7 messages2007-04-28 13:21 UTCthrough 2007-05-01 21:50 UTC
Cal 33-2 Fuel Tank Corrosion (Long)
Al Waschka2007-04-28 13:21 UTC
So I went down to the boat last weekend and when I opened the hatch I
was greeted with a strong diesel smell. This has happened before, after
a refueling. There was diesel in the bilge, again. Last time I figured
I had over filled the tank and it had leaked from the fill or vent hose
somewhere although it bothered me that I never could find the source of
the leak. This time I checked all the hoses more or less end to end and
found no leaks. There was no evidence of fuel in the engine bilge. The
obvious conclusion was it was the tank. I stuck a batten with a paper
towel wrapped around it between the fuel tank and the port water tank
and it came back with a greasy red sludge on it.
Yesterday I pulled the tank. Pulled the fuel sender and used a Tempo
hand pump to pump the fuel out into tanks. That went more quickly than
I expected. BTW, nice yellow diesel tanks are only about $6.50 at
Wal-Mart. Hardest part was getting the fill hose off the barb. Ended
up pushing the fill and vent hoses back under the sink to clear the top
of the tank. With all hoses, sender line and ground wire off the tank
and clear I pushed the tank outboard while lifting and then rotated the
inboard end above the settee edge and took the tank out.
Apparently the forward inboard end is the low point in the tank. There
was a mass of red gunk on the tank and when I pushed on it with a
screwdriver, it completely failed over an area about 1/4" x 1/2". I was
VERY close to having 24 gallons of diesel in the bilge. My assumption
is that condensation collected there and corroded the tank from the
inside out. There was no significant indication of abrasion on the
outside of the tank, which is what I was actually expecting to find.
FYI, at either end and the middle of the tank there is a tubular opening
in the sub-sole about 1-1/2" inch in diameter which apparently goes into
the bilge. It is used for routing wiring at the forward and after end.
In my case, the middle one provided a way for the seeping fuel to get
into the bilge. So now I am cleaning up the tank, assessing the damage,
and trying to decide whether to try to repair the old tank or replace
it. The original manufacturer, Florida Marine Tanks, is still in
business. I have asked them and another custom tank manufacturer for a
quote. The other one has already responded: $760 in Al, $980 in
stainless. Makes a repair or a neoprene bladder start to look
attractive.
Anyone have any experience with the bladder-type tanks?
Al
1974 Cal-25 #1693, "Sweet Mary"
1985 Cal-33 #0026, "Short Wave"
RE: [Cal_Boats] Cal 33-2 Fuel Tank Corrosion (Long)
darr lafon2007-04-28 14:09 UTC
Al,
I had the same problem with Alcyone about 3 years ago. It was after Ivan
blew through and rocked the boat real hard. My tank was not badly corroded
so I elected to get a lot of JB Weld and place half way up the inboard side
and half way up the slanted bottom. Seemed to work well. Boat went from
Destin to Annapolis with no leaks.
I figured the corrosion was from outside as the low point also always seems
to have a little water sitting there. It sounds like your tank is a goner,
however. Three years ago the Florida tank company gave me a quote of $250
for an aluminum tank. A 300% increase is pretty steep. I would re-engage
with them or see if someone can put a good large aluminum patch over the
area.
Getting the fill hose off was an absolute bear of a job. Getting it back on
is going to be even more fun. :-) I went ahead and replaced all the fuel
lines at the same time.
Hope this helps.
Darr LaFon
Alcoyne, 86 Cal 33
Of Al Waschka
Sent: Saturday, April 28, 2007 9:21 AM
To: Cal Boats Yahoo News Group
Subject: [Cal_Boats] Cal 33-2 Fuel Tank Corrosion (Long)
attractive.
Al
Re: [Cal_Boats] Cal 33-2 Fuel Tank Corrosion (Long)
Al Waschka2007-04-28 15:05 UTC
Hi Darr -
Hope everything continues to go well in Cinncinnatti. Thanks for the
info on Florida Marine Tank. They are not the ones that gave me the
expensive quote. I'm hoping to hear from them. Maybe I'll give them a
call in case they don't check their e-mails often. $250-$300 is about
what I was expecting. The $760 quote blew me away. Since I posted
first I've pressure cleaned the outside and found a few more suspect
areas. Not leaking now but could be soon. I discussed the tank with a
friend and we've concluded there is a new tank in my future.
Al
NYBoilermaker2007-04-29 05:48 UTC
Plastic fuel tank?
> after
> figured
> hose
> source of
> end and
> bilge. The
> and it came back with a greasy red sludge on it...
Chris Campbell2007-05-01 12:48 UTC
> it.
Al:
Yesterday I read your question. Last night I found my latest _Practical
Sailor_ in the mailbox and they have an extended article on replacing
fuel tanks and what materials to use--and how to use them effectively to
prevent corrosion in the future. By the way, there's no mention at all
of bladder options for fuel. They like aluminum and steel. The last
page has a short mention of ways to get rid of diesel odor in the bilge
(hot-water pressure washing, with lots of ventilation).
Michael D2007-05-01 14:07 UTC
When I repowered Magic, I chose to replace the 20+ year old tank... Just to say that it cost about $160 for a new aluminum 13 gallon tank I had fabricated. I removed the old tank, took it to a local shop, put it on their counter and told them I wanted one as close to the original as they could make it.
See the attached photos...
Regards,
Michael Duvall
s/v Magic #627 Cal 2-27, 1979
Pompano Beach, FL
Ahhh...imagining that irresistible "new car" smell?
Check outnew cars at Yahoo! Autos.
John Boyce2007-05-01 21:50 UTC
Michael,
Nice install on the tank I notice you have a wheel installed on the boat.
The install looks new in the picture. Did you do it yourself? How does it
work in the cockpit. I've been thinking about installing a wheel but I was
afraid that the cockpit was too narrow for a wheel.
John Boyce
Gotcha Again
Cal 2-27 #650
Of Michael D
Sent: Tuesday, May 01, 2007 9:07 AM
Subject: Re: [Cal_Boats] Cal 33-2 Fuel Tank Corrosion (Long)
could make it.
Regards,
Michael Duvall
Pompano Beach, FL
Check out new
<http://us.rd.yahoo.com/evt=48245/*http://autos.yahoo.com/new_cars.html;_ylc
=X3oDMTE1YW1jcXJ2BF9TAzk3MTA3MDc2BHNlYwNtYWlsdGFncwRzbGsDbmV3LWNhcnM-> cars
at Yahoo! Autos.
