3 messages2006-12-14 22:15 UTCthrough 2006-12-15 05:09 UTC
rudder stock/tube/shaft
r good2006-12-14 22:15 UTC
A friend has acquired a new-to-him sailboat. He recently pulled the rudder
to find that corrosion has eaten through the rudder shaft/tube, creating
some perforations and a substantial groove just above the rudder body, where
the tube/shaft enters the hull. He is thinking about grinding qway enough
of the rudder body to allow a competant welder to repair the damage. Anyone
see a problem with that or have other recommendations?
WIN up to $10,000 in cash or prizes � enter the Microsoft Office Live
Sweepstakes http://clk.atdmt.com/MRT/go/aub0050001581mrt/direct/01/
RE: [Cal_Boats] rudder stock/tube/shaft
ti… [at] ch2m.com2006-12-14 23:05 UTC
This may be okay for a real short term fix, sailing in calm waters where
you can get help, immediately.
The post is most likely stainless, and from my experience, ss gets hard
in the heat effected zone, around the weld hoop. Stainless hard =
stainless brittle. If this is acceptable, risk wise, then the stainless
should be chemically passivated, hopefully to reduce future corrosion.
I've also noticed that once stainless begins the corrosion process, all
of it is bad... not just the places where the material has disappeared.
This a little like putting a band aid on a severed arm... may provide
some temporary relief, but probably will not save a life.
If cash is a problem, then it is possible to split the rudder skin, and
make a new shaft using your own labor. or, depending on the boat, Foss
Foam may have a "stock" solution for @ $1,000 - $1,500..
Another wild solution would be to sleeve the post (interior)... but the
correct solution is to replace with a new one.
We had a rudder with far fewer indications of failure than the one you
are describing, and began the Cal 40 rudder project. We co'oped 25
rudders being built, at a great discount.
dEmO
Behalf Of r good
Sent: Thursday, December 14, 2006 2:16 PM
To: ca… [at] list.sailnet.net; Ca… [at] yahoogroups.com; as… [at] rmlh.com
Subject: [Cal_Boats] rudder stock/tube/shaft
rudder
where
enough
Anyone
WIN up to $10,000 in cash or prizes - enter the Microsoft Office Live
Yahoo! Groups Links
r good2006-12-15 05:09 UTC
thanks, Tim.
and Mr. lentil, also!
>From: <ti… [at] ch2m.com>
>To: <Ca… [at] yahoogroups.com>
>Subject: RE: [Cal_Boats] rudder stock/tube/shaft
>Date: Thu, 14 Dec 2006 16:05:22 -0700
>dEmO
>-----Original Message-----
>Behalf Of r good
>rudder
>where
>enough
>Anyone
>Reggie
>_________________________________________________________________
>Yahoo! Groups Links
><< att5091c.jpg >>
