11 messages2006-12-20 14:17 through 2006-12-20 21:06 UTC
Drip Free/Dripless Packing
Travis2006-12-20 14:17
While my Cal 33-2 is on the hard, I'd like to do something besides the
typical packing. I don't want to spring for a mechanical seal but
would like to improve on standard packing. What experience does the
group have with these? I see some that are putty-like and some
packing rope that is teflon impregnated. What is recommended?
Travis
Re: [Cal_Boats] Drip Free/Dripless Packing
Bill Terrell2006-12-20 14:48 UTC
Hi Travis,
I use the normal Teflon packing (rope) on my Cal 33-2
and it usually last 3+ years without doing anything.
I've heard that the Gortex fiber packing is supposed
to be even better, but its harder to find. Here's one
place I found that carries it:
http://www.emarineinc.com/products/gfopacking/packing.html
I've repacked the stuffing box while the boat is in
the water before and it's really not a big deal. I
have a Rule pump in the engine bilge and just keep it
running while digging out the old stuff and inserting
new rings.
You want a minimum of three rings around the shaft.
Offset the cuts between the three rings by 1/3 each.
good luck,
Bill Terrell
"Tupelo Honey", '88 Cal 33-2
> mechanical seal but
> experience does the
> putty-like and some
> recommended?
> Thanks,
> Travis
steve honour2006-12-20 18:07 UTC
Hi Travis,
I got this stuff called GFO packing. I think it has gore-tex in it. Anyway it is amazing. Install it just like regular packing. And it will drip just like regular packing. For a while. Then it will miraculously quit or nearly quit. And, I swear, it does not get hot when the engine is running. I check. I've gone down numerous times to feel the gland while it is or has been running hard (for hours). Warm but not hot. I really love this stuff. It makes me laugh when I hear of all the money some people pay for dripless seals and some of the problems encountered. This is so easy. A truely great product. I tried it because the guy said it's what the Coasties use. I dunno if that is true but wouldn't be surprized. I've had it in there for years.
It seems to drip a bit while running, but then quits when stopped. And that's fine with me.
~smile~
SMon
Travis
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
RE: [Cal_Boats] Drip Free/Dripless Packing
John Vronay2006-12-20 18:35 UTC
Hi Travis,
Keep in mind that all packing materials require a small amount of leakage
through the ring-gland to function properly; even so called "drip-less"
packing material needs to leak a little. Therefore, you will always have
some dripping seawater. This is accompanied by friction & abrasion of the
packing on the shaft due to the rings riding on the shaft and the various
abrasives (mud and sand) that come in with the seawater. The only way to
avoid this is the mechanical face seal.
-John
Cal 2-30
Hull #4
"Francine"
Emeryville, California
Of Bill Terrell
Sent: Wednesday, December 20, 2006 6:48 AM
Subject: Re: [Cal_Boats] Drip Free/Dripless Packing
Hi Travis,
http://www.emarinei
<http://www.emarineinc.com/products/gfopacking/packing.html>
new rings.
good luck,
Bill Terrell
--- Travis <travlin74@sbcglobal <mailto:travlin74%40sbcglobal.net> .net>
> mechanical seal but
> experience does the
> putty-like and some
> recommended?
> Thanks,
> Travis
r good2006-12-20 18:45 UTC
IMHO Teflon
>From: "Travis" <tr… [at] sbcglobal.net>
>Subject: [Cal_Boats] Drip Free/Dripless Packing
>Date: Wed, 20 Dec 2006 14:17:50 -0000
>Thanks,
>Travis
Find sales, coupons, and free shipping, all in one place! �MSN Shopping
Sales & Deals
http://shopping.msn.com/content/shp/?ctid=198,ptnrid=176,ptnrdata=200639
Chris Campbell2006-12-20 19:01 UTC
The drips are needed when running, for lubrication, and not when
stopped, so it's perfect behavior.
My query for the engineers on the list is whether this fancy stuff might
become more abrasive by trapping more suspended solids in the water that
does run through. I recall reading that the shaft tends to wear more in
regions with silty water, because the silt stalls at the packing and
grinds away. That's why you need to move the packing's location on the
shaft sometimes, to move to an unworn area. Would this more-effective
packing trap more abrasive particles? Or, more likely, is the effect so
tiny that it doesn't matter?
John Vronay2006-12-20 19:33 UTC
Chris,
Depends on how much you run the engine I suppose.
If you were a powerboat, you would probably have a mechanical seal.
For us sailors, the packing seems to do just fine. The softer seal types
are more embeddable and tend to keep the grit in them and not trap it hard
between the packing and the shaft so I think the software materials are
probably better in this respect (for wear of the shaft). If you were really
concerned about the shaft, you could have it chromed in the way of the shaft
seal gland rings. Similarly, if your existing shaft is worn, you can have
it chrome plated back to the original diameter.
The main advantage of the softer materials (graphoil and Teflon) is their
lubricity; they generate less friction and do not require as much gland
water. They also do not dry out and lose their shape they way older seals
did if they were in to tight (insufficient sealing water) or if the boat was
on the hard.
Hope this helps.
-John
Of Chris Campbell
Sent: Wednesday, December 20, 2006 11:02 AM
The drips are needed when running, for lubrication, and not when stopped, so
regions with silty water, because the silt stalls at the packing and grinds
away. That's why you need to move the packing's location on the shaft
sometimes, to move to an unworn area. Would this more-effective packing
trap more abrasive particles? Or, more likely, is the effect so tiny that
it doesn't matter?
Sail Away2006-12-20 19:53 UTC
I replaced my complete stuffing box on my new-to-me boat this past year and used the teflon packing.....it worked drip free. Good stuff with the safety of the traditional stuffing box set-up
Greg
1986 P36-2
1977 Cal 34 III (for sale)
Sent: Wednesday, December 20, 2006 9:17 AM
Travis
Sail Away2006-12-20 20:00 UTC
Actually it was GFO packing not Teflon that I use and again the stuff is great. I always check to see if the packing nut and shaft get hot and it only gets warm even after several hours of running.....great stuff.
Greg
Sent: Wednesday, December 20, 2006 2:53 PM
Greg
1986 P36-2
Travis
Joe DeMers2006-12-20 20:08 UTC
Sent: Wednesday, December 20, 2006 1:35 PM
Subject: RE: [Cal_Boats] Drip Free/Dripless Packing
Hi Travis,
Keep in mind that all packing materials require a small amount of leakage through the ring-gland to function properly; even so called "drip-less" packing material needs to leak a little.
****** This is incorrect. When we install a new shaft and Gore tex packing, it will not leak at all, assuming the packing nut is adjusted correctly and engine alignment is also correct.
Therefore, you will always have some dripping seawater. This is accompanied by friction & abrasion of the packing on the shaft due to the rings riding on the shaft and the various abrasives (mud and sand) that come in with the seawater. The only way to avoid this is the mechanical face seal.
***** Mechanical face seals are MORE susceptible to grit in the water. This is why they are not recommended for Cape Cod or the Florida pan hadle.
Joe DeMers
Sound Marine Diesel LLC
www.soundmarinediesel.com
-John
Cal 2-30
Hull #4
"Francine"
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Bill Terrell
Hi Travis,
new rings.
good luck,
Bill Terrell
> mechanical seal but
> experience does the
> putty-like and some
> recommended?
> Thanks,
> Travis
Chris Campbell2006-12-20 21:06 UTC
John Vronay wrote:
> If you were really concerned about the shaft, you could have it
> chromed in the way of the shaft seal gland rings. Similarly, if your
> existing shaft is worn, you can have it chrome plated back to the
> original diameter.
John:
I am grateful all over again for having an outboard. At least until the
next time it decides not to run at some crucial moment.
I'm curious about the chrome plating. How do you plate a portion of a
shaft? Or do you just do the whole thing? I think of plating tanks and
getting just part of the shaft in it, or even the whole shaft, would be
quite an exercise unless the tank were really big or the shaft quite
short. If short shaft or long tank, I guess you could just mask off the
part you didn't want plated, using some sort of impervious coating where
you didn't want plating.
