7 messages2007-01-22 17:01 UTCthrough 2007-01-24 01:47
Re: Night Vision (was LED for running/navigation lights)
Alfred Poor2007-01-22 17:01 UTC
I recall from my pilot training that the red light to preserve night vision
is an old wive's tale (old sailor's tale?). I believe the theory is that
either the rods in the retina are less sensitive to red light, and thus red
light is less damaging to night vision. As I understand it, scientists now
believe that it's the intensity of the light and not the wavelength that is
important, and so any dim light will do. Avoid a bright point source if
possible, which means using as much of a diffuser as is practical to still
provide enough illumination.
Keep in mind that it takes the eyes just 10 to adjust from dim to bright
light, but it takes 30 to 45 minutes to adjust from bright to dim. This is
because your eyes actually have to manufacture a chemical required for dim
light vision. Also keep in mind that the cones are concentrated in the
center of your retina; these are the ones that see color and detail. The
rods are the ones that work in dim light, and there are very few in the
center of your field of vision. This is why you should keep a constant sweep
going when keeping watch at night, and not fixate in any one direction. You
may not see objects when you look directly at them, but only when you are
looking off to one side or the other. (Try this with the Pleides - the Seven
Sisters - some dark night. You can't see them when you look straight at
them, but they will appear in view if you look to one side or the other.)
Alfred Poor
1969 Cal 29 #132, "Pentaquod"
<http://groups.yahoo.com/group/Cal_Boats/message/5456;_ylc=X3oDMTJycHY1OGJhB
F9TAzk3MzU5NzE1BGdycElkAzE2NDg1Njk1BGdycHNwSWQDMTcwNTA2NTc5MgRtc2dJZAM1NDU2B
HNlYwNkbXNnBHNsawN2bXNnBHN0aW1lAzExNjk0NzE1MzM-> Re: LED for
Posted by: "Randy Alcorn"
<mailto:sa… [at] yahoo.com?Subject=%20Re%3A%20LED%20for%20running%2Fnavigat
ion%20lights> sa… [at] yahoo.com <http://profiles.yahoo.com/saylorran>
saylorran
Sun Jan 21, 2007 9:00 pm (PST)
Hi,
I am assembling a Flying Tiger 10 meter for this seasons races. It came as a
boat in a box!
What a great experience!
All lights are LED.
I am surprised the nav station has a blue light. I gues I was raised with
red lighting to protect the eyes at night.
Randy
CAL 2-29
Out Patient
Channel Islands Ca
Re: [Cal_Boats] Re: Night Vision (was LED for running/navigation lights)
Chris Campbell2007-01-22 17:45 UTC
> vision is an old wive's tale (old sailor's tale?). I believe the
> theory is that either the rods in the retina are less sensitive to red
> light, and thus red light is less damaging to night vision. As I
> understand it, scientists now believe that it's the intensity of the
> light and not the wavelength that is important, and so any dim light
> will do. Avoid a bright point source if possible, which means using as
> much of a diffuser as is practical to still provide enough illumination.
> bright light, but it takes 30 to 45 minutes to adjust from bright to dim.
This is what I have read, also. One trick when you must use bright
light during a stint at the helm is to close one eye in the bright
light, using the other only. Then you have "one good eye."
RE: [Cal_Boats] Re: Night Vision (was LED for running/navigation lights)
Husar, Charlie2007-01-22 18:24 UTC
There was a series of Chesapeake Bay chart books (Alexandria Drafting
Company?) that had many points on the Bay marked in red type. We'd go
onto red night vision on the boat and all the markings would disappear.
It seems the Navy did (does?) the red thing on ships. Is that true?
Behalf Of Chris Campbell
Sent: Monday, January 22, 2007 12:45 PM
Subject: Re: [Cal_Boats] Re: Night Vision (was LED for
night vision is an old wive's tale (old sailor's tale?). I believe the
to bright light, but it takes 30 to 45 minutes to adjust from bright to
dim.
Chris Campbell2007-01-22 19:00 UTC
My recall is that they've gone to green.
Robert Andrew2007-01-22 20:15 UTC
Interestingly, I just ordered a retrofit binnacle light for my 30 year old
Ritchie (the old one finally disintegrated) - the light was available in
either red or green.
Bob Andrew
Of Chris Campbell
Sent: Monday, January 22, 2007 2:00 PM
Subject: Re: [Cal_Boats] Re: Night Vision (was LED for running/navigation
lights)
Company?) that had many points on the Bay marked in red type. We'd go onto
st… [at] us.ul.com2007-01-22 23:06 UTC
The Discover Channel show "Myth Busters" just did an experiment to prove or
disprove the myth that pirates wore an eye patch so one eye was always
night-vision ready. Often, the scientific methods used on this show are
questionable. However, in this instance, the results were conclusive
despite the subjective nature of how well one sees. Wearing an eye patch
does provide night vision readiness while the other eye is exposed to
light. One simply designates which eye is to be used for night and which
for light and moves the patch from one eye to the other as required.
Does West Marine carry eye patches ?
Steve Urbanski
Ca… [at] yahoogroups.com wrote on 01/22/2007 11:45:26 AM:
> vision is an old wive?s tale (old sailor?s tale?). I believe the
> red light, and thus red light is less damaging to night vision. As I
> understand it, scientists now believe that it?s the intensity of the
> as much of a diffuser as is practical to still provide enough
illumination.
> Chris Campbell
- For more information about UL, its Marks, and its services for
EMC, quality registrations and product certifications for global
markets, please access our web sites at http://www.ul.com and
http://www.ulc.ca or contact your local sales representative. --
********* Internet E-mail Confidentiality Disclaimer **********
This e-mail message may contain privileged or confidential
information. If you are not the intended recipient, you may not
disclose, use, disseminate, distribute, copy or rely upon this
message or attachment in any way. If you received this e-mail
message in error, please return by forwarding the message and
its attachments to the sender.
UL and its affiliates do not accept liability for any errors,
omissions, corruption or virus in the contents of this message
or any attachments.
Bruce Stirling2007-01-24 01:47
I did a sort of Transpac of my own, commonly called a Tiger Cruise
aboard a U.S. Navy frigate homeward bound from Hawaii to Everett, WA.
Family of sailors are allowed onboard for the return trip. We were
shown the combat room, which was very dark and lit only with red
lights. My nephew reported the only time the lights were not red was
when she was in port.
Here she is: http://www.navsource.org/archives/07/0761.htm
We'd go
disappear.
> Chris Campbell
