5 messages2007-01-16 18:38 through 2007-01-18 15:48 UTC
LED for running/navigation lights
edwardperrow2007-01-16 18:38
I am incrementally replacing my cabin light bulbs with LED clusters and
would like to replace my navigation light bults with LEDs AND HAVE
SEVERAL QUESTIONS; (i) are there USCG issues, (ii) any suggestions for
sources and (iii) what are others experience with the nav/running light
options?
Thanks and fair winds,
Ed Perrow
CAL 25-2, Spirit
Lake Lanier, GA
Re: LED for running/navigation lights
mtkennedy12007-01-16 23:33
> options?
I have a Lopolight masthead tricolor for the 40. The new ones are improving quickly and
there is more variety even than a year ago.
Mike Kennedy
Conqust Cal 40 # 96
> Ed Perrow
> CAL 25-2, Spirit
> Lake Lanier, GA
RE: [Cal_Boats] LED for running/navigation lights
ti… [at] ch2m.com2007-01-17 00:04 UTC
I've found these products to be cheap and readily available.
http://www.superbrightleds.com/1157.htm
I am testing a number of the bulbs in different parts of my boat
and have made new LED running lights.. using my original housings
with new LED bulbs. My cabin lights are now with the clusters, or the
light grids.
The cluster bulbs are not as bright as stock, and have ample light for
general purpose, but are not bright enough to be considered "task"
lights,
i.e. reading fine print or pulling out a sliver.
For the stern light I'm using the (9 led)festoon bulb, and in the bow
lights
a red and a green Luxeon 1 watt bulb set. These are VERY bright!!! in
fact
there is a warning to not stare at the light for too long at a close
proximity.
On the foredeck light and steaming, I've also adapted the std housing
for the 1 watt
Luxeon white LED's.
So far the only problem I've discovered is when my alternator went to 16
volts
during a delivery, the green LED burned out... You also have to be
careful with the
polarity on the Luxeon.. reverse will blow up the light...
The standard housings are of ample size to hold the new lights, and the
holders
limit the light arc to the correct Coast Guard angles. They are brighter
than
the "stock bulbs" so I'm confident that they meet the range
requirements.
Doctor Evil says "Very cool stuff, just like my lazerrrrr beam"
dEmO
Behalf Of edwardperrow
Sent: Tuesday, January 16, 2007 10:38 AM
Subject: [Cal_Boats] LED for running/navigation lights
options?
Ed Perrow
CAL 25-2, Spirit
Lake Lanier, GA
Re: [Cal_Boats] LED for running/navigation lights
Bob Walden2007-01-18 15:20 UTC
My only experience is with the bow lights on a Cal 39; it took 3 tries to
get the wiring really waterproof enough both in the light enclosures and
inside the anchor locker. Make sure you use only marine-grade electrical
connectors and high-quality shrink-wrap.
I found some "liquid shrink wrap" (look for it at west marine, etc) that
works well, especially if you use it first as a base layer, then add 2
layers of regular shrink-wrap (2nd cut longer than 1st), and then some more
of this liquid shrink-wrap over all.
Now I have a question: I've wanted to put LED courtesy lights in the boats
in places where they can be used for work light, such as the galley, salon
for reading lights, and in the berths. I'd like them each to have their own
switch, but so far I have not found any low-intensity white LED lights that
include their own switches. Anyone seen something like these?
bw
> options?
> Ed Perrow
> CAL 25-2, Spirit
> Lake Lanier, GA
> Yahoo! Groups Links
Bruce Stirling2007-01-18 15:48 UTC
Costco had a deal just before Christmas on a package of three LED lights,
each having five (5) "super bright" white LEDs per light. All for about
$20.00. They are battery operated, on-off switch, and the light head
swivels and pivots for "ideal light positions." Three AAA batteries per
light. They are called "LUMEN" and they are warrantied for two years. They
attach with either velcro or a screw.
I posted a photo online here:
http://www.stirlinglaw.com/cal28/lumen.jpg
http://www.stirlinglaw.com/cal28/lumen2.jpg
{give me a minute to post them up there}
> options?
> Ed Perrow
> CAL 25-2, Spirit
> Lake Lanier, GA
> Yahoo! Groups Links
