3 messages2007-03-11 13:43 through 2007-03-11 17:25
Raised the stick!
jeribelle20002007-03-11 13:43
We're over at the DH's boatyard. Mast is up, boom is up, and rigging
close to finished. Replaced the old laptop recently and got a USB
floppy drive so we can still use our camera - old technology but
still takes nice photos. At the time the yard empties out a bit we
will be able to take photos. Right now we're sitting between a couple
of 100 footer tri-deck megayachts, and we're still the tallest thing
in the yard, at least on the water.
For those who recall, I'm close to finished varnishing the old Mamu
wheel. It is turning out gorgeous. So well, in fact, that the
interior designer here wants me to come to work. Not. I've enough to
do on this refit here. But it was nice that it's going so well.
Varnishing lots of the other tired teak these days also. FL winter
weather is agreeable for that task.
Hull is now compounded and waxed, and even shines. I've about 4 coats
of Meguiars on it now.
Also, a quick fix for anybody having ports with rubber gaskets. We
retrieved tubes of sikka-flex that were bent from the trash here.
Taped off the rubber around the gaskets, both hull and window. After
several coats of a rubber paint made for tool handles and such to
fill in the cracks in the rubber, my friend and I (Tar Baby and
Rubber Girl, the super heroes!), caulked the black rubber with sikka-
flex to seal against hull and windows. Ended up just covering all the
black rubber with sikka-flex. I waxed the white inner trim piece with
Meguiars, which lifted all the old dirt from it. Ports are now ready
for some type of cleaning/buffing with something. Not sure what.
Still trying to find out how to get scratches out. Tried the scratch
remover products for lexan and strataglass, but only by hand, and
didn't do the trick. But the ports no longer leak one iota, and look
brand new. Leaves a chunk of change for other stuff we need.
Sailmaker will be by next week to pick up sails to inspect and modify
for the furler, if possible. So we're moving closer to raising a
sail. After sucking air over line prices for running rigging, I found
Maritime Cordage, in Canada, which was a better price, despite
shipping to FL, than anything comparable from the US manufacturers.
Very nice line. So nice, in fact, that one of the captains here for a
refit on an 80 footer is going to use Maritime Cordage for all the
rigging on it.
Photos to follow.
girlsaylor
Re: [Cal_Boats] Polishing plexi
Tom Vandiver2007-03-11 15:37 UTC
Hi,
Here's how we didit. Embedded msgs. Look for ***
> up, and rigging
> and got a USB
> technology but
> between a couple
> the tallest thing
> that the
> Not. I've enough to
> going so well.
> also. FL winter
> I've about 4 coats
> rubber gaskets. We
> the trash here.
> and window. After
> handles and such to
> (Tar Baby and
> rubber with sikka-
> covering all the
> Ports are now ready
> Not sure what.
> Tried the scratch
> by hand, and
> one iota, and look
> we need.
*** We have used 3-M's Finnessette gentle rubbing
compound with a slow RPM sheepskin buffing pad. Make
sure the buffing pad is clean and go slowly.
We have buffed out older classic powerboat windshields
that were totally clouded, imposssible to see through.
First wash using water and TSP, dried, used 3-M Gel
Coat compound, then Finnesseit. Learned about this
from EAA, Experimental Aircraft Association, restoring
antique planes. Works on boats too.
I don't have interest in 3-M, wish I had.
Tom and Bobbie Vandiver Cal 46 & 25
Bayou Chico, FL
> inspect and modify
> to raising a
> rigging, I found
> price, despite
> manufacturers.
> captains here for a
> Cordage for all the
> rigging on it.
> Photos to follow.
> girlsaylor
Re: Polishing plexi
jeribelle20002007-03-11 17:25
Thank you Tom. I've got the info bookmarked so I can move forward and
finally see out of those windows.
Hoping to get our spinnaker pole up and take some measurements today
for a boom tent to hang up forward to help shade the deck in the hot
FL sun.
girlsaylor
- In Ca… [at] yahoogroups.com, Tom Vandiver <bshmarine@...> wrote:
> Hi,
> > up, and rigging
> > and got a USB
> > technology but
> > between a couple
> > the tallest thing
> > that the
> > Not. I've enough to
> > going so well.
> > also. FL winter
> > I've about 4 coats
> > rubber gaskets. We
> > the trash here.
> > and window. After
> > handles and such to
> > (Tar Baby and
> > rubber with sikka-
> > covering all the
> > Ports are now ready
> > Not sure what.
> > Tried the scratch
> > by hand, and
> > one iota, and look
> > we need.
> Bayou Chico, FL
> > inspect and modify
> > to raising a
> > rigging, I found
> > price, despite
> > manufacturers.
> > captains here for a
> > Cordage for all the
> > rigging on it.
> > Photos to follow.
> > girlsaylor
