10 messages2006-12-06 17:42 UTCthrough 2006-12-08 18:01
Re: [Cal_Boats] Re: Lexan (Mike)
ai… [at] aol.com2006-12-06 17:42 UTC
Mike, didn't you find storing the single BIG hatch board a problem?
Daniel Casey
"Air Time"
Cal 9.2R #75
Santa Barbara, Ca.
Re: Lexan (Mike)
mtkennedy12006-12-06 18:10
I used to stow it under the cushion on the quarterberth. It wasn't a problem. The fiberglass
and wood cover in the 40 is more bulky and trouble to stow. The lexan hatch was flat and
easy to stow.
Mike Kennedy
Conquest Cal 40 # 96
> Daniel Casey
> "Air Time"
> Cal 9.2R #75
> Santa Barbara, Ca.
Bob Walden2006-12-06 18:21 UTC
I've had single lexan hatchboards on my last 2 boats. There's pros and cons. They let in a lot of light when you have them in, and they're simple to make. But they're heavy, harder to store, and less versatile (can't put in just 1 or 2).
On Cals with bridgedecks, I think they're fine. IOW, you don't need to keep the boards in as often, since the bottom of the companionway hatch is well up away from the cockpit sole, less chance of massive water intrusion. In really bad seas you'd want to keep them in, and in those situations you'd have all your sections of a divided hatchboard in anyway.
One issue I have now is that we just put in a radar/chartplotter on a swing arm, and while it works great, you can't use it in the cockpit if the hatchboard is in. I've thought of going to a completely transparent lexan hatchboard, or one with a "window" of clear lexan. Would it be crazy to put in a sliding door so one could reach in to adjust the radar without taking out the hatchboard? :-) Maybe now I'm getting silly.
bw
Cal 39-2 "Sea Star"
Richmond, CA
Sent: Wednesday, December 06, 2006 9:42 AM
Subject: Re: [Cal_Boats] Re: Lexan (Mike)
Daniel Casey
"Air Time"
Cal 9.2R #75
Santa Barbara, Ca.
RE: [Cal_Boats] Re: Lexan (Mike)(Cal 40)
ti… [at] ch2m.com2006-12-06 19:04 UTC
We cut the Cal 40 cover in two, so in a seaway
you can have some options.
We normally have only the bottom section in,
In moderate seas and the full two pieces in in heavier stuff.
In the baddest stuff, we have an aluminum cover for the vent
section.
All pieces oare on a lanyard, and store in a pouch on
the companionway ladder.
<http://home.att.net/~v.lessley/images/HB_1.jpg>
<http://home.att.net/~v.lessley/images/HB_2.jpg>
Behalf Of mtkennedy1
Sent: Wednesday, December 06, 2006 10:11 AM
Subject: [Cal_Boats] Re: Lexan (Mike)
hatch was flat and
easy to stow.
Mike Kennedy
> Daniel Casey
> "Air Time"
> Cal 9.2R #75
> Santa Barbara, Ca.
Downing, Thomas2006-12-07 17:14 UTC
> Bob Walden wrote:
[snip]
I think it's a good idea. On my Cal 2-27 I had a similar arrangement for my
chartplotter. In my case, the chartplotter was also on a swing arm, but
when swung aft for reading from the cockpit, it didn't swing into the companion,
instead it swung up flush against the aft bulkhead of the cabin, and just there
I cut a hole. I put an ordinary round access plate ring in it, and found a
flat and transparent access plate cover. Gluing a couple of small bits on
the outside edge of the cover made it easy to remove from the cockpit side.
So when the weather was fine, I just left the cover out. When it was snotty
or raining, I just removed it whenever I needed to punch a button. Of course,
that was a Garmin 182C, so a 4? 4.5? inch hole was perfect. For a radar the
bulkhead wouldn't be so good, but the idea of a hatch, sliding, hinged, what
ever works very well!
td
DISCLAIMER:
carlos Solanilla2006-12-08 01:13 UTC
can you make your lexan hatch door in 3 stacking pieces? Since the hatchboard is an upside down trapeze, then you can live the middle third hatch out and be able to see the plotter
Sent: Thursday, December 7, 2006 11:14:19 AM
Subject: RE: [Cal_Boats] Re: Lexan (Mike)
> Bob Walden wrote:
[snip]
td
DISCLAIMER:
Important Notice ************ ********* ********* ********* ********* *
Any questions? Get answers on any topic at www.Answers.yahoo.com. Try it now.
Bob Walden2006-12-08 03:41 UTC
hmm, interesting idea!
Sent: Thursday, December 07, 2006 5:13 PM
> Bob Walden wrote:
[snip]
td
DISCLAIMER:
Cheap Talk? Check out Yahoo! Messenger's low PC-to-Phone call rates.
Husar, Charlie2006-12-08 16:06 UTC
Hi, Carlos. when I make a multiple part hatchboard, I bevel (or
champher or slant) the the edges between the parts toward the outside.
Creates an overlap to keep water out in rain. Can be done with a
skilsaw with a sideguide (for straight cutting) and a canted bed on the
saw. I use wood, but lexan can be cut this way with a fine blade.
As Roger knows, I don't have a workshop. I do these on the picnic table
in my little back yard. Kinda puts a premium on creativity.
Behalf Of carlos Solanilla
Sent: Thursday, December 07, 2006 8:13 PM
> Bob Walden wrote:
[snip]
swing arm,
hatchboard is
hatchboard, or one
door so
hatchboard? :-)
my
companion,
just there
a
on
side.
snotty
course,
the
what
td
DISCLAIMER:
<http://us.rd.yahoo.com/mail_us/taglines/postman8/*http://us.rd.yahoo.co
m/evt=39663/*http://voice.yahoo.com> Yahoo! Messenger's low PC-to-Phone
call rates.
carlos Solanilla2006-12-08 16:56 UTC
That is how I made my lexan door in the CAL39. It has two pieces and I glued a lip on the top piece so the water will run outside. It works for me and it should work for three piece door
Sent: Friday, December 8, 2006 10:06:05 AM
Hi, Carlos. when I make a multiple part hatchboard, I bevel (or champher or slant) the the edges between the parts toward the outside. Creates an overlap to keep water out in rain. Can be done with a skilsaw with a sideguide (for straight cutting) and a canted bed on the saw. I use wood, but lexan can be cut this way with a fine blade.
As Roger knows, I don't have a workshop. I do these on the picnic table in my little back yard. Kinda puts a premium on creativity.
From: Cal_Boats@yahoogrou ps.com [mailto:Cal_ Boats@yahoogroup s.com] On Behalf Of carlos Solanilla
> Bob Walden wrote:
[snip]
td
DISCLAIMER:
Re: Lexan (Mike)
sail_c22006-12-08 18:01
--- In Ca… [at] yahoogroups.com, "Husar, Charlie" <husar_charlie@...>
The other way is via a "shiplap," or two matching rabbets that make a
right-angle Z-shaped edge--the top piece overhangs the bottom piece in
the lap. You can do this with a router, shaper, table saw with dado
blade, hand rabbet plane, or a jointer with that option.
With this version, you don't have sharp-pointed edges to chip and break.
