Starting Cold Diesel Engines--Magnetic Block Heaters a Help?
3 messages2007-02-02 22:26 through 2007-02-03 14:41 UTC
Travis2007-02-02 22:26
Hi, I've seen on the web that magnetic block heaters can be purchased for use on engine blocks. They only cost about $30. Does anyone have any experience with these? Thanks, Travis Cal 33-2
Re: [Cal_Boats] Starting Cold Diesel Engines--Another solution
Tom Vandiver2007-02-03 11:56 UTC
This works for me here in FL. If the month's name has a "R" in it, never go north of Interstate 10. Tom Vandiver, down on the bayou --- Travis <tr… [at] sbcglobal.net> wrote: > Hi, > I've seen on the web that magnetic block heaters can > be purchased for > use on engine blocks. They only cost about $30. > Does anyone have any > experience with these? > > Thanks, > Travis > Cal 33-2 > >
Re: [Cal_Boats] Starting Cold Diesel Engines--Magnetic Block Heaters a Help?
Joe DeMers2007-02-03 14:41 UTC
I'm a dealer for Wolverine oil pan heaters. They are 'peel and stick' type installation onto the oil pan, and work very well, while consuming MUCH less power than the traditional block heaters. Joe DeMers Sound Marine Diesel LLC www.soundmarinediesel.com From: "Travis" <tr… [at] sbcglobal.net> To: <Ca… [at] yahoogroups.com> Sent: Friday, February 02, 2007 5:26 PM Subject: [Cal_Boats] Starting Cold Diesel Engines--Magnetic Block Heaters a Help? > Hi, > I've seen on the web that magnetic block heaters can be purchased for > use on engine blocks. They only cost about $30. Does anyone have any > experience with these? > > Thanks, > Travis > Cal 33-2 > > > > > Yahoo! Groups Links > > >
