9 messages2007-04-13 05:31 UTCthrough 2007-04-17 18:03 UTC
Cal 25 question
Marsh Wise2007-04-13 05:31 UTC
I have seen a lot of pix (okay, I save all I see online) of Cal 25
interiors. My question is, when did they change the galley to the
starboard side? Mine had it (since been removed) on the port side... is
there somewhere I could go to look at plans year by year? Or at least
the changes? Or was this an option.
Thanks for any help... Marsh
Re: Cal 25 question
slickbutfoxbuger2007-04-13 06:18
Yo, Marsh......
you are just looking at it the wrong way.
walk on down to-da other end and look back at your boat. it will all
be on the right side then.......you'll see.
now you be sure and stop by and see fiver in
Springfield when she gets there.... you-hear!
hope that helps...... :)(:
side... is
least
Re: [Cal_Boats] Re: Cal 25 question
Marsh Wise2007-04-13 14:36 UTC
:-Þ as to stopping, my cross countryin' days are done for a bit. a whole
month of it was enough... about killed me. :-0 However, next time I DO
make it to MO, I will try and stop. :-D
M.
slickbutfoxbuger wrote:
>Yo, Marsh......
>side... is
>least
>Yahoo! Groups Links
Some CAL 25 History - Was CAL 25 Question
Husar, Charlie2007-04-17 16:06 UTC
Hi, Marsh. It was around 700-800 hull that the interiors changed the
most (as you describe). That would have been circa 1968-1969.
Keep in mind that an East Coast plant opened around 1967 (NJ, I
believe). Looking at first one or two digits of hull number, the even
numbers (6xx, 8xx, 10xx, 12xx, and so on) were built in New Jersey, and
the odd numbers (7xx, 9xx, 11xx, and so on) were built in California.
Most boats here are even numbers.
Old Interior - (Sometimes called an "A" Hull) Small sink port aft in
cabin on small counter. Dining table starboard. No shelves forward.
No quarterberth bunks. Aft is wide open spaces under seat hatches
except for water tank in middle under cockpit. Toilet longitudinal in
head space on port side with forward bulkhead farther forward than newer
boats (shorter vee berth)
Newer Interior - Large starboard side counter with sink. Dining table
port. Shelves in vee berth area. Two quarterberth bunks. Water tank
forward under vee berth. Toilet sideways in head space on port side
with head space compressed by moving the forward bulkhead aft.
Newest Interior - This one started circa 1974 with the 1500-1600 hulls.
Mostly the same as newer, except long shelf/storage space added on port
side in main cabin. #$^*#$(& carpet installed on interior walls below
shelves forward, and below deck hull joint in main cabin and aft.
Looks like boats got heavier as time went on, but there was also more
bracing against hull oil canning (if that was ever a thought given the
thick hull). A lot of it could have been comfort based to sell a
cruising boat. Also some boats have a bilge well at the back of the
keel lead ballast, and some have a flat ballast all the way back. No
particular hull number pattern her that I could see. My 460 has the
well. My 1657 has flat ballast. My 1845 has the well.
By the way, 1845 was one of the last CAL 25 flat decks built in March of
1977. Don't know when they stopped in California. Just talked to an
owner in CA who has Hull number 2 (This one is barer than even the old
interior described above.)
I do not believe that original design material exists for the
variations. Roger Jones might correct me, but whatever is available is
minimal. Other minor variations exist. Hope this helps some.
Behalf Of Marsh Wise
Sent: Friday, April 13, 2007 1:32 AM
Subject: [Cal_Boats] Cal 25 question
Re: [Cal_Boats] Some CAL 25 History - Was CAL 25 Question
Marsh Wise2007-04-17 16:32 UTC
Awesome! (showing my California roots there, huh?!)... Okay, well then
if that's how it was, what was removed in this picture (I thought it a
galley):
pix1
here's another pix if this helps:
pix2
> and the odd numbers (7xx, 9xx, 11xx, and so on) were built in
> California. Most boats here are even numbers.
> newer boats (shorter vee berth)
> hulls. Mostly the same as newer, except long shelf/storage
> space added on port side in main cabin. #$^*#$(& carpet installed on
> interior walls below shelves forward, and below deck hull joint in
> main cabin and aft.
> of 1977. Don't know when they stopped in California. Just talked to
> an owner in CA who has Hull number 2 (This one is barer than even the
> old interior described above.)
> is minimal. Other minor variations exist. Hope this helps some.
> Cheers
> Charlie
RE: [Cal_Boats] Some CAL 25 History - Was CAL 25 Question
Husar, Charlie2007-04-17 16:56 UTC
Marsh, I forgot about the mini-hanging locker you have in port forward
main cabin. That does not exist in the later boats. Also, the cooler
that is the step into the cabin is not on later boats, just a step. The
large counter to starboard on the newer ones has a top opening cooler.
Somebody went and ripped out your sink and small counter on the aft port
main cabin. How uncivilized.
Sent: Tuesday, April 17, 2007 12:32 PM
Subject: Re: [Cal_Boats] Some CAL 25 History - Was CAL 25 Question
galley):
changed the most (as you describe). That would have been circa
1968-1969.
aft in cabin on small counter. Dining table starboard. No shelves
forward. No quarterberth bunks. Aft is wide open spaces under seat
hatches except for water tank in middle under cockpit. Toilet
longitudinal in head space on port side with forward bulkhead farther
forward than newer boats (shorter vee berth)
table port. Shelves in vee berth area. Two quarterberth bunks. Water
tank forward under vee berth. Toilet sideways in head space on port
side with head space compressed by moving the forward bulkhead aft.
hulls. Mostly the same as newer, except long shelf/storage space added
on port side in main cabin. #$^*#$(& carpet installed on interior walls
below shelves forward, and below deck hull joint in main cabin and aft.
more bracing against hull oil canning (if that was ever a thought given
the thick hull). A lot of it could have been comfort based to sell a
March of 1977. Don't know when they stopped in California. Just talked
to an owner in CA who has Hull number 2 (This one is barer than even the
Marsh Wise2007-04-17 17:21 UTC
So, the hanging locker was converted to drawers?
> The large counter to starboard on the newer ones has a top opening cooler.
> port main cabin. How uncivilized.
> Cheers
> Charlie
> galley):
Husar, Charlie2007-04-17 17:57 UTC
Marsh, if there are drawers in there, then it is a conversion. Not a
bad one. The ONLY original drawer in the boat was starboard forward
main cabin under the seat. This large drawer held the old dangerous
alcohol stove (would spit alcohol with invisible flame). The sink
counter (that you don't have) had doodads to attach the stove and a
strap to the ceiling to hold the stove in place so you could cook right
next to the little sink (that you don't have).
Sent: Tuesday, April 17, 2007 1:22 PM
forward main cabin. That does not exist in the later boats. Also, the
cooler that is the step into the cabin is not on later boats, just a
step. The large counter to starboard on the newer ones has a top
opening cooler.
aft port main cabin. How uncivilized.
Marsh Wise2007-04-17 18:03 UTC
Hey, I DO have the sink, its just not in anything. It's in one of the
lockers under the cockpit :-Þ
> right next to the little sink (that you don't have).
> Cheers
> Charlie
