19 messages2007-04-05 22:33 through 2007-04-10 11:49 UTC
How to Properly Use Sail Repair Tape
Bruce Stirling2007-04-05 22:33
I haven't been able to get to San Diego since December, when I tore my
main. No time to convert new sail from rope, either. I did
previously buy sail tape, and I was thinking it would be the quickest
way to get me back on the water while I figured out my other sail
problems.
Question: Is there a proper technique I should be aware of? Do I
just iron the tape on? No instructions received. Guess I could
Google this. Thought I'd raise it with the experts here first.
Thanks to all who responded to my "mineral oil" inquiry, too.
At the rate I am going, I will not get back to my boat until sometime
in May!
Bruce Stirling
Gangfurd
Cal 28 - Hull 82
http://www.stirlinglaw.com/cal28
Re: [Cal_Boats] Need help Bending t-track
scott2007-04-06 01:32 UTC
Hello
I'm extending the jib tracks on my 2-29 and need help on how to bend the new sail track
any ideas would be great.
Scott
2-29 1975 hull 22 Coyote pt SFbay
It's here! Your new message!
Get new email alerts with the free Yahoo! Toolbar.
Re: [Cal_Boats] How to Properly Use Sail Repair Tape
Chris Campbell2007-04-06 13:57 UTC
> problems.
My experience with sail tape is the stuff that's sticky-backed ripstop
nylon--it has the visible grid in it. I've viewed this stuff as mostly
suitable for low-stress repairs like small holes and tears, but not for
high-load repairs. If your main is torn in a high-load location, like
along the leech or the luff, then I don't think the tape is adequate.
It will hold until the wind pipes up a bit and then, when you are least
in the mood for disaster, it will part.
The hand stitch that's best for these repairs is the baseball stitch.
I've read several articles on how to do it and they always left my head
swimming. Then a friend described it by e-mail and somehow her
description created a picture in my head. I still haven't tried the
stitch but now it seems possible. Do a Google search on "baseball
stitch" and see what you find. If no luck, e-mail me and I'll dig it
out of my home computer.
Better still, of course, is a zig-zag sewing machine. I've got an old
straight-stitch model that I use for sail and boat covers and it would
probably put a stitch in a sail, too, if the cloth were not too heavy.
You can pick op old cast-iron sewing machines very cheaply.
RE: [Cal_Boats] Need help Bending t-track
ti… [at] ch2m.com2007-04-06 16:03 UTC
If you buy the track from Garhauer, they'll bend it for you, and drill
the holes where you want.
They have a great shop, but you typically need to give them a few
months, on this type order.
dEmO
Behalf Of scott
Sent: Thursday, April 05, 2007 6:33 PM
Subject: Re: [Cal_Boats] Need help Bending t-track
Hello
Scott
<http://geo.yahoo.com/serv?s=97359714/grpId=16485695/grpspId=1705065792/
msgId=6439/stime=1175812517/nc1=4438963/nc2=4430620/nc3=3848616>
<http://us.rd.yahoo.com/evt=49938/*http://tools.search.yahoo.com/toolbar
/features/mail/> with the free Yahoo! Toolbar.
/features/mail/>
Re: Need help Bending t-track
mtkennedy12007-04-06 17:00
--- In Ca… [at] yahoogroups.com, scott <sscot12@...> wrote:
> Hello
track
One way is to bolt it on one bolt at a time, bending a little each time you bolt the next
segment.
Mike Kennedy
Conquest Cal 40 # 96
> Scott
RE: [Cal_Boats] How to Properly Use Sail Repair Tape
ti… [at] ch2m.com2007-04-06 17:21 UTC
The proper use of sail tape, is like the 40mph/ 500 mile spare, in your
car trunk. It's to get you home,
so you can make a proper repair. Tape has almost no strength on Dacron
sails. IMHO
I'm assuming you have a "vintage" Dacron sail/ not new. If the tear is
quite small, tape may keep
the hole from snagging on something. If the tear is in any "strength
location" of the sail, then tape
will not work. Like the head, tack, or clew, where the tear is on the
arc from the corner. What tore
the sail?, if it propagated on it's own, then the material may be
rotten, and the ultimate failure is lurking.
To try to get sail tape to Dacron, the Dacron must be dry and clean. A
solvent like MEK is what we
used as sail makers (not for repair tape, but for sail numbers) to
improve adhering. Round the corners
of the patch, and patch both sides. If the sail is salty, then removing
the salt will also improve the temporary
patches success of sticking.
If the sail is "Mylar", then use Mylar tape. The skin on these sails
only holds the strength threads in place,
and assists in flowing the air.
dEmO
Behalf Of Bruce Stirling
Sent: Thursday, April 05, 2007 3:34 PM
Subject: [Cal_Boats] How to Properly Use Sail Repair Tape
problems.
in May!
Bruce Stirling
Gangfurd
Cal 28 - Hull 82
http://www.stirlinglaw.com/cal28 <http://www.stirlinglaw.com/cal28>
prop for Cal 33
John Raxter ~~~~~_/)~~~~2007-04-06 22:36 UTC
Help! I am in a quandary!
The boat is hauled and I believe I could use a new prop. We are getting a
slight vibration (knock) in the prop at a certain RPM (2500?) and I think
this is due to the bottom paint/protective coating plus years of sanding and
cleaning. If a new prop is in the future, now is the time.
Boat specs: cal 33; 27.5 LWL; 10800 disp; engine yanmar 3gm30f (27hp@3600)
rated 24hp in the manual. 2.36:1 transmission. Current prop 16x15 RH 2
blade. 1 ¼ shaft.
We are mostly cruisers, not racing, and use the Rule of 3s to please the
Admiral: Under 3 knots or making more than 3 tacks to get to our
destination, the engine starts and we are motoring. (G)
I understand that a three blade prop might be better for motoring, when the
wind gets over 30 knots and sailing into the breeze. Will this help backing
the boat, and maneuvering into the slip? What size would be recommended for
the 3 blade vs 2 blade? Do I need to keep the 16 x15 spec? I have
researched the internet as much as I can without confusing myself, so asking
yall for opinions that will help make my final decision.
One prop calculator recommended 14.7 x 11.74 based on my specs above. Does
this sound correct? It does not specify 2 or 3 blades. Do I need to make
any adjustments to this spec for the 2 or 3 bade choice?
One final question: Teflon packing or Goretex? PTFE from WM is $ 7.50. GFO
is $ 15. I trust any recommendation yall can offer.
Thanks for your help?
John
Re: [Cal_Boats] prop for Cal 33
Bill Terrell2007-04-07 00:11 UTC
My Cal 33-2 originally had a 16x13 2-blade Michigan Sailor prop. I
replaced it with a 2-blade 16" Max-prop (size recommended by PYI-Inc).
Forward performance seems to be about as with the fixed prop, but the
MaxProp is better in reverse. I initially noticed a slight difference
in speed when sailing in very light winds (<10kts). We race our boat
often so every little bit helps!! I think a folding 2 or 3 blade prop
like Flex-o-fold would be another good option and reduces the chance of
catching pot warps on the prop.
Its very possible your prop or shaft needs to be balanced. If you're
going to put on another prop, I'd first recommend that you get the
shaft checked by a local prop shop. Also check engine alignment as
both of these can cause vibration that occurs only at certain RPMs.
-Bill
"Tupelo Honey", Cal 33-2
> getting a
> think
> sanding and
> (27hp@3600)
> 2
> blade. 1 ¼ shaft.
> the
> when the
> backing
> recommended for
> asking
> Does
> make
> 7.50. GFO
> John
Joe DeMers2007-04-07 02:29 UTC
Sent: Friday, April 06, 2007 6:36 PM
Subject: [Cal_Boats] prop for Cal 33
The boat is hauled and I believe I could use a new prop. We are getting a slight vibration (knock) in the prop at a certain RPM (2500?) and I think this is due to the bottom paint/protective coating plus years of sanding and cleaning. If a new prop is in the future, now is the time.
***** There are many reasons for vibration, one of which could be the prop.
Boat specs: cal 33; 27.5 LWL; 10800 disp; engine yanmar 3gm30f (27hp@3600) rated 24hp in the manual. 2.36:1 transmission. Current prop 16x15 RH 2 blade. 1 ¼" shaft.
We are mostly cruisers, not racing, and use the Rule of 3's to please the Admiral: Under 3 knots or making more than 3 tacks to get to our destination, the engine starts and we are motoring. (G)
***** It provides more thrust than a 2 blade prop, and is preferred when fighting wind, current, and wave. The trade off is cost and sailing resistance.
when the wind gets over 30 knots and sailing into the breeze. Will this help backing the boat, and maneuvering into the slip?
**** Yes, a 3 blade will provide more control in ahead and astern.
What size would be recommended for the 3 blade vs 2 blade? Do I need to keep the 16 x15 spec? I have researched the internet as much as I can without confusing myself, so asking y'all for opinions that will help make my final decision.
***** I will check for you Monday when the prop shop opens.
One prop calculator recommended 14.7 x 11.74 based on my specs above. Does this sound correct? It does not specify 2 or 3 blades.
**** Then what good is it?
Do I need to make any adjustments to this spec for the 2 or 3 bade choice?
***** Yes.
One final question: Teflon packing or Goretex? PTFE from WM is $ 7.50. GFO is $ 15. I trust any recommendation y'all can offer.
**** We use Goretex exclusively.
Joe DeMers
Sound Marine Diesel LLC
www.soundmarinediesel.com
John
Checked by AVG Free Edition.
Version: 7.5.446 / Virus Database: 268.18.25/745 - Release Date: 4/3/2007 12:48 PM
Re: How to Properly Use Sail Repair Tape
michaelkennedy052007-04-07 20:53
> problems.
> in May!
> Thanks,
> Bruce Stirling
> Gangfurd
> Cal 28 - Hull 82
Hi Bruce-
First thing, make sure you have the right kind. Make sure you have
Dacron and not nylon for this. The nylon kind only really works with
spinnakers. Hold the sail flat on a flat surface-enough tension to
take the wrinkles out but no more. Stick the tape on, then rub it
really good with the packing that you've peeled off. This will heat
up the glue a little and help it bond. No ironing needed. As others
have mentioned, depending on size and direction of tear, it may need
to be sewn by your friendly neighborhood sailmaker.
Mike Kennedy Jr.
Cal 40 Conquest #96
NYBoilermaker2007-04-08 18:44 UTC
Hello All,
I've got a fixed 3-bladed on Seredip now and it's a bear. Backing
down is great, but under sail with the prop in gear (reverse), you
can feel the brakes on. I'm looking for an alternate prop this year.
Perhaps trying to put on the 2 blade that came with her. The former
owners bought and installed a the 3 bladed. Perhaps a MaxProp is in
my future at the show in October.
Cheers,
JD
Serendipity
Cal 33-2 #153
On Apr 6, 2007, at 1836 EDT, John Raxter ~~~~~_/))~~~~
> the future, now is the time...
shore power connection for Cal 33-2
Bill Terrell2007-04-09 13:27 UTC
I'm curious as to where the shorepower inlet is located on other other
Cal 33-2's.
On ours, the shore power inlet is located inside the cockpit locker (on
bulkhead). This is convenient when we're not using the shorepower
cord, but when we do use it, I had to bend the cord between a gap in
the locker lid and the aft wall of the locker. As a result, this has
been hard on both the shorepower cord and on the locker lid (cracked
the lid where it bowed a little due to the cord).
I decided to move it into the cockpit but there didn't seem to be an
ideal spot for it. I finally settled on putting it just forward of the
the manual bilge pump on port side wall of the cockpit (above engine
controls). There was room behind this spot for the inlet fixture and
wiring, and I only need to re-route about 2 ft of the triplex AC
wiring.
Anyone else have the same problem??
tkx,
Bill Terrell
"Tupelo Honey", '88 Cal 33-2
Re: [Cal_Boats] shore power connection for Cal 33-2
NYBoilermaker2007-04-09 14:06 UTC
Hiya Bill and All,
The shore power inlet on Serendip is in the same place as yours was
originally. The locker lid on mine is good (slight crazing), but I'm
careful to not stress out that corner of the locker lid. I make sure
that the cord is secured outside of the locker somewhere so if
there's stress on the cord, it doesn't transfer to that bend into the
locker. She lives mostly on a mooring so it's not something that I
deal with often.
Here's another question for you guys/gals, two actually:
#1) I'd like to add another battery or two with the originals. Has
anyone added more storage capacity? If so, how did you make it fit?
The location is perfect access-wise, not to mention my old girl tends
to list to port at anchor. Makes for a quick Port tack though.
#2) Has anyone replaced the engine panel in the cockpit? Mine's
showing wear as well as cracking around the stop plunger. I'd love to
add a water temp gauge and a fixed VHF in the area. Thoughts?
JD
"Serendipity" Cal 33-2 #153
Last thing-Before I go out today and scan the entire 33-2 manual
electronically, does anyone already have a copy digitized?
> Cal 33-2's...
Re: [Cal_Boats] Re: How to Properly Use Sail Repair Tape
Chris Campbell2007-04-09 14:22 UTC
michaelkennedy05 wrote:
> Hi Bruce-
> spinnakers.
This reminds me of an interesting arrangement on my other boat. It came
with a spinnaker and pole and rigging, but for some odd reason some
previous owner had spliced up some nice spinnaker sheets of 3-strand
nylon. This created a self-adjusting system, because the sheet and guy
would stretch or shrink with wind-pressure changes. The farther forward
the pole was, the more dramatic the spontaneous changes. None of the
changes were welcome or helpful but they were all interesting. It did
not take long for me to convert the nice 3-strand nylon into mooring
lines and to splice some double-braid dacron onto the shackles for the
spinnaker.
It's somewhat akin to the nylon sail on my old DN iceboat. Hey, nylon
was high-tech and class-legal back in the mid-'50s. It's also
self-adjusting in the wrong way--the stronger the wind, the more draft
in the sail. @#$&*!!!!!.
Bill Terrell2007-04-09 14:22 UTC
Thanks JD. Good to know this was the original location of the
shorepower inlet.
I have two group 27 house batteries and one group 27 starting battery
in the compartment under the stbd settee. I saw one Cal 33-2 where the
starting battery was moved under the quarterberth. This seemed like a
good spot since it shortens the length of the battery cable to the
starter, but it also required moving the thru-hull for the engine
freshwater intake, which is more work than I've wanted to do so far.
I had some cracking around the plastic "box" on which the engine panel
sits. I removed the whole thing, removed the engine panel and then
epoxyed/repainted/reinstalled the box. Haven't found a source for the
clear plexiglass door frame though.
I'd love to get a copy of the original manual if you scan it.
best,
Bill
--- NYBoilermaker <ny… [at] gmail.com> wrote:
> Hiya Bill and All,
> deal with often.
> Thanks,
> JD
> other
> > Cal 33-2's...
RE: [Cal_Boats] shore power connection for Cal 33-2
darr lafon2007-04-09 14:35 UTC
My shore power is on the port side of the cockpit near the hand operated
bilge pump. Just behind it. Not bad unless you are on a starboard tack
and you are wedged up against it.
I re engineered the battery compartment on the starboard side to accept 2 x
4D gel batteries. Not easy and involved polyboard to make a new
compartment. A tight fit. I also put a group 27 back in the port lazarette
as the dedicated starting battery. Works OK.
I placed a RAM mike that is off the nav station VHF in the cockpit. It
works very well.
Hope this helps,
Darr LaFon
Of NYBoilermaker
Sent: Monday, April 09, 2007 10:06 AM
Subject: Re: [Cal_Boats] shore power connection for Cal 33-2
Hiya Bill and All,
deal with often.
JD
> Cal 33-2's...
Chuck Lennox2007-04-09 19:30 UTC
Hello
I'm a fan of the 3 blade Max prop. It's only down side is the price. I went from a 2 blade fixed to the 3 blade Max. It was night and day better in all categories. Headway in large swells is where I feel the price was worth it.
Chuck
Second Fiddle 2-34
Hello All,
I've got a fixed 3-bladed on Seredip now and it's a bear. Backing down is great, but under sail with the prop in gear (reverse), you can feel the brakes on. I'm looking for an alternate prop this year. Perhaps trying to put on the 2 blade that came with her. The former owners bought and installed a the 3 bladed. Perhaps a MaxProp is in my future at the show in October.
Cheers,
JD
Serendipity
Cal 33-2 #153
On Apr 6, 2007, at 1836 EDT, John Raxter ~~~~~_/))~~~~ <jr… [at] triad.rr.com> wrote:
The boat is hauled and I believe I could use a new prop. We are getting a slight vibration (knock) in the prop at a certain RPM (2500?) and I think this is due to the bottom paint/protective coating plus years of sanding and cleaning. If a new prop is in the future, now is the time...
Don't get soaked. Take a quick peek at the forecast
with theYahoo! Search weather shortcut.
Re: [Cal_Boats] shore power connection for Cal 33-2 & battery location
tr… [at] sbcglobal.net2007-04-10 03:22 UTC
Bill, et al,
I have an '86 33-2. The shore power connection is located on the port side, in the cockpit, just aft of the manual bilge pump, in the short section of seatback which connects the port seatback with the transom seatback. Seems to work pretty well.
I see that you've placed three group 27 batteries in the compartment under the stbd settee. I have two group 27 batteries in this location--just forward of the water tank. I was thinking about putting another so I would have the set-up you have. However, I did not see how to get a third battery in the space. How did you do it?
Travis
Sent: Monday, April 09, 2007 9:22 AM
shorepower inlet.
best,
Bill
> Hiya Bill and All,
> deal with often.
> Thanks,
> JD
> other
> > Cal 33-2's...
Bill Terrell2007-04-10 11:49 UTC
Interesting, it sounds like some of the Cal 33-2's have it in the
locker and some have it next to the bilge hand pump. Perhaps this was
the commisioning dealer's choice? I think I'm going to opt for the
spot immediately forward of the bilge hand pump on the port-side
cockpit wall, for the reason JD mentioned.
The layout of the batteries under my stbd settee (fwd of water tank)
is: two house batteries side-to-side and the starting battery fore-aft
on the stbd side of the compartment. Here's an attempt at a diagram:
|<=HB1=>^^^|
| SB1|
|<=HB2=>vvv|
The starting battery sits on a wood platform which raises it about thee
inches. I have isolated the house and starting batteries. The house
batteries are wired in parallel and go to the batt switch on the nav
panel and also to the alternator. The starting battery goes to a batt
switch under the settee and then to the starter. I use a battery
combiner to connect the starting battery to the house bank when voltage
gets to 14v.
The only think I dislike about this setup is the long battery cable
runs to panel, starter, alternator.
best,
Bill
--- tr… [at] sbcglobal.net wrote:
> Bill, et al,
> Thanks,
> Travis
> From: Bill Terrell
> shorepower inlet.
> battery
> the
> a
> far.
> panel
> the
> best,
> Bill
> > Hiya Bill and All,
> was
> I'm
> sure
> the
> I
> > deal with often.
> Has
> fit?
> tends
> love to
> > Thanks,
> > JD
> other
> > other
> > > Cal 33-2's...
