9 messages2007-04-10 14:57 UTCthrough 2007-04-11 04:07
Engine panel (was shore power connection for Cal 33-2) [JD]
Alfred Poor2007-04-10 14:57 UTC
JD inquired:
#2) Has anyone replaced the engine panel in the cockpit? Mine's
showing wear as well as cracking around the stop plunger. I'd love to
add a water temp gauge and a fixed VHF in the area. Thoughts?
The fiberglass "pan" that held the engine gauges, switches, and choke on
Pentaquod gave up the ghost soon after we bought the boat. We too wanted to
add a gauge (a tach), and so we enlarged the hole and bult a teak box to
hold the components. It has worked out well over the years. We have always
planned to put a plexiglass cover over it to protect it from the elements,
but haven't done so yet. It still looks pretty good and is very functional.
Alfred Poor
1969 Cal 29 #132, "Pentaquod"
Re: Engine panel (was shore power connection for Cal 33-2) [JD]
mtkennedy12007-04-10 17:17
--- In Ca… [at] yahoogroups.com, "Alfred Poor" <apoor@...> wrote:
> JD inquired:
I put a Beckson port over the engine panel in the 40. The Yanmar panel was small so I
made a fiberglass panel and mounted the Yanmar panel in it. That allows room for later
additions. The Beckson port is mounted hinge up so it tends to fall down when not lifted
up and it can be dogged down to make the panel waterproof. It's clear so the gauges are
visible and I lift it to start or stop the engine. The panel is recessed so it could be dogged
down with the key in the ignition switch.
Mike Kennedy
Conquest Cal 40 # 96
> Alfred Poor
CAL 29 V-Berth Cushions
Eric Jackson2007-04-10 17:47 UTC
Hey CAL 29 owners,
i am in the process of getting new v berth cushions made for my CAL 29..
i have the old cushions and covers that i am getting ride of, i think
they are the original 1971 cushions and vinyl covers that came with
the boat..
the foam is too soft for my back, but is in great condition (not
ripped or moldy).. the covers are still decent but the zippers have
finally failed.
just thought if someone was trying to save a buck or needed them for
something i am giving them away before i throw them in the trash..
anyone, anyone...
cheers
eric jackson
BAREFOOT
1971 CAL 29
CHANNEL ISLANDS CA.
RE: [Cal_Boats] Engine panel [JD]
ti… [at] ch2m.com2007-04-10 18:07 UTC
Temp Gauges and VHF are fairly simple.
You can use an automotive gauge (or "marine"), and only need minimal
wiring and a thermostatic connector. Tap Plastics can make
a box for you, and then put a clear cover on it, with a hinged opening
for stuff you need to get to, See the sensor and cover in photos. Cover
has hinged opening at key. (hinge is a plastic piece larger than the
hole, that
swings out of the way to gain access)
As for the VHF, Have you looked at the RAM (Remote Access Mike) ability
with many VHF's? I like this way
so you have two stations, with one radio. The expensive stuff is safe
below, and the two mikes work as an intercom.
> JD inquired:
<http://geo.yahoo.com/serv?s=97359714/grpId=16485695/grpspId=1705065792/
msgId=6486/stime=1176225635/nc1=4438963/nc2=4430620/nc3=3848610>
ti… [at] ch2m.com2007-04-10 18:23 UTC
Another use of "boxes" made by by tab plastics, is to recess instruments
in the bulkhead, so instrument heads are out of the way of seating and
rope snags, etc. and flush to the bulkhead.
See the one we made for our GPS repeater? (now you know EXACTLY
where I live.. if you can read the display!)
Tap doesn't have these in stock,... they built from my specs, so
you are open to any size you want.
dEmO
Behalf Of ti… [at] ch2m.com
Sent: Tuesday, April 10, 2007 11:07 AM
Subject: RE: [Cal_Boats] Engine panel [JD]
hole, that
> JD inquired:
Husar, Charlie2007-04-10 18:35 UTC
Timm, do you live right off the end of a runway and have golf balls come
crashing through your plate glass windows all the time?
Sent: Tuesday, April 10, 2007 2:24 PM
dEmO
hole, that
> JD inquired:
ti… [at] ch2m.com2007-04-10 19:42 UTC
Maybe that's it? I thought the big silver birds
were dropping eggs on me!
Behalf Of Husar, Charlie
Sent: Tuesday, April 10, 2007 11:36 AM
dEmO
hole, that
> JD inquired:
Re: [Cal_Boats] Engine panel (was shore power connection for Cal 33-2) [JD]
Paulson2007-04-11 03:30 UTC
Alfred Icantell you I made a mold to make a new panel Balsa woob and plywood did it covered with epoxie and primer. Dave Owens saw it last weekend and I know he was impresed. I could take some pics so you could see it not that Difficult
Dave paulson
Allergia
Cal334 ChannelIslands
Sent: Tuesday, April 10, 2007 7:57 AM
Subject: [Cal_Boats] Engine panel (was shore power connection for Cal 33-2) [JD]
JD inquired:
The fiberglass "pan" that held the engine gauges, switches, and choke on Pentaquod gave up the ghost soon after we bought the boat. We too wanted to add a gauge (a tach), and so we enlarged the hole and bult a teak box to hold the components. It has worked out well over the years. We have always planned to put a plexiglass cover over it to protect it from the elements, but haven't done so yet. It still looks pretty good and is very functional.
Alfred Poor
slickbutfoxbuger2007-04-11 04:07
if i may ask a question......
do i understand this right; you-all are custom making boxes
that are basically 4 to 6 inch deep inverted rectangles with outside
lips that keep them from simply falling through the holes that you
cut for them. and give mounting flanges to screw them down with????
fiver,
Master of The "BB-54"
one of the famous Cal-28 flush-decks
out of Sierra-5, Papa Hotel (in days gone by)
now resting outside my shop
Federal Way, Wa.
(built like a Battleship; sails like a Sub......)
--- In Ca… [at] yahoogroups.com, "mtkennedy1" <mtkennedy1@...> wrote:
> --- In Ca… [at] yahoogroups.com, "Alfred Poor" <apoor@> wrote:
> > JD inquired:
love to
choke on
wanted to
box to
have always
elements,
functional.
> Mike Kennedy
> > Alfred Poor
