6 messages2007-01-18 16:01 through 2007-01-19 23:05 UTC
cal 39 mast
Jeff Baumgardner2007-01-18 16:01
There is minor corrosion at my mast base. There is supossedly a drain
at the base of the mast to allow water to exit. I cant see where it is.
I remived a couple trim pieces of the sole to see the step and clean it
up but didn't see a drain hole. Any help?
Re: cal 39 mast
mtkennedy12007-01-19 01:09
Drill one. If corrosion is bad, you may have to cut a bit off the bottom. That would require
adjusting the shroud length and that depends on how much extra thread you have on rigging
screws. How old is the rigging ?
Mike Kennedy
Conquest Cal 40 # 96
Re: cal 39 mast
Jeff Baumgardner2007-01-19 21:27
Rigging has been replaced piece by piece. Corrosion doesn't appear to
be that bad to me. Where do I drill the hole, just a 1/4" hole close
to the bottom? I know there is a casting there and I don't want to
drill into that. I wonder if the hole is on the side against the
bathroom where I cant see.
--- In Ca… [at] yahoogroups.com, "mtkennedy1" <mtkennedy1@...> wrote:
> --- In Ca… [at] yahoogroups.com, "Jeff Baumgardner" <jeffbum1@>
drain
it is.
clean it
> Mike Kennedy
Re: cal 39 mast
mtkennedy12007-01-19 21:46
If the step is like the 40's, there is a metal casting that the mast sits on but it has an X
shape with the arms of the X fore and aft plus side to side. If you drill about 3/4 inch
above the bottom and not directly in the center of the side, it should be OK. I have a 1/2
inch hole for a pin to keep the mast from jumping off the step in a capsize. That is an
offshore rules requirement.
If the corrosion isn't bad, why drill it ?
Mike Kennedy
> drain
> it is.
> clean it
> > Mike Kennedy
RE: [Cal_Boats] Re: cal 39 mast
Harleigh Ewell2007-01-19 22:33 UTC
Sounds like a job for one of those extendable mirrors.
Harleigh Ewell
Cal 31, Magothy River, Chesapeake Bay
Of Jeff Baumgardner
Sent: Friday, January 19, 2007 4:28 PM
Subject: [Cal_Boats] Re: cal 39 mast
Re: [Cal_Boats] Re: cal 39 mast
Duane Knize2007-01-19 23:05 UTC
Jeff,
The original 1971-72 C39 was based on the C40 so the mast step is as
Mike described.
The later 1977 + models have the aluminum mast base plate that sits
on a larger stainless plate that sits on fiberglass floors.
Somewhere between hull # 18 and 25 Jensen started using a full floor
pan so there is a layer of fiberglass (and perhaps no ss plate) in those steps.
You should be able to drill down straight through the base plate and
floors right into the bilge without any problems.
Jeff what vintage is your Cal 39?
I don't see you on the Cal 39 list that Jim Williams compiled. If you
can forward the HIN, boat name, location, etc we can add you.
The masts that have some corrosion evidence seem to also have
internal halyards.
I don't, and when my mast was pulled for refinishing (at 20 years
old) the base looked shiny and new and still full of metal chips from
the original fitting out.
There is no drain hole.
Regards,
Duane
Duane & Lynn Knize
Marlyn, 1978 Cal 2-39, #18
Berthed: Emeryville, CA
>--- In
><mailto:Cal_Boats%40yahoogroups.com>Ca… [at] yahoogroups.com,
> > --- In
>drain
>it is.
>clean it
> > Mike Kennedy
Duane & Lynn Knize
