking seas continually knocking them back into the water. They couldn't offer a lot of help, but some. That is, they were weak from the cold, but not unconscious. It took about three hours since the rest of my crew and the skipper were down below vomiting or unconscious after too many Husong's Tavern agave concoctions. Being, for all practical purposes alone, and not having a clue what else to do, I simply got the main down (we were motorsailing from Ensenada to San Diego), put the boat in neutral and let the wind shove the boat down onto the broken cat each time. It was dark and noisy and I was very scared and running on adrenalin. With the main centered and locked down by the mainsheet, I used a snatch block through the boom bale that secured the top of the vang and ran the LifeSling line through it to a sheet winch. I kept tossing the LifeSling until each person got it and then got into it and dragged them aboard, facing the boat, up the ladder, through the opening in the stern pulpit. It was exhausting, even with the winch. As soon as I got the first guy aboard, by which time we'd drifted away from the catamaran, I engaged the prop again and got upwind and repeated the process. Possibly the most terrifying thing I've been through since my days in West Pac. Couldn't do it today, I think. I just don't have that much endurance or adrenalin. The point here is that it would be swell to have done stuff amidships, but when you are alone or short-handed, that may not be an option. The swim ladder was great because it gave the guys I was picking up something to hang onto as I winched them up a little at a time.
\Rog
Cal 29+ #1
Swiss Navy
Cal 2-30 #77
St. Lori's Comet
_
Chris Campbell2006-12-06 23:16 UTC
Rog Jones wrote:
> Hi, Bob --
> Two things:
> last summer?
> had been clinging to a broken and overturned trapeze of a catamaran --
> floating upside down -- for about four hours in the dark in very cold
Thanks to all you guys who have described your actual experiences with
retrieval devices. I have printed a bunch of them to share with our
local schooner organization. It's been a topic of discussion for some
time. The big lesson is that things always work worse, and happen under
more demanding circumstances, than you ever expect. We do MOB exercises
on the schooner, but it's just the throw-the-pfd over, call-MOB,
have-crew-point, retrieve-pfd kind of thing (on nice summer
afternoons). The schooner, with its high freeboard (maybe 7' to top of
bulwarks), presents a special challenge. The plan is to launch the
inflatable and pull the MOB into that, but the next step, getting aboard
from the inflatable, would present a challenge with a helpless victim or
big seas or both.
Re: Lifting devices for MOBs (Bob W)
mtkennedy12006-12-06 23:19
--- In Ca… [at] yahoogroups.com, "Rog Jones" <rog@...> wrote:
> Hi, Bob -
> Two things:
> summer?
This story makes me think of Willard Bell's rescue of the crew of a trimaran in the 1981
Transpac. They were in a raft and that may have helped. It would be interesting to have
that story from his children who still have Westward. Willard is gone. I'm sure they were
there as the family took the trimaran crew aboard and gave them the choice of being put
off in the raft at daylight for the Coast Guard to pick up, or going to Honolulu with the Bell
family. They chose the latter and Willard got a time allowance and a trophy for
seamanship. I think they had 14 going to Hawaii. The Bell's had Westward at the Transpac
dinner last February.
Mike Kennedy
Mark Alan Stahnke (MAS Consulting)2006-12-06 23:49 UTC
Rog mentioned, adding to the pfd, a heavy 2" sewn on crotch strap with its own d ring. I am picturing that the strap is sewn on from the back and wrapped around the crotch and the d ring connects with the harness d rings. Does the addition of this crotch strap d ring to harness solve the issue with the pfd sliding over the arms of the weighted mob?
And if not, are there any solutions on the drawing board that enable a secure pick up and lift connection point on the pfd and without the need for a sling.
Mark
Sent: Wednesday, December 06, 2006 1:32 PM
Mark;
bw
Mark
Hi, Mark -
Hope this helps.
\Rog
Cal 29+ #1
Swiss Navy
Cal 2-30 #77
St. Lori's Comet
Bob Walden2006-12-06 23:59 UTC
I dunno if the crotch strap would make a sospenders pfd a good hoising harness. Mainly, the crotch strap is to help you float higher in the water, and keep the pfd in its intended location on an unconcious person. I can't see that it would impair the lifting process.
I'd still go with the lifesling if at all possible.
bw
Sent: Wednesday, December 06, 2006 3:49 PM
Mark
Mark;
bw
Mark
Hi, Mark -
Hope this helps.
\Rog
Cal 29+ #1
Swiss Navy
Cal 2-30 #77
St. Lori's Comet
mtkennedy12006-12-07 01:05
process.
Did any of these workshops check out the MOM 8 and the MOM 9 ? The MOM 9 has an
inflatable raft packed in that little cannister. It is a one person raft with a built-in sling. It's
expensive but, for offshore use, the money would seem worthwhile given all the trouble
getting MOB aboard. It has a tackle built in, as I read the literature. The MOM 8A has an
inflatable horseshoe ring and a lighted MOB pole that inflates. I think there is also a
beacon of some sort. They are quite a bit more than the Lifesling but maybe something to
think about.
Mike Kennedy
Conquesst Cal 40 # 96
MOB Life Saver Buoy (Mike)
ti… [at] ch2m.com2006-12-07 01:41 UTC
Mike,
Sospenders made a unit like this.. essentially an inflatable one man
raft
with an inflatable rigging tower. We bought one for each boat. They are
a great solution... except that when Sospenders was bought out, the
item has completely fallen off the radar..
They were called the Life Saver Buoy
See them at:
http://tinyurl.com/yhpgk9
Timm
Sent: Wednesday, December 06, 2006 5:06 PM
Subject: [Cal_Boats] Re: PFDs with crotch straps (Mark S) (was MOB
discussion)
harness.
keep the pfd in its
impair the lifting
process.
has an
all the trouble
The MOM 8A has an
there is also a
maybe something to
think about.
Mike Kennedy
Re: [Cal_Boats] Re: PFDs with crotch straps (Mark S) (was MOB discussion)
Bob Walden2006-12-07 03:08 UTC
Yeah, in fact I was on the boat that tested the mom-9. It's a great unit and
worked very well. We were deploying it in 25 knots in SF bay, with about 4
foot chop. The unit deployed and inflated perfectly 3 times (3 different
days, with a trip to the repack shop each night). The unit didn't drift
downwind too fast, we were concerned about that but the drogues worked. The
diver was able to get in the raft without much trouble. We hoisted the raft
but in this case you need to have a block and tackle with a very long
full-out length. The lifting slings for the raft are quite long, and to get
it up to at least deck level to roll the mob under the lifelines, the top
block had to be at least 10 feet above deck. We couldn't use the
handly-billy, had to winch the halyard directly--hard work.
But yeah, if you can afford it, the mom-9 is good stuff.
Sent: Wednesday, December 06, 2006 5:05 PM
discussion)
>> harness.
> keep the pfd in its
> impair the lifting
> process.
> has an
> the trouble
> The MOM 8A has an
> there is also a
> maybe something to
> think about.
> Mike Kennedy
> Yahoo! Groups Links
Re: [Cal_Boats] PFDs with crotch straps (Bob/Rog/Tim/Mike)
Randy Alcorn2006-12-07 04:00 UTC
Hi Rog and Bob,
I have to say, the talk around the club this last weekend was about this same subject. I can't tell you how many people told me I may not of gotten back on the boat.
It made me feel lucky the Sheriffs Dept got to me.
The swimmer ditched my harness and pulled me up with a sinch strap of some sort. It was quick and I didn't notice it. He threaded it under my arms, around my back and next I was hooked to a carbiner. He clipped onto me and up we went.
Thrish's family is making Christmas Tomales for the SAR dept this weekend.
I will try to find out what they use next week.
Maybe this will help!
Randy
CAL 2-29
Out Patient
Channel Islands Ca.
bw
Mark
Mark;
bw
Mark
Hi, Mark
We tested the Stearns universal crotch strap accessory by lifting a 200 pound adult with a dock hoist to see how it worked. It began to tear at the seams and was incredibly uncomfortable because the webbing is son narrow. The 4000 Series is a really high-quality workhorse of a PFD/harness and weve used them on our boats for some time.
I suggest that you simply have a 2 - 3 wide, nylon webbing strap with a stainless steel D ring on the loose end professionally sewn into the back of the harness on your 4000 Series PFD. Ours are length-adjustable, but I think thats overkill as you will see if you first have the strap sewn in and then measure for where you want the D ring. Unless the wearer is incredibly small or incredibly large, no length adjustment is needed. I think the total cost for the materials and the professional sewing ran us something like $12 per PFD.
Hope this helps.
\Rog
Cal 29+ #1
Swiss Navy
Cal 2-30 #77
St. Lori's Comet
Any questions? Get answers on any topic at Yahoo! Answers. Try it now.
RE: [Cal_Boats] Re: PFDs with crotch straps (Mike K)
Rog Jones2006-12-07 14:13 UTC
Wow! Mike - 20% is not big tipping where I grew up. But St. Lori and I agree
that the service and the excellent brunch were almost as good as the
company! Worth every penny! As always, it was really nice to get to spend
time with you, my friend.
As for the PFDs, why don't you just send them back and get the right ones?
Or go down to W-M and get their 4000 series. To me they seem every biot as
good.
All the best.
\Rog
Cal 29+ #1
Swiss Navy
Cal 2-30 #77
St. Lori's Comet
Of mtkennedy1
Sent: Wednesday, December 06, 2006 12:31 PM
discussion)
--- In Cal_Boats@yahoogrou <mailto:Cal_Boats%40yahoogroups.com> ps.com, "Rog
> Hi, Mark -
past
the
I'd gotten the
fact that the
appear to have
Mike Kennedy
Re: PFDs with crotch straps (Bob/Rog/Tim/Mike)
sail_c22006-12-07 14:58
We'll save a discussion of the bravery and courage of these guys for
another day, but it's worth noting the value of training. They train
over and over and when the time comes to use the skills, they can do
it just right. I used to think about My Tax Dollars at Work every
time I saw the Coast Guard helicopter out playing on the Bay in front
of my office, but then I read about the great value of repetitive
training, and how doing the thing over and over leaves you not needing
to think or remember when your skills are needed. Now when I hear the
helicopter's whine, I think about preparedness and competence.
