4 messages2006-12-26 09:13 UTCthrough 2006-12-28 16:40 UTC
Static dissipaters, was..Re: Through Hull: now grounding
Gerald Sobel2006-12-26 09:13 UTC
Just my guess, but I'd bet a tree, with all its leaves and branches, and being a living organism with electrolyte, makes a good static dissipater. Therefore, one should always sit under a tree, or better yet, climb into a tree, during a lightening storm. So why is it that it isn't recommended to do so during a strom, and why does lightening frequently strike trees?
I don't think lightening is very smart.
I saw a video on lightning strikes, and one victim was a teller working in a bank in an office, at his desk, who was struck, even tho the storm clouds were miles away. The discharge came in through the metal frame of the outdoor teller window and followed electric cables through the office. The strike left him permanently disabled.
Just a guess, but isn't grounding the mast make it more likely to attract a lightening strike, in the first place? Then grounding bronze through holes to the mast sounds like looking for trouble. If you must, leave the through holes ungrounded, and clamp a heavy electric cable, the thickest one you can find, to the mast and trail it overboard, away from where you're sitting
Re: [Cal_Boats] Static dissipaters, was..Re: Through Hull: now grounding
walter2006-12-26 14:55 UTC
I have seen the aftermath of trees hit by lightning and they (at least,
the trees I have seen) look like and exploded pile of toothpicks.
Conductivity in trees is not good. So they cannot conduct the energy
efficiently to the ground. So the lighting often comes out the sides of
the trunk simply because it can't drain to the ground quickly enough.
Kind of like a sewer backing up. And that is why you DON'T want to be
near a tree in a lightning storm. The lightning hits the tree because
it is the most convenient item around but because it is a poor
conductor the energy leaves the tree (no pun intended :) ) in multiple
places. I am not certain, but I strongly suspect the human body is a
much better conductor than the tree. This makes the human a likely
target if he is close to the tree.
Lighting is likely to hit the mast anyway if one is near a potential
discharge area. The idea is to make the pathway easier to go to ground
and hope the mast (and every everything else) is spared.
I am NOT an expert in lighting. But I worked as a high voltage
electrician for about 8 years for the Federal Gov't. I worked with
voltages up to 12 KV. Lighting is WAY higher than that. It is a whole
other ball game.
Don't stand near any trees and get as far away from the mast and
shrouds as you can :)
Walter MacArthur
Tejana
'70 Cal34 #301
RE: [Cal_Boats] Static dissipaters, was..Re: Through Hull: now grounding
dwowen2006-12-26 23:14 UTC
Back on the farm in Kansas, I have had lightning strike a tree outside my
home and then jump across to an upstairs breaker box (probably a 6' gap, if
I remember right,) blowing the panel cover completely off but doing
otherwise minor damage. The siding was split and singed, the tree split in
places but not destroyed.
Very strange stuff, lightning.
David Wilkie Owen
Of walter
Sent: Tuesday, December 26, 2006 6:55 AM
Subject: Re: [Cal_Boats] Static dissipaters, was..Re: Through Hull: now
grounding
I have seen the aftermath of trees hit by lightning and they (at least, the
trees I have seen) look like and exploded pile of toothpicks. Conductivity
in trees is not good. So they cannot conduct the energy efficiently to the
ground. So the lighting often comes out the sides of the trunk simply
because it can't drain to the ground quickly enough. Kind of like a sewer
backing up. And that is why you DON'T want to be near a tree in a lightning
storm. The lightning hits the tree because it is the most convenient item
around but because it is a poor conductor the energy leaves the tree (no
pun intended :) ) in multiple places. I am not certain, but I strongly
suspect the human body is a much better conductor than the tree. This makes
the human a likely target if he is close to the tree.
discharge area. The idea is to make the pathway easier to go to ground and
I am NOT an expert in lighting. But I worked as a high voltage electrician
for about 8 years for the Federal Gov't. I worked with voltages up to 12
KV. Lighting is WAY higher than that. It is a whole other ball game.
Don't stand near any trees and get as far away from the mast and shrouds as
you can :)
Walter MacArthur
Tejana
'70 Cal34 #301
strike trees?
Chris Campbell2006-12-28 16:40 UTC
> least, the trees I have seen) look like and exploded pile of
> toothpicks. Conductivity in trees is not good. So they cannot conduct
> the energy efficiently to the ground. So the lighting often comes out
> the sides of the trunk simply because it can't drain to the ground
> quickly enough.
One problem with trees is that they have a higher resistance than, say,
copper wire, so they heat up from carrying high lightning currents and
the moisture boils and the wood explodes.
I have a big cottonwood, the highest tree around, and it was struck last
summer. I was not there. The noise was, according to neighbors, quite
astonishing. There is a track down the trunk where the bark popped off,
about 2-3" wide, and a furrow in the sapwood about an inch across and
deep.
Interestingly, the tree did not lose foliage after the strike except
right at the point of contact, and seems to be OK. I've got my fingers
crossed, both because I like the big tree and because it would cost a
small fortune to have it cut down.
